Bed removal
Discussion in '1st Gen Tundras (2000-2006)' started by shoe07, Apr 16, 2022.
  1. Apr 16, 2022 at 6:47 AM
    shoe07
    shoe07 [OP] New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    Good day fellas, just finished my exhaust install and while I was down there I decided I wanted to get after the rust that’s on the underside of the bed this spring.
    Does anyone know how much the bed weighs?
    Is it a two man job, or more of a four man?
    thank you
  2. Apr 16, 2022 at 7:57 AM
    Casper421
    In the woods
    06 DC
  3. Apr 16, 2022 at 8:05 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Considering how awkward it is I would guess 4 man if you don’t want to drop it.
    I think someone used a tree once with some straps and a cumalong to get it off by themselves.
    I could picture using an engine hoist myself.
  4. Apr 16, 2022 at 8:12 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Weight alone, two strong men might be able to do it, but the shape of the thing says no. And, it doesn't lift straight up. The back of the bed has to come up slightly, then the whole thing toward the back back to clear the front of the bed from the cab. 4 men with gloves.
    FirstGenVol and NUDRAT like this.
  5. Apr 16, 2022 at 8:14 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  6. Apr 16, 2022 at 8:16 AM
    alb1k
    Left Coast
    It's good
    If you had a hoist that had the reach or came from above center bed, that works. If you lift it off and put it down somewhere, have a plan as to where to put it and on what.
  7. Apr 16, 2022 at 8:18 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I have a buddy used an engine hoist to lift off his 2005 F250 bed.
    I used 3 buddies to swap my '02 Tacoma bed. 4 made it real simple. 2 would have done.
    On a Tundra I'd use 4 people, it's longer & wider & you need to lift it off/around the filler neck, hard to maintain control for 2 people.
    Some folks just raise the bed with some blocks of wood to work on the underside - you could do that solo, but what a PIA.
    old bed off - standing up so much easier to deal with (didn't take pics of the new bed for some reason)
    Jack McCarthy likes this.
  8. Apr 16, 2022 at 8:27 AM
    “J”
    “J” New Member
    NC
    2021 Tundra SR Barcelona Red
    I’ve aided in a few bed removals. 3 guys can do it. One on each side, one on the back.
  9. Apr 16, 2022 at 8:32 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
  10. Apr 16, 2022 at 8:46 AM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    I did mine with me and the neighbor both on and off without real struggle. 3-4 would make it cake but 2 was very doable.
    NUDRAT and Jack McCarthy like this.
  11. Apr 16, 2022 at 7:10 PM
    shoe07
    Ohio
    Thanks for the info fellas
  12. Apr 16, 2022 at 7:54 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    When I fixed the rust in my bed, I used ratchet straps and hung it from the garage rafters. Worked out well, and just relaxed one side at a time to tip it up..
    Jack McCarthy and NUDRAT like this.
  13. Jul 18, 2022 at 12:46 PM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Is it just the 6 bed bolts, unclip taillight wires, and maybe a couple screws at gas filler neck?
    If using straps or hoist overhead, what is best place to hook onto bed for lifting?
    Edit: just noticed i ventured into 1st gen thread but I assume same process for newer gen too.
