Best Jack for use on 2021 TRD Pro
Discussion in '2.5 Gen Tundras (2014-2021)' started by Nflguy, Apr 22, 2023.
  1. Apr 22, 2023 at 8:16 PM
    Nflguy
    Nflguy [OP] New Member
    My 2021 TRD Pro is sitting in my garage with the rear passenger side tire going flat due to a nail. I have not changed a tire in years so watched a few youtube videos. Many of them claim the jack that comes with the Tundra doesn't not work well. Looking for recommendations for a jack that is similar in size to the factory jack that comes with the Tundra TRD Pro but works as intended.
    Also on youtube there seems to be disagreement over where to place the jack when changing a tire. Some say the manual directs you to place it under the frame but many people commented that the jack wont raise the truck high enough to change the tire if you do that.
  2. Apr 22, 2023 at 9:17 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
  3. Apr 22, 2023 at 9:25 PM
    Nflguy
    I was hoping for something to keep in the truck. Since next time this happens Ill probably be in the middle of nowhere.
  4. Apr 22, 2023 at 10:21 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
  5. Apr 22, 2023 at 10:47 PM
    Sunnier
    Sunny
    San Diego, CA
    bulldog93 and Tripleconpanna like this.
  6. Apr 22, 2023 at 11:24 PM
    Tripleconpanna
    Makes sense, but... I think that was my point in that flats, etc. never happen where it's convenient or on an ideal surface. Therefore, I'd rather have something that can roll and move around in almost any surface condition, and I can adjust the lifting up to a position that requires minimal effort to get the truck moving upward. All the little scissor jacks, OE jacks, etc.. seem to provide a nice workout and just as you get to where you're starting to lift the truck, it runs out of travel and you've got to unwind the stupid thing and start over.
    It's definitely bulkier than an OE style jack, but if you can creatively secure it in the bed when you travel it's a lifesaver :thumbsup:
    Also, I agree w/your point about jacking from the frame or pumpkin, etc... I'd rather use the frame than some little 'crease of metal that is the suggested jacking point for most OE style jacks (especially on uneven or a non-solid surface).
    Hopefully, you'll find something that works for you!!!
  7. Apr 23, 2023 at 2:41 AM
    Demented Canine
    Demented Canine Hiding in the Baffles
    Extreme Southeast Georgia
    2020 MGM SR5 DC
  8. Apr 23, 2023 at 6:45 AM
    Nflguy
    Several reviews on Amazon mention a design flaw that can cause this Jack to get stuck when lowering your truck back down.
  9. Apr 23, 2023 at 6:51 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Get a "TRD pro" sticker for the factory jack and it will work just fine for your "TRD pro".
    TelemarkTumalo likes this.
  10. Apr 23, 2023 at 7:27 AM
    brown_subaru
    brown_subaru New Member
    Eastern WA
    2021 Tundra SR5 TRD
    bulldog93 and Sunnier like this.
  11. Apr 23, 2023 at 8:23 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    I carry a 6x6 block of wood plus a couple pieces of 2x6 to help. Hope I never have to find out.
  12. Apr 23, 2023 at 8:44 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    Most compact and affordable setup:
    -6 ton bottle jack (most will fit in the OEM storage)
    -hi-lift jack base/stabilizer for the dirt and sand (these are highly moddable to fit any bottle jack footprint)
    -Couple of 2x4 or 4x4 blocks of wood
    If you have an under-seat storage, this gear will be safe and hidden away. Anything else will take too much space or demand more $$.
    The powerbuilt jack+stand is nice and inexpensive, but IMHO doesn't belong inside the cab, too heavy and bulky to hide.
    bulldog93 and the red like this.
  13. Apr 23, 2023 at 8:47 AM
    Nflguy
    I mentioned that my Tundra is a TRD Pro because it comes with a factory lift. Thought the increased height might be a factor to consider.
    Sunnier and Rodtheviking like this.
  14. Apr 23, 2023 at 8:50 AM
    the red
    the red the threat is real
    New Brunswick, Canada
    Good to have. Though I must say: never hope, always test. For me, I tried to lower my spare, only to find out it was seized in place. Penetrating oil got it down, only to find out it's never been used or changed and is 10 years old (beyond the age of tire that should be used). On top of that there was no valve cap, and it's so full of crap there's no way to inflate it. Best to know ahead of time to be ready.
    Same to @Nflguy , be ready for the situation ahead of time. Good you're lucky you made it to your garage.
    sask3m[QUOTED] and bulldog93 like this.
  15. Apr 23, 2023 at 8:55 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    The little jack that comes with the truck works fine. Whatever jack you feel you need or use, I always recommend using a jack stand. I never 100% rely on just a jack.
    I'm good with the little factory jack, a few blocks of wood and a small jack stand on board. It can all be kept in a small tote and none of it is heavy. I've never had an issue changing a wheel/tire with the little jack.
    If you have giant tires and your frame is a mile off the ground or need to change tires during a Baja race, then get whatever rig you need. But you don't really need anything expensive or cumbersome to deal with a flat on the average truck.
    bulldog93 likes this.
  16. Apr 23, 2023 at 8:59 AM
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
    Do you feel better, big guy?
    itsallgood101 likes this.
  17. Apr 23, 2023 at 10:25 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Not really.
    It actually makes me sad that so many people are so sensitive and take themselves way too seriously.
    ZappBrannigan likes this.
  18. Apr 23, 2023 at 10:37 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Yeah, I was just bustin yer chops a little.
    I don't think the TRD stuff is a whole lot higher off the ground than non TRD stuff. The little stock jack will work fine with a block of wood, for fixing a flat. Or, get one of those 2-ton shop jacks. It's really just a matter of what you wanna spend and what you wanna keep onboard. I don't think there's a wrong answer.
    Either way, my biggest recommendation is using a jack stand too. I usually jack up the truck and set it back down on a jack stand before working on a wheel.
  19. Apr 23, 2023 at 4:58 PM
    Rodtheviking
    Vancouver, WA
    Sequoia
    Good for you.
  20. Apr 23, 2023 at 5:07 PM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Lotta wadded up panties around here.
  21. Apr 23, 2023 at 5:35 PM
    C.I.
    Cesar Pedrin
    Cabo, Mx
    I should have read a little more.
    However, the gear I recommended before is a fantastic setup on the move but that's it.
    Jack stands and wheel chocks are absolutely necessary for safety in any garage, newbie or pro.
    Also, don't think bottle jacks are great for frequent use, too slow, demand more maintenance (albeit easy) and typically the handle is too short.
    Rear wheels are easier to lift off the housing and require less height. Front wheels do need you to place the jack on the frame.
    Of you don't plan on wrenching on your own vehicle, the minimalist kit will do just fine for flats.
