BFG ko2 on stock 20 inch rim
Discussion in 'Wheels & Tires' started by Frankstb, Jan 16, 2021.
  1. Jan 16, 2021 at 5:48 PM
    Frankstb
    Frankstb [OP] New Member
    2018 Silver Limited 4WD
    RC 1.75” leveling kit BFG K2s 275/60/20
    There is so much info out there and hope someone has my set up to determine best BFG tire size. I have a 18 tundra with stock 20 inch rims and a 1.75 inch rough country leveling kit on the front. What is the best BFG tire size I can use with this set up. Will a 285/60 work? Sincerely thanks for any advise!
  2. Jan 16, 2021 at 5:52 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    I recall seeing on the rough country site that you can do 285 65, maybe even 70 with that kit.
    I been thinking about the 1.75" kit myself though I dont know if I would go 285 since they are more expensive than the 275. Plus the mpg hit.
  3. Jan 16, 2021 at 5:59 PM
    Frankstb
    I saw a set of 285/60 on a gmc A/T and they looked dang good! Not sure about the diff in a 275 and 285 on gas mileage? I wonder if the rim width is the same on the 20 inch tundra rim and the 20 inch GMC A/T rim?
  4. Jan 16, 2021 at 9:32 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
