Bed rail system installation problem
Discussion in '2.5 Gen Tundras (2014-2021)' started by TucsonTundra1794, Mar 25, 2021.
  1. Mar 25, 2021 at 6:38 PM
    TucsonTundra1794
    TucsonTundra1794 [OP] ASCM #6-11 I'll buy if you're willing to ship
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Hey guys, my 2017 didn't come with the bed rail system so I purchased it from Toyota and tried installing it today. It seems some of the holes in the bed aren't accepting the provided screws, I'm pretty sure I marred the threads on one of the screws trying to get it in and another won't even grab. Out of the 15 screws needed, 3 of them are having this problem.
    My questions are:
    Can I re-thread the holes and try again with new screws?
    Can I buy slightly larger self-tappers and use those?
    Since it's only 1 screw on each rail that is having an issue Can I use the rails normally with out them and without worrying about them coming off?
    Any help would be appreciated. Thanks!
  2. Mar 25, 2021 at 6:42 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    I have 2 missing on mine and haven't had any issues. but if it worries you I would rethread it. Goodluck.
  3. Mar 25, 2021 at 6:46 PM
    Be careful, those screws are not that strong so don't overtorque them.
    NewImprovedRon likes this.
  4. Mar 25, 2021 at 7:02 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I pulled the problem ones and the threads are jacked, didn't even torque them down yet. I'll run them without those screws like saybng mentioned and see how it goes. Maybe down the line If it bugs me enough I'll re-thread. Thanks for the help guys.
    The Towse Tundra 2.0 likes this.
  5. Mar 30, 2021 at 2:20 PM
    Stover87
    Stover87 New Member
    I am having the same issue but with 3 on one side. Wondering if you found a good solution?
  6. Mar 30, 2021 at 2:39 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I bought a Tap at an auto parts store for under $10 and chased all of mine before trying to screw into the holes and it was all that I needed.
    Mine had Line-X in many of the holes so I did this as I expected that there would be problems with some of them.
    RitcheyRch and JPBeeMan like this.
  7. Mar 30, 2021 at 6:10 PM
    JPBeeMan
    JPBeeMan Lab Approved
    Eastern Iowa
    2021 Limited Nightshade, Blk Metallic, Moonroof, TRD Exhaust
    Alpharex Headlights, BAK Revolver X4 Bed Cover, PowerBoard NX Running Boards, Sprint Power Booster, Blacked out 3rd Taillight and Taillights, Wireless Charging Tray, OPT7 LED Tailgate Light Bar and LED Truck Bed Light Strips.
    If you have a tap & die redo the threads on both the screw and hole.
    BlueCrushSC16 likes this.
  8. Mar 30, 2021 at 6:56 PM
    Stover87
    Stover87 New Member
    I was afraid I damaged the threads in the bed but, it was just Bedliner stuck in the threads. The tap worked like a dream and the size was 6mm-1.00 if that helps anyone?
    Thanks for the help!
    RitcheyRch likes this.
  9. Mar 30, 2021 at 7:26 PM
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Aries Side Bars, DeeZee low profile tool box, weathertech mats, TRD RSB
    mine is an 18 and no rail system either. Bedside holes are M6 X 1.0. Bought tap and have chased all threads. Bolts are shouldered and are Metric 10.2. Supposed to be stronger than grade 8 SAE. Planning eventually on trying the Unistrut DIY. Any way tap maybe the best to recover threads just do as we all do little forward and more in reverse. Anyway good luck.
    R65 and JPBeeMan like this.
  10. Dec 16, 2021 at 11:30 AM
    Ahutch_6
    Ahutch_6 New Member
    2017 Toyota Tundra SR5 crewmax
    I have a 17 and a spray in bed liner when I tried to install bolts went in but not all the way. Should I try the Tap? Also will it damage rail system if I try pulling rails off truck? Specifically the long points that hold in place while you put bolts in?
  11. Dec 16, 2021 at 12:01 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I don't understand the second half of your question but for the first half, using a tap did help but I wasn't able to get 2 bolts in even after that. So 2 of my rails are missing 1 bolt each.
