Best Stainless Steel Cleaner For Exhaust Pipes?
Discussion in 'Detailing' started by d_kinneyjr, Dec 22, 2021.
  1. Dec 22, 2021 at 11:00 AM
    d_kinneyjr
    d_kinneyjr [OP] New Member
    Dave
    Southern NH
    2018 Crew Max SR5
    Looking to see if anyone can recommend a good product for cleaning exhaust pipes. Just purchased the MagnaFlow Street Series Cat-Back Performance Exhaust System from @JeffMac out of the Market Place yesterday. I would like to clean up the pipes as well as the tips before i install it on the truck. The parts I am looking to clean are mostly all Stainless Steel. Thanks in advance for your help.
    JeffMac likes this.
  2. Dec 22, 2021 at 11:10 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Scotch brite pad
    d_kinneyjr[OP] and 2mchfun like this.
  3. Dec 22, 2021 at 12:13 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    ditto above and some dawn soap, but the pads will make some marks. Other than that you could use stainless steel cleaner, like for appliances, grills, etc and a microfiber towel to avoid scratches.
    If is it really nasty, could also try oven cleaner, but dont let that sit too long.
    d_kinneyjr[OP] likes this.
  4. Dec 22, 2021 at 12:41 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I put some brasso on my bassani pipes and thought it did well, the muffler and tips polished fair, but the pipes didnt really. Mofthers mag/aluminum works for the tips when i wash the truck, but its not something i do every time.
    thought i had a pic, but i dont.
  5. Dec 22, 2021 at 6:28 PM
    briarpatch
    briarpatch New Member
    P21S polishing soap. I use it for exhaust tips, as well as the stainless range hood in my kitchen.
  6. Dec 22, 2021 at 8:42 PM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    I like Never Dull… an old school fireman showed me early in my career and it works for me
  7. Dec 27, 2021 at 5:47 AM
    Supratuntaco
    Supratuntaco New Member
    Canada
    2022 Tundra Trd Pro
    Do you know what grade of stainless steel it is ? Will it hold a magnet ?
  8. Dec 27, 2021 at 6:09 AM
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    Are you trying to clean dirt and grime or surface rust?
    FrenchToasty likes this.
  9. Jan 3, 2022 at 9:27 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    'Flitz' Brand metal Polish is a really good one . . . so is 'Simichrome' which is made in germany . . . those are the 2 best that I have found.
  10. Jan 3, 2022 at 9:52 AM
    d_kinneyjr
    Dave
    Southern NH
    2018 Crew Max SR5
    Both actually. There's a lot of dirty and grime, but there are also some spots of surface rust
    I do not know, I will have to try out your magnet theory
    I did happen to buy some of the Brasso polish. I will report back and let everyone know how it did. Just waiting for a little warmer weather here in the North East.
  11. Jan 3, 2022 at 9:56 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Hard to go wrong with Flitz . . . it's food grade (if that means anything), and if I remember correctly (at the time) it was the only polish recommended by Smith & Wesson to remove oxidation/rust safely from their 'Blue'd' barrels. Hard to mess anything up with it, but it still really works good.
  12. Jan 3, 2022 at 10:08 AM
    MoToad
    MoToad New Member
    Toad
    BC Kanuckistan
    2009 Tundra DLX
    Barkeepers Friend? Works great inside. Prolly outside too.
  13. Jan 9, 2022 at 8:11 PM
    Supratuntaco
    Canada
    2022 Tundra Trd Pro
    I was a Welder for quite a few years in another lifetime lol.
    If it's 304 Stainless Steel it's non ferrous and much stronger, less prone to scratches and more chemical resistant. 409 Stainless steel won't last as long as 304. You shouldn't use any harsh chemicals or abrasive on either. There's lots of other types too. Some exhausts have a coating on them such as aluminized steel or Zinc.
    See if you can find out what it's made of then look up the best way to look after it.
    You should also never use anything that you previously used on Ferrous Steel as you can impregnate the Stainless with more Iron and cause it to rust. I mean like sandpaper, emery cloth or grinding wheels etc. Unless you're cutting or modifying it you probably wouldn't do that anyways.
  14. Jan 9, 2022 at 8:51 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    It's 409
  15. Jan 12, 2022 at 9:09 PM
    peeps
    peeps New Member
    Sheila Shine.
