Best full length antenna
Discussion in 'General Tundra Discussion' started by idiggplants, Jan 7, 2021.
  1. Jan 7, 2021 at 7:57 PM
    idiggplants
    idiggplants [OP] New Member
    PA
    2013 DC 4wd
    5100 fronts middle setting 5100 rears 3rd gen offroad wheels softopper ditch lights
    whelp, im the function over form type. it seems that's less than common where antennas are concerned. i cant search the forum for best antenna without a million results for stubby antennas.
    when it comes down to it, i want it to work. is there a good or great brand of aftermarket antenna that anyone has found to work particularly well?
    i rarely listen to the radio, but when i do, its usually trying to tune into football on the way home from my cabin and the better the reception means more of the game i get to listen to
    70m4h4wk likes this.
  2. Jan 8, 2021 at 7:26 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    why aftermarket? The stock antenna works fine and you can probably pick up a good used unit for next to nothing.
    1lowlife likes this.
  3. Jan 8, 2021 at 7:29 AM
    idiggplants
    PA
    2013 DC 4wd
    stock unit snapped off so looking for a replacement. wasnt sure if there was an aftermarket one that would work better, or be less prone to snapping off. but honestly i hadnt thought about a used oem one. you're right, with everyone going to stubby, there might be some cheap ones out there.
  4. Jan 8, 2021 at 7:30 AM
  5. Jan 8, 2021 at 7:37 AM
    idiggplants
    PA
    2013 DC 4wd
  6. Jan 8, 2021 at 7:39 AM
    They also sell full length and mid length antennas.
  7. Jan 8, 2021 at 7:41 AM
    idiggplants
    PA
    2013 DC 4wd
    yeah, i know. i'm looking to see if they will be an improvement over oem full length.
    Tundyfundy likes this.
  8. Jan 8, 2021 at 10:22 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    What you need is either an amplified antenna or a signal booster such as this https://www.crutchfield.com/p_12044UA60/FM-Signal-Amplifier.html
    Without a amplified antenna you won’t see any Benefit between brands. Make sure you get an antenna that’s at least 32” for best reception.
    You could also try mounting your antenna away from the engine bay for better reception. The booster will only boost signals Within range. For instance if you are picking up a station and it’s really weak. It’s not magic but it helps in a lot of situations.
