Best projector headlight upgrade for night driving?
Discussion in 'Lighting' started by Pokesholes, Mar 8, 2021.
  1. Mar 8, 2021 at 7:23 AM
    Pokesholes
    Pokesholes [OP] New Member
    2015 Tundra CrewMax Limited
    Greetings,
    New to the forum.
    I have a 2015 Crew Max limited, and the illumination at night is poor. I installed some LED bulbs, but they're almost worse.
    I have terrible night vision, so I'm after the best illumination I can get.
    Any recommendations are greatly appreciated.
    Thank you.
  2. Mar 8, 2021 at 7:27 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    It's going to be HID or LED. Complete game changer. New bulbs and the outdated projector are a lipstick on a pig phenomenon. Best to get a whole new assembly. OEM, Morimoto,etc. Oh and welcome aboard!
  3. Mar 8, 2021 at 7:34 AM
    Willard
    Willard New Member
    2024 F250
    Swapping to LED bulbs is almost always worse than the original halogens because the reflectors are designed to focus a tiny single point light source. LEDs have a larger die size or multiple diodes, which results in a much larger, uncontrolled beam pattern. It's much like a flashlight with high lumen output but low candela, meaning it's not focused.
    For a 2015 you should take a look at getting the OEM LED headlights, plus a wiring harness from iHacker (a member on this forum). Here is a link to the thread about his wiring harnesses: https://www.tundras.com/threads/201...lay-harness-for-2014-2020-models-v-2-0.24416/. Don't bother with any other harnesses on the market.
    For the headlights you'll want the 81110-0C211 and 81150-0C211 (TRD Pro LED gloss black housings).
    Some people may suggest the morimoto xb headlights but if you do a little searching they have a lot of problems, cost WAY more, and while the low beams have slightly higher candela than the OEM LEDs, nothing compares to the performance of the OEM LEDs for high beams. The OEM LEDs offer much better performance over the halogens, as well.
  4. Mar 8, 2021 at 8:35 AM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Yup, OEM LEDs is the way to go. I did Led bulbs and xenon retrofit, but both were terrible experience. Retrofit "expert" did really crappy job, so after $600 and my original lights had to be thrown out, i bought OEM LED headlights through @Roman and couldn't be happier
  5. Mar 8, 2021 at 8:52 AM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    I've done the morimoto projector retrofit route on other vehicles and picked their full enclosure over the oem headlights this time. I wanted a fully sealed led enclosure and preferred the look. The light spread and cutoff are better for what I need (close to the truck visibility 35-50 mph driving) . The oem does have better high beams cutoff. I was adding the nsv bar at the same time and that completely obliterates the high beam.
    There are sales right now and also look for scratch and dent housings - significant savings.
    ackthresher, xdmelarton and 300BLK like this.
  6. Mar 8, 2021 at 9:40 AM
    Mcoop
    Mcoop Throbbing Member
    Michael
    Berlin, NJ
    2015 Black SR5 5.7L DCLB 4x4
  7. Mar 8, 2021 at 9:49 AM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    Pokesholes, I had fantastic luck and experience with installing LED replacement bulbs in my 2016 Tacoma.
    Ive learned that 'the lamp you buy makes it or breaks it'
    I just replaced a set of H11 bulbs in a 2016 Highlander with these bulbs and they worked fantastic just like my Tacoma.
    https://www.amazon.com/gp/product/B07GWF2JXZ/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8
    For less then $30.00 you can brighten your nite vision and you can "dial them in" as they are adjustable to emulate the flat top of the beam that your projecting. I can tell you that i did not have to adjust or change either the Tacoma or the Highlander position, just plug and play.
    RdKing
