BFGoodrich HD Terrain - 15k mile update
Discussion in 'Wheels & Tires' started by AZBoatHauler, Mar 7, 2024.
  1. Mar 7, 2024 at 8:19 AM
    AZBoatHauler
    AZBoatHauler [OP] SSEM#140 / 2.5 gen plebe
    So.Arizona
    FrenchToasty and 2mchfun like this.
  2. Mar 7, 2024 at 8:23 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Haven’t seen them before. Almost like an old mud terrain. I wonder how loud they are.
    AZBoatHauler[OP] likes this.
  3. Mar 7, 2024 at 8:29 AM
    centex
    centex New Member
    Website doesn't give much detail but something tells me it's very heavy and way overkill for anything these trucks are meant or will do. It's marketed specifically towards HD trucks and off road construction jobs so it's probably a high ply count which makes for a stiff ride.
    Tom likes this.
  4. Mar 7, 2024 at 8:36 AM
    AZBoatHauler
    So.Arizona
    Not really. This is what I’m running currently-
    Here are the specs on these BFGs
    My truck also weighs 7,000 empty so I’m in HD truck weight territory all the time…
  5. Mar 7, 2024 at 8:43 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    In the late 90’s we had mud terrains on a few select broncos. Aired down, they were incredible in the desert. They were loud on road but we kept them in the dirt at night. Great tire.
  6. Mar 7, 2024 at 9:31 AM
    redrdr67
    redrdr67 New Member
    2007 White Tundra RCSB 2wd
    Good looking tire IMO. Looks to be a cross between their mud terrain and all terrain. Appears a lot of tire manufacturers are doing the same. Looking forward to some reviews.
  7. Mar 7, 2024 at 10:30 AM
    centex
    centex New Member
    That’s actually better than I thought. Interesting.
  8. Mar 7, 2024 at 11:00 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    I've been curious about these, too. Only guessing, but thinking the rubber compound might be hard, which is great for a long lasting tire, not so great for off-road traction.
  9. Mar 7, 2024 at 11:05 AM
    boatsnbikes
    boatsnbikes New Member
    First I’ve seen of these but they look very similar to cooper rugged treks. I have those on an f250 and they are great on and off road. They make a little noise but not even close to an actual mud tire
  10. Mar 7, 2024 at 11:06 AM
    2mchfun
    Had them once before on an SUV. Just found a good deal on a gently used set and figured why not. They were great, wore like iron. Been thinking about a set for my truck, but they are really heavy compared to other good options. Time will tell.
    AZBoatHauler[OP] and BillyB like this.
  11. Mar 7, 2024 at 11:07 AM
    2mchfun
    Yep, the set I had were very hard.
  12. Mar 7, 2024 at 11:08 AM
    AZBoatHauler
    So.Arizona
    Question is at 15 psi and 7400 lbs on them will it matter?
    BillyB[QUOTED] and 2mchfun like this.
  13. Mar 7, 2024 at 11:08 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    Good point
    2mchfun likes this.
  14. Mar 7, 2024 at 11:40 AM
    AZBoatHauler
    So.Arizona
    The Nitto RGs the same size weigh 2lbs more…
    :monocle:
    BillyB and 2mchfun like this.
  15. Mar 7, 2024 at 12:28 PM
    2mchfun
    Well hell, I had a set of these and a set of Yokohama Go15 both in my Amazon cart for about the last two weeks for comparison. Same size 285/75 18. I was looking at the weights about 10 days ago and these were listed at about 68 and the Yoko's were listed at around 35 ish. Since I'm really happy with the Yoko's and saw the substantial weight difference, I was thinking maybe best just to get the Yoko's again. Now, that you said the Nitto's are heavier, I just checked two other sites and I'm quite pleased to discover that there's not a huge difference between these and the Yoko's. Damn Amazon!!! I should have known! I'm very happy to be back in this camp, thanks!
    BillyB and AZBoatHauler[OP] like this.
  16. Mar 8, 2024 at 1:53 PM
    AZBoatHauler
    So.Arizona
    I’ll be able to give some initial feedback on these tomorrow.
