Best Gen Hood wrap? Buy it or have it done?
Discussion in '1st Gen Tundras (2000-2006)' started by Jerry311SD, Jun 25, 2019.
  1. Jun 25, 2019 at 7:29 AM
    Jerry311SD
    Jerry311SD [OP] New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    I want to wrap the middle section of my hood matte black to match my roof.
    I want it to go from the cowl by the wipers to the grill.
    Are there (Precut) pieces I can buy and slap on my self, Or should I just take it to a shop and have it done?
  2. Jun 25, 2019 at 3:19 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I haven't seen anything pre cut. I have looked some because this is the look I wanted to do eventually. I was looking into using the vinyl tape and doing it myself probably, but I'm kind of a cheap ass. I'd imagine this is a common type of thing for a vinyl shop to do. They probably love that kind of work because it's mostly flat.
  3. Jun 25, 2019 at 3:29 PM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    I could do it myself BUT if the lines on the side are not straight I wont be able to sleep at night.
    Darkness and Sunnier like this.
  4. Jun 25, 2019 at 3:31 PM
    KarmaKannon
    Utah
    Some junk
    Well and the hood lines aren't very pronounced. I think it would be hard to get perfect but you could always lay it out carefully with marker and a paper with a grid on it I suppose. I understand the not sleeping thing. It sucks knowing something isn't straight.
  5. Jun 25, 2019 at 6:42 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Would Plasti-dip and masking tape work for what you're trying to do?
    Darkness likes this.
  6. Jun 25, 2019 at 9:57 PM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    It would work, but the roof of the truck is already wrapped with black vinyl. It wouldn't look the same I don't think.
    I'll call a shop and see how much they'll charge for the middle of the hood.
    Darkness and KarmaKannon like this.
  7. Jun 26, 2019 at 4:32 AM
    Professional Hand Model
    Hand Protectors
    Pull the vinyl and do both. I am amazed at all the Plastic Dip options available. Thought it was only black and white colors they provided. They have a wide selection of colors and metallic, as well. They even have a satin toner for reducing gloss.
    Pudge likes this.
  8. Jun 26, 2019 at 5:35 AM
    KarmaKannon
    Utah
    Some junk
    Plasti dip is cool but I'd personally rather have vinyl. I had Plasti dip on some truck parts before and it would start to peel and it was a huge pain to remove or touch up. I guess vinyl is a pain too, but on something mostly flat like a hood or roof I bet the removal would be simple with a heat gun.
  9. Jun 26, 2019 at 6:35 AM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    I did my old ford Cammo green plasti dip came out nice.
  10. Jun 26, 2019 at 6:37 AM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    The lower part of the truck is Plasti dip around the fog lights its starting to peel up.
  11. Jun 26, 2019 at 6:52 AM
    Hand Protectors
    How long has it been since install?
  12. Jun 26, 2019 at 7:09 AM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Maybe 6 months, But the part that is pealing is on the bottom portion below the fog light on one side. Could have been shitty prep or poor coverage or me driving in the weeds who knows.
    I do know plasti dip lasts longer then 6 months.
    I'm leaning towards vinyl because the roof is already done . The grill portion Im going to find a grill from a black truck and keep my gold grill. see what that looks like.
  13. Jun 26, 2019 at 7:38 PM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    @Professional Hand Model
    The plasti dip is peeling. Looks like my fault poor prep and coverage.
    I'd like the center hood and the grill and the plasti dip section I did by the fog lights black matte wrap, like my roof.
  14. Jun 26, 2019 at 7:55 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I would probably pay a tiny shop to do it vinyl, then not sleep at night because they didn't get it straight either.
  15. Jun 26, 2019 at 8:21 PM
    KarmaKannon
    Utah
    Some junk
    The Plasti dip I had would get rock chips and the bubble and peal from there. I think it's just inherent to the idea of a thin spray on coating like that.
    Jerry311SD[OP] likes this.
  16. Jun 26, 2019 at 8:49 PM
    BayRunner
    2017 Tundra Platinum
    Had my hood vinyl done by a local shop. Said it was very easy using cutting tape to get the lines correct. Over a year now and still looks perfect.
  17. Jun 26, 2019 at 9:24 PM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    That looks good.
  18. Jun 27, 2019 at 4:29 AM
    Hand Protectors
    Since you want the hood done in vinyl, you should do the bumper as well. Makes sense to do both simultaneously.
  19. Jun 27, 2019 at 5:48 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I've had really mixed results with plasti dip. I would go vinyl as well.
  20. Jun 27, 2019 at 6:36 AM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Oh yeah I forgot about him.
    He did my TRD stickers for my bed sides for me.
  21. Jun 27, 2019 at 10:06 AM
    allibubba
    allibubba New Member
    PDX
    2003 Access Cab & 2006 Double Cab
    Level kit 33's
    I would bet the toughest part would be getting the vinyl into the shape/size you need. Wrapping the whole hood would be pretty easy, but getting things cutout without a plotter cutter would be tough.
    If you can find the shape you want, pre-cut, getting lined up on the hood should be easy. I know the 3m vinyl doesn't stick until pressure is applied, so you can position where needed.
    Hope this helps some.
  22. Jun 27, 2019 at 10:15 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    I checked with him a month or so ago and he no longer carries it
  23. Jun 27, 2019 at 12:03 PM
    BayRunner
    Don’t need to pre cut it. The professional shops use cutting tape. They basically outline the desired shape with cutting tape (tape with threads in it). They then apply the vinyl and then pull the threads to “cut” the vinyl to the desired shape.
    Darkness and Jerry311SD[OP] like this.
  24. Jun 27, 2019 at 12:56 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Did you do the roof yourself? Was it pre.cut?
  25. Jun 27, 2019 at 1:02 PM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Bought it like that
  26. Jun 27, 2019 at 1:18 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Seems to be popular among white tacomas out my way
