Bigger mudflaps?
Discussion in '3rd Gen Tundras (2022+)' started by Max713, Oct 9, 2022.
  1. Oct 9, 2022 at 2:20 PM
    Max713
    Max713 [OP] New Member
    Anyone running different mudflaps? These things are tiny…
    I don’t need semi-truck flaps but something with a little more coverage would be cool. I run a lot of gravel, and 1” spacers with 35’s is going to eat up the side of the truck.
  2. Oct 9, 2022 at 2:22 PM
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    Not sure about mud flaps but some GoRhino RB20 side steps will help a lot
  3. Oct 9, 2022 at 3:20 PM
    ToyoMon
    ToyoMon New Member
    2022 White Tundra SR5
    Black widow TRD likes this.
  4. Oct 9, 2022 at 5:00 PM
    Tsm503
    2021 DC SR5
    Got pics?
  5. Oct 9, 2022 at 8:22 PM
    ToyoMon
    ToyoMon New Member
    Pic 2 shows the front flap, and the holes needed. The rear flap's screw on the inside wasn't back there, so it's just clipped on with the 3 outside screws for now.
    Pic 3 you can see a little mud does still hit the body about a foot behind the flaps.
    Screenshot_20221009-200326_Gallery.jpg Screenshot_20221009-200341_Gallery.jpg Screenshot_20221009-201043_Gallery.jpg
    t300 likes this.
  6. Oct 10, 2022 at 7:48 AM
    21CGtundra
    21CGtundra New Member
    Robbie
    SLC, UT
    2022 Midnight Black Tundra SR5
    2" front level, 1" Cornfed rear spacer, Rally Armor flaps, Method Con-6 wheels, 285/75 Duratrac
    I also have the rallyarmor flaps. I think they look good on these trucks. I've had mine on since March as well. One thing I did (cause it drove me nuts) was reshaped the rear bedside support to sit square with the wheel well opening so it wasn't twisted in relation to the tire. I'll be upgrading to the urethane ones before winter. I also ended up lowering my fronts after my 2" level so they better match my rears.
    Yaboy and ToyoMon like this.
  7. Oct 10, 2022 at 7:52 AM
    Max713
    These look awesome, going to order a set of the urethane ones now.
    How was the install?
  8. Oct 10, 2022 at 8:55 AM
    21CGtundra
    Robbie
    SLC, UT
    Install wasn't bad. I held one flap in the position I liked and rubbed it against the top bolt head to make a small impression in the plastic. I then drilled a hole there and hung the flap from the top bolt. I then positioned the flap in the right vertical alignment and rubbed the other bolt heads on the flap as I swung it back and forth slightly. This gives you an idea of where the other bolts will be. Then I drilled a whole and "slotted" them sideways so I have some adjustability. Once I got that flap in a good position I removed it and laid it over the other side and then traced the holes in the other flap. Kind of trial and error but if you get that first hole where you want it the other holes are fairly easy to mark out.
    Hadelson and Max713[OP] like this.
  9. Oct 10, 2022 at 6:43 PM
    Carolina Peej
    Carolina Peej Hey can you hold the light for me real quick?
    North and South Carolina
    2022 Midnight Black Metallic 4x4 Tundra Platinum 5.5 w/ load leveling + AVS, HUD, and Power Running Boards
  10. Oct 11, 2022 at 7:24 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
  11. Mar 26, 2023 at 10:05 AM
    pawner
    pawner New Member
    Chattanooga, TN
    2022 Tundra Limited with Leer 100XR
  12. Mar 26, 2023 at 2:40 PM
    lesh234
    lesh234 New Member
    Thanks
  13. Mar 26, 2023 at 5:32 PM
    charliep
    charliep New Member
    2022 Lunar Rock Tundra TRD
    RC lifted struts, RC MC1 rear shocks, 295/70/18 Wildpeak AT3, TRD performance air filters, Flipbak bed cover.
    Glad to see this! Running a slightly larger tire and wider rim the factory mud flaps are essentially useless. Again tired of the back of my pant leg getting dirty. Surely will look into these, just wish they were mounded and contoured.
  14. Mar 27, 2023 at 4:58 AM
    nodak67
    nodak67 New Member
    JR
    weather tech has the no drill ones for the tundra supposedly.
    those reds are nice but dam that price :)
  15. Mar 27, 2023 at 6:30 PM
    ChrisCamp
    ChrisCamp New Member
    23 Crewmax
    Any issue with rubbing with the rallyarmor? I had to trim some of the felt with my 35’s
  16. Mar 28, 2023 at 4:56 AM
    DexterL
    DexterL New Member
    you’ll just need to trim them where your tires rub, install as normal, crank the wheel and mark them- then remove and trim till you’re all set
  17. Mar 30, 2023 at 7:03 PM
    Carolina Peej
  18. Mar 30, 2023 at 9:15 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Very nice options gents!
  19. Mar 30, 2023 at 9:28 PM
    Mattedfred likes this.
  20. Mar 31, 2023 at 5:35 AM
    nobaddays
    nobaddays New Member
    Tyler
    2023 Black Tundra TRD Pro
    Full front PPF, Tint, Go Rhino boards, Retrax, 35's, Rekgen Flaps
  21. Mar 31, 2023 at 5:06 PM
    pawner
    pawner New Member
    Chattanooga, TN
    They do look great. Getting mine tomorrow! I have a very slight poke so hopefully these will cover it.
  22. Mar 31, 2023 at 5:19 PM
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    Nice! Please post once completed. I have OEM, thinking of switching.
    pawner[QUOTED] likes this.
  23. Apr 6, 2023 at 10:42 AM
    pawner
    pawner New Member
    Chattanooga, TN
    I got the black on black ones. They look real good and the coverage is pretty close to covering all of the poke. There is a about 3/4" of adjustment you can do on them (side to side) to get them to poke out more or less. I adjusted mine to max while still keeping them straight.
    DMackler and nobaddays like this.
  24. Apr 9, 2023 at 5:18 PM
    BCTundraTRDPro
    BCTundraTRDPro New Member
    2023 Magnetic Grey Tundra TRD Pro
    295/70 18 Falken Wildpeak AT3W
    Purchased/installed the rekgens after noticing minor road rash on rear fender wells. These are the ones!
    DMackler, pawner and Mattedfred like this.
