Best rotors if you live in the mountains?
Discussion in '1st Gen Tundras (2000-2006)' started by mtnhaul, Oct 31, 2022.
  1. Oct 31, 2022 at 8:41 AM
    mtnhaul
    mtnhaul [OP] New Member
    2003 Access Cab 4.7v8 4x4 TRD
    Well it's time for new front rotors, but which ones? I live in the mountains and inevitably put a lot of wear and tear on brakes. No towing or heavy loads but lots of extended downhill trips with lots of braking. I don't mind spending more upfront if the rotors last a lot longer, but even then there is a point where it's cheaper to buy econo parts and plan on replacing them sooner--brakes are easy. Basically there are too many choices and more than a few opinions out there that contradict one another. I would appreciate it if someone could recommend a good rotor/pad setup for mountain driving and weather.
  2. Oct 31, 2022 at 8:59 AM
    Standard store brands often trigger complaints on here about being out-of-round, introducing shimmy/vibrations.
    OEM is always a win, as much as I know many people hate to hear it, but you pay a little more, it works as intended from the factory.
    I swear there's a couple of owners here successfully running PowerStop stuff, but it's spendy, not sure how much more so than OEM.
  3. Oct 31, 2022 at 9:00 AM
    Not a rotor recommendation beyond the stock ones that I have had good luck with, but using tow / haul in the mountains helps with down hill engine braking which will save your pads and rotors. I rarely need to ride the brakes, even when towing my large travel trailer. 6ok miles on mine with factory rotors and pads with no shudder or warping.
    Toyotadoug likes this.
  4. Oct 31, 2022 at 9:05 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Lol
    pads and rotors are cheap.....thats why.
    terrward and shifty` like this.
  5. Oct 31, 2022 at 9:07 AM
    Danimal86
    Daniel
    Sacramento, CA
    I gave cryo treated rotors a try. I had heard that they do much better at not warping and wearing unevenly. I've got about 1k miles on a set of Frozen Rotors and Hawk Green pads and its very noticeable difference much more confident stopping power.
  6. Oct 31, 2022 at 9:09 AM
    Danimal86
    Daniel
    Sacramento, CA
    Jack McCarthy likes this.
  7. Oct 31, 2022 at 9:09 AM
    Is engine braking expensive? Overheating your brakes to the point of warping means your overheating them to the point of fade likely, which is dangerous. Using engine braking to help control your downhill runs is much safer. And standard for people who tow and haul.
  8. Oct 31, 2022 at 9:13 AM
    Aaaaaaand this is why 1st gen makes fun of people who drive the other gens. It's pretty difficult to have an adult conversation about brakes, I guess. Somehow we get my just fine over here in 1st Gen w/o all the sarcasm and back & forth.
    txagg, richsadams, bmf4069 and 3 others like this.
  9. Oct 31, 2022 at 9:18 AM
    Danimal86
    Daniel
    Sacramento, CA
    This is the last that i'll say on the matter....My factory pads/rotors had about 25k miles on them before they wore unevenly and shook everything, i chose Frozen Rotors based on Keith from DirtyDeeds' recommendation (write up over on TundraTalk) but opted with Hawk Green's since its what Frozen Rotors recommended for heavy towing.
    Large increase in stopping power and overall grip. Will they last longer than factory rotors? Time will tell.
    richsadams and WILLINH like this.
  10. Oct 31, 2022 at 9:19 AM
    There's a lot of sense out there these days. It's not exactly common, though...
  11. Oct 31, 2022 at 1:17 PM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    OP, I've had good luck with PowerStop brakes and use them on all my vehicles. Have you thought about doing the GX460 Brake upgrade? I've done the upgrade and I love it!
    Riverdale21 and richsadams like this.
  12. Oct 31, 2022 at 1:22 PM
    Depending on what year OP's truck is, it may not be the best. Just look at what happened to @FirstGenVol :rofl:
    If OP is in an older truck, it's probably worth just doing a bolt-on no-machining-required upgrade like the 13WL.
  13. Oct 31, 2022 at 1:27 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I've put EBC drilled/slotted on everything. OEM rotors warp quickly in my experience, regardless how much engine braking you do (and I grew up in the mountains so do that plenty). Lots of flat landers commenting and butthurt that corners are a thing that require braking :rofl:
    shifty` likes this.
  14. Oct 31, 2022 at 1:31 PM
    2006Tundra
    Lou
    Long Beach, CA
    Poor guy @FirstGenVol
  15. Oct 31, 2022 at 2:53 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I finally fixed my brakes by getting rid of the GX460 calipers!! 13WL's are working fine for me.
    I agree with others on engine braking. When I'm leaving the mountains I gate shift between 1st and 2nd.
  16. Oct 31, 2022 at 3:18 PM
    citrusmaster
    citrusmaster New Member
    Tielar
    2015 Tundra RCLB
    I have run powerstop stuff in multiple vehicles including my Tundra.. It's pretty decent. I haven't had any issues with it getting warped or anything, but I don't live in mountains.The main benefit to me was how cheap it was. In the Tundy I can't tell any difference between it and OEM, but I didn't buy their most expensive package either.
    From the trips to colorado mountains I have had, cooling was my biggest issue. drilled and slotted will help with that. Engine braking will also help, but it doesn't remove the need for better brakes entirely.
    If I were you I'd try drilled and slotted. If they don't last longer, just use cheaper powerstop stuff and replace them regularly.
