Bigger or smaller?
Discussion in 'Wheels & Tires' started by Samoan Thor, Sep 26, 2017.
  1. Sep 26, 2017 at 8:25 PM
    Samoan Thor
    Samoan Thor [OP] God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Ok the big/small wheel debate, I know small wheels offer benefits like cheaper tires although some have said not by much and most off-road serious people have small wheels big rubbers. Big wheels give you the cool look and also fill the wheels better without going that much up in size with the tires. I feel like with bigger tires no matter what wheel size you get, you’ll get diff lift plus wider surface area, but won’t that make it easier to rub on the fender liners with suspension travel? 17,18,or 20’s for the occasional to semi-serious off-roader? Voice your opinion........
    ColoradoTJ and T-Rex266 like this.
  2. Sep 26, 2017 at 8:34 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Bc related....
    Someone defintely posted this in the funny pictures thread.... No repost police here, but if any we're thinking about it, it won't happen again!
  3. Sep 26, 2017 at 8:39 PM
    Werbenjagermanjensen
    Werbenjagermanjensen New Member
    Dude
    Oreegun
    2017 TRD limited
    Bone stock
  4. Sep 26, 2017 at 8:41 PM
  5. Sep 26, 2017 at 8:54 PM
    Tundra9831
    Tundra9831 New Member
    17 or 18" with a bigger sidewall look way better than 20's or bigger in my opinion
  6. Sep 26, 2017 at 8:56 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    agreed
  7. Sep 26, 2017 at 9:04 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    In my opinion:
    Smaller wheel size and larger Tire > Larger wheel size and smaller Tire
    I am a fan of smaller wheels with larger rubbers.
    Samoan Thor[OP] and zcarpenter92 like this.
  8. Sep 26, 2017 at 10:21 PM
    geno0506
    geno0506 New Member
    Michael
    These are 18's SR8's on 295 ridge grapplers what they said above, less rim more rubber and this for me was a good ratio!18199175_10212141073380654_1146328819123712943_n.jpg18157462_10212141074260676_6298941563570129508_n.jpg18119405_10212141071500607_6986543202950021700_n.jpg
  9. Sep 27, 2017 at 1:05 AM
    chphilo
    chphilo Tundra addict
    Western PA
    When it comes to off-road performance, smaller wheels, hands down. There really is no advantage for larger wheels and less rubber.
    When it comes to on-road performance, smaller wheels have more advantage (better acceleration, braking, mpg, wheel protection). Larger wheels have advantage in handling high-speed turning (which personally I don't do often, actually, more like never). Also related to this--less body roll.
    Pricewise, for the same overall size, smaller wheels and larger rubber is generally cheaper than larger wheels and smaller rubber. (I don't get why less rubber is more expensive).
    The difference between 18 and 20 is really small though for everyday driving. But if you are serious off-roader and have to air down your tires, go over a very sharp rocks, etc., you will definitely get more nervous with 20 inch wheels than 18.
    Theoretically 17s should be better than 18s. I did not go with 17s because I could not find any wheels I liked (and choice for Tundras in that size is really really small).
    Samoan Thor[OP], joonbug and Sunnier like this.
  10. Sep 27, 2017 at 1:20 AM
    chadjamesr
    chadjamesr New Member
    Chad
    Atlanta
    2016 Tundra Platinum 4x4 Crew Cab
    Fox 2.5 w/ DSC Remotes F&R Coach Builder +3 Shackles RW Wheels w/285/75/17 Terra Grappler G2 Interior and exterior changed to LED Retrofit headlights with DS2 4.0 Morimoto LED fog lights Morimoto 40" LED bar in front bumper Retrax PRO Tonneau cover RCI front skid plate Crystalline tint on all windows and windshield P&P Rock sliders and full skip plates
    Like most people said, for most cases including offloading, the smaller wheel larger sidewall works best. Even on road, I prefer the larger side wall as it gives a better ride and I don't have to worry about damaging my wheel when I run over something. Big wheels look nice, but other then an advantage of handling they weigh more resulting in poorer performance, less MPG, and a harsher ride.
    I went with 17" RW wheels as they are light, but if you don't like those wheels I would probably go with 18" for more options both for wheels and tires. I also highly recommend E rated tires. Although they ride a little firmer, I found that they made the truck feel much more stable in the turns. The stock 20" wheels and tires always felt mushy.
    Samoan Thor[OP] likes this.
  11. Sep 27, 2017 at 7:51 AM
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    17's with 35's where it's at!! At least for me and alot of other guys/gals.
  12. Sep 27, 2017 at 11:40 AM
    mlucas555
    mlucas555 New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    I have been looking for new wheels and tires. This has helped me decide, I'm going with 18" wheels but not sure on the tire size yet.
  13. Sep 27, 2017 at 12:38 PM
    Samoan Thor
    I agree but I have also seen 20's(I wouldn't go past 20, don't like the lowrider street queen 22-24" wheel looks) with 35's and 37's and it looks good with a lot of tire, but then back to the issue I mentioned it might rub on the fender liner when the suspension travels too far up
    I agree but I have also seen 20's(I wouldn't go past 20, don't like the lowrider street queen 22-24" wheel looks) with 35's and 37's and it looks good with a lot of tire.
    I agree but I have also seen 20's(I wouldn't go past 20, don't like the lowrider street queen 22-24" wheel looks) with 35's and 37's and it looks good with a lot of tire. I want 17's to be honest but not many choices like you said, only stock wheel is the rock warriors and those are discontinued plus hard to come by, methods yea I like them but I think i want a more tucked in look under the fenders or stock offset wheels.
    I agree but I have also seen 20's(I wouldn't go past 20, don't like the lowrider street queen 22-24" wheel looks) with 35's and 37's and it looks good with a lot of tire. I like the rock warriors and hated toyota for discontinuing them, they're hard to come by and when I do find them they're always far and not willing to ship, I wish there were more 17" wheel choices besides methods, icon and rock warriors.
    agreed
    good to know it helped!
