Belt/ idler pulley recommendations
Discussion in '2nd Gen Tundras (2007-2013)' started by Mmars, Feb 2, 2025.
  1. Feb 2, 2025 at 6:24 PM
    Mmars
    Mmars [OP] 2009 Tundra
    2009 Tundra SR5, 4x4, 5.7 flex fuel
    Usually the search feature is my friend. However I didn’t find anything about recommendations for belt, idler pulley, and belt tensioner replacement for the 5.7. Some on the first gen. May only need the belt but at 180k and if more need replacement I’d prefer to be ready.
  2. Feb 2, 2025 at 6:44 PM
    j_supra
    j_supra Dreamin about boooost!
    Manitoba, Canada
    2008 Tundra Limited
    20x9 Vision brawls, 285/60 Toyo at3s, Bilstein 5100s, Tint, rock warrior grille, all chrome removed. fully paint matched, HID headlights, LED tail lights, LED fog lights, Doug thorley LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub,
    Are you wondering what brand or if you should replace more parts? I'd loosen the belt quickly and give your idler and tensioner pullies a quick spin. If they don't feel and sound the best, might as well replace them too. I got dayco for all of it for mine. From rock auto. Dayco is the oem supplier for second gens.
    Tim98TA and AZTundra like this.
  3. Feb 2, 2025 at 7:05 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    belt: 90916-A2033
    tensioner: 16620-0S012
    The Toyota parts are good. I have found the belts to last longest with least stretching.
    As mentioned above, remove the belt tension and check the idler pulleys.
    Mmars[OP] likes this.
  4. Feb 3, 2025 at 4:50 AM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    I ordered mine from Toyota, costs more but worth it for piece of mind IMO. Honestly the OEM belt tensioner is downright cheap all things considered.
  5. Feb 3, 2025 at 5:59 AM
    skiTRDPro
    skiTRDPro New Member
    2016 DC TRD Pro
    I ordered the Dayco kit for mine from rockauto.
    The idler pulley turned out to be a defect and started whining on cold start after a month or so, replaced it with a continental idler and it went away. Probably just unlucky.
  6. Feb 3, 2025 at 6:14 AM
    Mmars
    Thanks all!!!! that’s the feedback I was looking for. I work a lot and I’ll buy all the parts to replace anything that is needed as I pull work on it.
  7. Feb 3, 2025 at 6:15 AM
    Mmars
    Here’s my Tundy too
  8. Feb 3, 2025 at 6:26 AM
    Leedaar
    Leedaar New Member
    2016 Tundra CM
    I bought OEM parts: belt, tensioner and idler pulley from an online Toyota dealer for about $180 shipped. Also got a new hex bolt too (mine was rusting already). No more cold start squeal. 2016 with 120k miles.
  9. Feb 3, 2025 at 6:42 AM
    Cox3497
    Cox3497 New Member
    Toyota Tundra Crewmax
    I bought the Dayco kit from Rock Auto as well after initially purchasing the Gates kit. Upon unpacking of the Gates kit, I was not happy with the apparent quality and condition of the parts (very heavy machining marks with “made in China” in a cheap looking laser engraving on the belt tensioner). I returned them and reordered the Dayco. I am very happy with the Dayco parts. Clearly higher quality. In addition, when I removed the old belt tensioner from the engine, it was stamped as a Dayco part. Also, the Dayco tensioner comes pre pinned making install easier (will make more sense when you see how to remove the belt and pin the tensioner). Clear evidence of a superior part. Would highly recommend doing the belt tensioner and the idler pulley with the belt as they’re really designed to be changed together. My tensioner was making some noise but that is now all gone. Finally, consider buying a serpentine belt wrench. Good piece of gear.
    https://www.homedepot.com/p/GEARWRE...-Tool-and-Socket-Set-15-Piece-3680D/204622165
    Mmars[OP] and Norfolk757 like this.
  10. Feb 3, 2025 at 6:56 AM
    Leedaar
    Leedaar New Member
    2016 Tundra CM
    ^ I bought a $12 breaker bar from harbor freight that did the job just fine.
  11. Feb 3, 2025 at 7:04 AM
    Cox3497
    Cox3497 New Member
    Different strategies. I bought the OEM parts from Dayco and the serpentine belt wrench for cheaper than I could have bought the Toyota branded parts. I have a breaker bar as well and the serpentine belt wrench is definitely better suited for the job.
