Best fuel injector cleaner
Discussion in 'Performance and Tuning' started by Chief 01, Mar 4, 2019.
  1. Mar 4, 2019 at 4:54 PM
    Chief 01
    Chief 01 [OP] New Member
    PA
    2020Tundra Pro Army green
    Any one ever heard of using PB Blaster to clean injectors?
  2. Mar 4, 2019 at 4:57 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    There is detergent in gas. I went over 200k on stock injectors before upgrading.
    10TundraSR5 likes this.
  3. Mar 4, 2019 at 4:59 PM
    Chief 01
    PA
    Coming up on 200k soon, what injectors did u use
  4. Mar 4, 2019 at 5:00 PM
    dirtydeeds
    Keith
    USA
  5. Mar 4, 2019 at 5:02 PM
    Casper421
    In the woods
    06 DC
  6. Mar 4, 2019 at 5:04 PM
    Chief 01
    PA
    That what I have, it's been throwing up all different codes, last one was about burning to rich, and MAF/VAC, replaced the MAF
  7. Mar 4, 2019 at 5:07 PM
    dirtydeeds
    Keith
    USA
    Post up the codes. Maybe I can help
  8. Mar 4, 2019 at 5:11 PM
    Chief 01
    PA
    The only one I remember is P0100, I think it's the maf/vac. Replaced MAF, I will have to check tomorrow and let you know the other 2, ty.
  9. Mar 4, 2019 at 5:12 PM
    Chief 01
    PA
    Bad gas mileage and jerking or hesitation on hard acceleration ????
  10. Mar 4, 2019 at 5:12 PM
    Professional Hand Model
    Hand Protectors
    Hey Chief. Try the 250cc injectors. They’ll put hair on your chest.
  11. Mar 4, 2019 at 5:22 PM
    Chief 01
    PA
    Sounds good but I have enough, but I just want the check engine light to stay off, replaced all O2 sensors, both converters and resonater, plugs,and coils, is the injector job a diy.
  12. Mar 4, 2019 at 5:33 PM
    PtundraA
    PtundraA New Member
    Nick
    2008 Timberland Mica DC 4.7L 4x4
    Did your dash look anything like this?
    Edit: my truck was not in 4x4 at the time. Dash randomly lit up like this after one of the big temperature swings here in PA.
  13. Mar 4, 2019 at 5:40 PM
    Chief 01
    PA
    No just check engine light, thank God, did it clear up ?
    PtundraA likes this.
  14. Mar 4, 2019 at 5:42 PM
    Chief 01
    PA
    Was told it might be ecm also
  15. Mar 4, 2019 at 5:51 PM
    PtundraA
    PtundraA New Member
    Nick
    Got ya. Just a simple $10 fuel additive worked for me. That and unhooked the battery for a minute to reset the lights.
    I went to autozone to get the codes printed off and the guy there told me he had the exact same issue years prior in his tundra, same model. Told me that the code was the same thing he had and his actually went away when the temp raised up and maybe dried out the sensor or something. Either way he told me it was the emissions system and not really a big deal if it’s running good. I gave it a couple days and it actually did go off on its own but came back a day later. This was with all the crazy weather we had a few weeks ago. So I ran the additive and reset the battery and it runs like a beast again with no lights
    Right? Wrong? I don’t know, seems to be working so far haha.
  16. Mar 4, 2019 at 6:04 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    I used fuel system cleaner called B12 from Wal-Mart. Worked good but I didn't have a light on. Just sluggish and surging. Fuel mileage increased too
  17. Mar 5, 2019 at 2:09 AM
    PtundraA
    PtundraA New Member
    Nick
    I used CRC G2P or something like that.
  18. Mar 5, 2019 at 2:41 AM
    Adam New Member
    You may be going into AIP failure. Its ok, on your 08 you can buy a kit to bypass it rather than spend the 2k to fix it. Toyota did extend the warranty periods on those though.
    PtundraA[QUOTED] likes this.
  19. Mar 5, 2019 at 3:50 AM
    Hand Protectors
    Come back over to the 1st Gen Section to find out. We miss you over there Chief.
  20. Mar 5, 2019 at 4:57 AM
    PtundraA
    PtundraA New Member
    Nick
    Thanks Adam. That’s good info to know.
  21. Mar 5, 2019 at 5:38 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    On the truck?...Or off? No.
    Techron has always worked for me whenever my 22RE would begin to miss, stumble, hesitate, etc. You get it as an additive in Chevron gasoline, but Chevron is pricey here compared to other top tier brands. I just buy whatever good gasoline I can find cheapest, and pour Techron in the tank when needed (rarely).
  22. Mar 5, 2019 at 6:54 AM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    BG 44K is a great fuel system cleaner and it should clean your EFI system. It’s basically kerosene that makes fuel burn hotter and it burns the bad residue off.
  23. Mar 5, 2019 at 7:08 AM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    I think it was MotorTrend magazine that did a test on a bunch of fuel cleaners. STP complete fuel system cleaner worked the best. I always use top tier gas and then the STP cfsc every 10,000 miles. I got 250K+ miles on a V-8 4Runner with no problems. Take care of your ide and it’ll take care of you. :D
  24. Mar 5, 2019 at 6:11 PM
    Chief 01
    PA
    New check engine codes, PO172, P0175 and P0100, replaced the maf, cleared the codes and the check engine light came back on with same codes, bad gas mileage, hesitation or jerking going up steep hill , and hard acceleration , smooths out when I leave up gas pedal.???????¿?
  25. Mar 5, 2019 at 6:49 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    Did you check the fuel filter?
  26. Mar 5, 2019 at 7:08 PM
    Chief 01
    PA
    Yes was changed two years ago before the problems
  27. Mar 5, 2019 at 7:37 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    I'm not sure what to tell you, you've pretty much done everything within reason to stop the CEL from coming on and to stop the "bad gas mileage, hesitation or jerking going up steep hill , and hard acceleration..." It may indeed be the MAF sensor not communicating correctly with the ECM, that is, the ECM is getting a bad signal from the MAF.
    Does not make sense. System too rich yet it's jerking and feels like it's misfiring? The P100 code is MAF or VAF A Circuit Malfunction code and you replaced the MAF sensor? You replaced the fuel filter, and "...replaced all O2 sensors, both converters and resonater, plugs,and coils..." and it's still not running right and it's throwing the stupid CEL?
    Might be the ECM. Not sure what the heck else could be wrong.
    NewImprovedRon likes this.