  17. Nov 1, 2022 at 6:30 AM
    mtnhaul
    Really:rolleyes:? With 258k on my transmission I would much rather keep the bulk of the braking load on my brakes as it's much cheaper and easier to replace rotors and pads than a transmission. And yeah, I do downshift in my other truck with a 5spd and I hardly ever need to touch the brakes--automatics kinda' suck in my opinion but I'll take what I can get with a Tundra(I didn't want a V6 Tundra with the 5spd option). And good call on the drilled/slotted rotors possibly getting debris stuck in them--I hadn't thought about that.
    I agree that engine braking is the better way to go down a hill but I am a bit worried about unnecessary wear and tear on the transmission. Since I do drive through a lot of rock and gravel it sounds like OEM or at least OEM style makes the most sense. Maybe look into those cryo rotors. Thanks for the 13WL suggestions. I'll see if my old buddy at the local dealership can get me a deal on some parts.
    I like how people assume I must've been riding the brakes like an idiot. I only recently acquired this 2003 Tundra with 258k on the clock and the rotors were slightly warped at purchase but the price was right and I would rather buy something that needs a few things so I can fix 'em right or hopefully upgrade them myself. It seems there's little the factory does that can't be improved upon later. Thanks for the replies one and all, much appreciated.
    shifty` likes this.
  18. Nov 1, 2022 at 6:36 AM
    Good luck with the brake search, these trucks are notorious for warping issues and I imagine the extending downhill braking runs would exacerbate this, regardless of brake brand. These trucks are not notorious for transmission or engine failures however and I would not hesitate to use engine braking to help with these downhill runs. Many years on Toyota Tundra forums including this one and I have yet to read about a catastrophic engine or trans failure rolling downhill.
    txagg, mtnhaul[OP] and FirstGenVol like this.
  19. Nov 1, 2022 at 6:39 AM
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    I have used StopTech for the past 2 years and I have had zero problems. I go offroading a lot and have tested them on a downhill that lasted almost an hour.
    mtnhaul[OP] likes this.
  20. Nov 1, 2022 at 6:42 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    I used these Centric rotors with some Akebono ASP976 pads back in March and have put about 7K miles on them. So far they have held up well and braking performance is smooth. My previous rotors were pulsing during braking but I didn't want to shell out for new Toyota rotors or deal with having the originals turned.
  21. Nov 1, 2022 at 6:46 AM
    mtnhaul
    I wasn't worried the trans would literally fail just from rolling downhill, but I do remember after paying a lot of money to rebuild the trans on my first truck I asked the mechanic about using the trans for braking and all he did was remind me how much I just spent on the trans and how relatively cheap pads and rotors are. I probably have an unfair opinion of automatics because the only other one I've owned was a piece of sumpin' and cost me a lot.
    shifty` likes this.
  22. Nov 1, 2022 at 7:36 AM
    You can't necessarily blame them, if you saw some of the shit people come and post here, some of the stories we've read, you'd understand :rofl:
    Let's just say we have a lot of fly-by-night, one-and-done types show up with problems, get advice, then disappear without sharing whether it fixed their problem. I'd say that's about half the posts we see in the 1st Gen forum.
    A lot of brake performance in these trucks is actually tied to the rear drums. If the previous owner swapped out the drums with standard store brands, it may actually be the drums that are causing the pulsing, not the rotors. It's a mistaken conclusion many before you have made, much to their disbelief. You'd be shocked at how many braking quirks have been solved by refreshing and/or properly adjusting the rears.
    If you're braking a lot, there's no reason you shouldn't inspect the drums, consider pulling and running to a shop to have them checked for out-of-round-ness (wtf is the word for that? my brain isn't working again today...) in case that's your actual culprit. Or if they look like the originals, consider replacing those first, then checking to see if it solves your probs BEFORE you dump money in the front.
    flyfisher and richsadams like this.
  23. Nov 1, 2022 at 7:59 AM
    CTundraForMe
    CTundraForMe New Member
    I'm not sure "notorious warping" is fair. I suspect a good portion of the warping comes from over tightening the lug nuts. Search around...
    I'm also in the "brakes are cheaper than a new transmission" crowd. That doesn't mean I recommend riding the brakes until they overheat and you crash. I mean don't ride the transmission the entire way: use both as appropriate.
  24. Nov 1, 2022 at 10:55 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I have an 03 and put Stoptech slotted rotors on with toyota pads. They work great. I've heard arguments both ways on drilled and slotted. Slotted made the most sense to me and I haven't had any issues with dirt or debris getting stuck.
    des2mtn likes this.
  25. Nov 1, 2022 at 3:54 PM
    Aerindel
    Aerindel New Member
    Montana
    I've never heard ANY argument for drilled or slotted that wasn't just marketing speak. Physics is agains both, which is a pretty convincing argument for me. Holes reduce the air cooling effect from the centrifugal pump, and both reduce the brake surface area and mass giving you effectively smaller brakes for the same diameter of disc.
    They look 'cool' though which I guess is worth it for most people. And the reduction in braking efficiency from drilled and or slotted is small enough most people won't notice it.
    Mr.bee likes this.
  26. Nov 1, 2022 at 4:13 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    The original reason for cross drilled was: off gassing of older pads, wet performance and less unsprung weight.
    Slotted takes care of 1 & 2, without the cracking cross drilled tends to end up with.
    With modern pads and not on a wet race track? Standard rotors are fine. Slotted if you're in a very wet area and tend to coat your rotors in water through large puddles.
  27. Nov 1, 2022 at 4:23 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Brakes are for cowards, stuff your feet through the floorboards and stop like a man.
    txagg, bmf4069, artsr2002 and 4 others like this.