    :spending:
    g6t9ed, des2mtn, redrdr67 and 3 others like this.
  17. Mar 9, 2024 at 3:29 PM
    AZBoatHauler
    So.Arizona
    First impression - very happy with the tires after the first ten miles. They look like they belong on a Humvee but are not roaring down the road. I’ll update more when I get some miles on them. Starting at 38 psi.
    Wrongside, g6t9ed, OHwendTrd and 11 others like this.
  18. Mar 9, 2024 at 3:50 PM
    2mchfun
    That truck is looking good and very capable with that new armor and shoes. Very sweeet! Any plans for tow mirrors?
  19. Mar 9, 2024 at 3:59 PM
    AZBoatHauler
    So.Arizona
    No plan for bigger mirrors at the moment - I bash these small ones on the trail plenty. @TRDFerguson can confirm.
    2mchfun[QUOTED] and TRDFerguson like this.
  20. Mar 9, 2024 at 4:24 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Those look great. I like BFG tires but I'm going to give Falken a try next.
    Does the sun in Arizona tend to kill your tires before miles?
  21. Mar 9, 2024 at 4:42 PM
    2mchfun
    Good point on the UV, Starbrite marine protectant is my usual weapon against the ☀️. Usually hit my tires with a heavy spray about once every 8-10 weeks and they hold up well.
  22. Mar 9, 2024 at 5:54 PM
    redrdr67
    redrdr67 New Member
    Thanks for sharing. Definitely a good looking tire. Especially on a Tundra
    2mchfun and AZBoatHauler[OP] like this.
  23. Mar 9, 2024 at 6:54 PM
    AZBoatHauler
    So.Arizona
    5-6 years and they’re heavily cracked has been my experience. I’ve only been getting 30k miles a set which is about 2.5 years of driving for me.
    2mchfun and BillyB like this.
  24. Mar 9, 2024 at 7:07 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    My tires have been installed since 2019 and still have 7/32 tread left but they aren't great in the rain anymore and they are getting loud. I'm considering replacing them. It sucks how much tires are now.
    In 2019 I paid $180/tire for KO2's. They are now 75% more. Over $300 per tire.
  25. Mar 10, 2024 at 7:20 AM
    AZBoatHauler
    So.Arizona
    Did a 100 miles round trip up to 9,000 ft on Mt Lemmon and put them through some snow. Traction, feel, handling are all improved over the Nitto. Never spun a tire. Under 50mph noise is comparable - these hum a little more over 55mph than the Ridge Graps.
    No issues with acceleration or braking - excited to get them in the dirt eventually.
  26. Mar 12, 2024 at 9:39 AM
    AZBoatHauler
    So.Arizona
    Got them on the interstate for the first time. Handling/balance seems really good, tracks nice. Over 60 the tires get progressively louder. To be expected with the tread pattern but almost mud terrain road noise on the freeway. Still love them but maybe a consideration if you daily the interstate.
  27. Mar 12, 2024 at 2:59 PM
    AZBoatHauler
    So.Arizona
    Mileage didn’t seem to take a hit - topped off after burning half a tank - 207 miles according to the trip odo, 224 when you account for the increased tires size - ended up at 14mpg hand calc - trip computer said 13.0 which is dead on if you use the 207 miles the truck thought it went.
  28. Jun 22, 2024 at 5:54 PM
    AZBoatHauler
    So.Arizona
    Almost 4,000 miles on these now - took them in for a balance and rotation. These will get the ultimate test in Moab next weekend.
    redrdr67, 2mchfun, BillyB and 4 others like this.
  29. Jun 22, 2024 at 6:15 PM
    biebs96
    PA
    definitely the perfect size tire for these trucks.
  30. Jun 22, 2024 at 7:04 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I see a hard decision between these and the Toyo RT Trail I've been considering. Both close. I'd like to see a bit more
    siping on the tread. Both a solid heavy E rated tire and tread design is good on these, I like it.
    Curious to see how they work in Moab, but seriously would rather see them on wet rocks of the west coast
    not the grippy slickrock.
    2mchfun likes this.
