Best Speed for Best Mileage
Discussion in '1st Gen Tundras (2000-2006)' started by evanhmn, Aug 10, 2021.
  1. Aug 10, 2021 at 7:49 PM
    evanhmn
    evanhmn [OP] mmm chicken pot pie
    State of Taxes
    2001 TRD Off-Road AC 4x4 Limited in Black
    5100/2885s, 1.5" Add-Leaf, BFF Front Bumper, 265/70/17 KO2s
    As the title says; I’m looking what speed others drive at(on freeway/highway) for the best mileage. Gonna be doing long stretches for a few days and want to set my cruise control to the best speed for mileage.
    Thanks.
    Rsmallw2 likes this.
  2. Aug 10, 2021 at 7:53 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    If there are any hills, even slight ones, cruise will eat your milage. Tundra seems happiest between 60-65. I kick it out of overdrive on hills under 60.
    Saltyhero13 likes this.
  3. Aug 10, 2021 at 7:57 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    Just fast enough to shift into overdrive and lock the torque converter. Not sure what that speed is on a 1st gen, maybe 45mph.
    avgguy likes this.
  4. Aug 10, 2021 at 8:59 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    55 mph or so. Accelerate slowly, get off the gas and use the brakes as little as possible, reduce massive efficiency losses to wind resistance above 60 mph, remove any racks or gear on the roof. Most important, delete any lift. Lifts kill mileage. Add a front air dam. Visit:https://ecomodder.com/
    KNABORES likes this.
  5. Aug 10, 2021 at 9:03 PM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    Delete any lifts? I'm out!
  6. Aug 10, 2021 at 9:06 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Make sure your tires are not low on psi.
  7. Aug 10, 2021 at 9:59 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
  8. Aug 10, 2021 at 10:24 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Is the rpm that count
  9. Aug 10, 2021 at 10:26 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The cruise control comment was dead on. On my 2005 the cruise control would cost up to 3 mpg unless you were on dead flat highway
    Darkness likes this.
  10. Aug 10, 2021 at 10:34 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    65mph.
    Best mpg is at 45mph.
    Mileage steadily declines as speed increases due to wind resistance.
  11. Aug 10, 2021 at 10:40 PM
    snomoman
    snomoman New Member
    North Aurora, IL
    2020 Cement SR5 4WD Tundra
    Bed liner, truxedo tonneau cover, Westin step rails, cover king seat covers
    I have been able to get 18+ miles per gallon keeping it at 72 miles an hour and under 2000 RPMs with the cruise control on, obviously in Flatland Illinois
    HBTundra likes this.
  12. Aug 10, 2021 at 10:40 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Any speed you want...
    Welcome to the forum..:thumbsup:
  13. Aug 10, 2021 at 11:02 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Please don’t drive 45 on the interstate
    TTund16, Siebler, jimf909 and 3 others like this.
  14. Aug 10, 2021 at 11:09 PM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
  15. Aug 11, 2021 at 5:23 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    My truck does really well around 55-60mph. I'm carrying a ton of extra weight and last year I was able to get over 17mpg coming back from the beach.
  16. Aug 11, 2021 at 6:54 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    There isn't really a right answer to this. Follow the speed limit and you'll be fine.
  17. Aug 11, 2021 at 7:24 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Speed limit on flat, 80mph downhill so you don’t have to shift gear or give it hella gas to go back uphill
  18. Aug 11, 2021 at 7:37 AM
  19. Aug 11, 2021 at 7:53 AM
    2mchfun
    Can you rent or borrow a car from a friend? A friend might like to drive your truck for a few days too, I would even give them free gas in the truck, return the car full and pay for an oil change. Maybe more depending on savings, no need to give all to oil companies.
  20. Aug 11, 2021 at 8:02 AM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
  21. Aug 11, 2021 at 9:20 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    40-45 mph I get the best mileage on back roads. Unfortunately stop signs and slowing down for intersections tend to defeat that gain in mileage.
  22. Jun 8, 2022 at 9:07 AM
    Toze’s Tundra
    Toze’s Tundra New Member
    Joe
    Boston
    2010 Tundra Limited
    Oiled to last!
    Funny you say that, I take mine annually to get oil undercoated and it’s on file as a Toyota Prius.
    evanhmn[OP] likes this.
  23. Jun 8, 2022 at 12:16 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    You can feather the throttle above 55. Once you drop under 55 gotta kill OD. 3rd is good until almost 60.
  24. Jun 9, 2022 at 5:41 AM
    avgguy
    avgguy New Member
    Craig
    2000 Tundra 274K Original
    When I first bought Tundra I drove across Western N.C. and set cruise around 62-63 mph and got 22.0 mpg and didn't believe it and followed that up with 21.5. Literally drove it like egg is under gas pedal. Hasn't happened since; just can't drive that slow on highway, even now.
  25. Jun 10, 2022 at 12:25 AM
    jwarren2
    jwarren2 New Member
    James
    Sugar Land Texas
    2014 Black Tundra Platinum 4x4
    None yet but making a list and looking at the budget.....
    I always try and keep my rpm's under 2k. I actually can see the MPG going up when doing this. Along with not running it in cruise control.
    avgguy and evanhmn[OP] like this.
