Best rear lift for 2008 tundra?
Discussion in 'Suspension' started by BrownTundra323, May 5, 2024.
  1. May 5, 2024 at 6:28 AM
    BrownTundra323
    BrownTundra323 [OP] New Member
    Jack
    2008 4.0l Tundra
    Just curious in what you guys think are the best way to go for a rear lift on these trucks. My truck is currently lifted 3 inches in the front and 1 inch in the rear with spacers to clear 34" tires. It rides like crap and after a while with this setup, I will be swapping this over to Bilstein 6112s up front with JBA upper control arms, and Bilstein 5160s in the rear. Should I leave the block in the rear to keep the truck level, or should I go with a shackle lift? Or would it be better to just do new leaf springs entirely, with new bushings in the rear? My truck is also 2wd for reference, and I want this suspension setup to feel like a new truck. Thanks in advance, and let me know if you guys have any other recommendations on suspension setups for the truck.
  2. May 5, 2024 at 6:35 AM
    2mchfun
    New Dobison's leaf packs, and some extended bump stops, maybe Timbren. Ironman 4x4 greasable shackles and bushings. A brake line relocate kit and a driveshaft drop spacer kit if not already installed.
  3. May 6, 2024 at 3:22 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    If you're 2WD and your truck is the same as your bio (4.0L) engine I don't think that I would go with Bilstein 6112s. Let me be clear... I love 6112s, and recommend them often! That said, I fear that you won't have enough weight to engage the spring, and as a result will feel as though you're riding atop the spring resulting in a quite firm ride. My recommendation would probably to be to go with something like the Eibach Pro truck Stage 2 or 2R kits. Those kits are valved slightly softer than Bilsteins anyway. Also, they have the same diameter spring top to bottom so if you needed to step down in spring rate a touch to get the ride comfort you could step down to a 600# spring and adjust the preload collar for your ride height.
    Happy to help you work through things over here at Hotshot Offroad as well. Shoot me a message or give me a buzz at 406-936-0206.
