Biggest 3UR "Major" Problems and PM to avoid
Discussion in '2.5 Gen Tundras (2014-2021)' started by steezy, Feb 10, 2025.
  1. Feb 10, 2025 at 10:42 AM
    steezy
    steezy [OP] New Member
    2021 Tundra TRD Pro
    I've been scouring this thread all morning looking at coolant valley leak, cam tower leak & (less-so) head gasket leak threads and got the typical WebMD paranoia setting in, so I thought it would be a good idea to get everyone's input on what the best preventative maintenance might be on these trucks to avoid the 3 "main" gremlins:
    1. coolant valley leak
    2. cam shaft tower
    3. head gasket
    If anyone thinks there are bigger/more common issues these engines see, feel free to add to the list.
  2. Feb 10, 2025 at 10:46 AM
    AZBoatHauler
    So.Arizona
    Coolant every 5 years or 60k miles after the factory fill.
    oil change every 5k miles/12months.
    Car care nut says head gasket failures seem to be limited to 2007-2013. 2014 got a part change.
    You could add ethanol miscalculation for the flex fuel models but that’s more of an electrical/computer issue than an engine problem.
  3. Feb 10, 2025 at 10:47 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Tundra Crewmax Platinum 4WD
    1. Frequent coolant exchanges/flushes (every 50k miles or 5 years).
    2. Get that 0W-20 water out of the pan and put 5W-30 in. Change every 5k miles.
    3. See #1 above.
  4. Feb 10, 2025 at 12:48 PM
    steezy
    2021 Tundra TRD Pro
    Looks like you live in a hot climate, too: do you recommend 5w-30?
  5. Feb 10, 2025 at 12:52 PM
    AZBoatHauler
    So.Arizona
    1000% yes. I’ve been running since 30k. At 108k now.
    ATV25 and steezy[QUOTED][OP] like this.
  6. Feb 10, 2025 at 12:57 PM
    mfelton18
    mfelton18 I'M THE PROBLEM
    South Central Texas
    2014 Magnetic grey SR5 4x4 crewmax
    Eibach Stage 2, RCI armor, Method 705
    does the 5w-30 help with the cam tower leak and the timing cover leak? Sorry if this has been answered somewhere else.
    ATV25 likes this.
  7. Feb 10, 2025 at 1:01 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    Anecdotally many seems to think so. It also seems helpful for quieting down or preventing the timing chain tensioner rattle.
    It's also fascinating that across the globe, the USA was the only country in which the 3UR was sold and recommended to be run on 0W-20. In every other country it was sold in, it was recommended to run 5W-30 (with zero mechanical changes made to the US version)
    Henry1jg, ATV25, Mdl and 1 other person like this.
  8. Feb 10, 2025 at 1:06 PM
    mfelton18
    South Central Texas
    Thank you. My truck is a 14 with 125k on it. Has a slight oil leak at the timing cover. I will be switching to 5w-30 next change and see if it slows it doesn't.
  9. Feb 12, 2025 at 7:51 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    As someone who has resealed almost two dozen cam towers, I've never seen any rhyme or reason to prevent them from leaking, though I can't comment on the oil viscosity possibility. I've seen them leak as early as 2-3k miles, and I've seen trucks that have greasy spots that we've told the customer to monitor, and it has never become a problem. I bought my '15 used with 86k on it and used the greasy cam towers as a bargaining chip with the Dodge dealer to knock a few bucks off of the price of the truck. I'm now at 221k as of this morning's drive into work, and I still haven't had them resealed. The only thing I have ever noticed from the truck is occasionally, after a heavy workload like pulling a decent trailer, I'll occasionally get a whiff of oil as I walk past the driver front fender.
    With that being said what I always told customers was that you shouldn't need to worry about it too much until you start seeing it actively dripping. The dealer I worked at wouldn't allow us to recommend them unless we had an active drip, and I found that seemed to be a pretty good basis for the recommendation.
    As for the valley tray, mine made it to 200k almost exactly. I found my water pump leaking when I replaced my original serpentine belt, tensioner and idler pulleys. My brother, who is still a dealer tech, did the water pump for me as it was a little more than I felt like doing in the driveway and knocked out the leaking valley tray at the same time.
    I agree with the head gasket issue, my understanding is it's almost exclusive to the pre update 2014 trucks.
    Terndrerrr and Mdl like this.
  10. Feb 15, 2025 at 9:51 AM
    FabioXc
    FabioXc New Member
    None
    Should I use 5w-30 I live in AZ and I got 101000 thousand miles on it
  11. Feb 15, 2025 at 3:41 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    We had a theory at the shop that the customers who did there oil changes over an extended period of time were the ones that had the cam tower leaks and timing cover leaks. One tech swore it was because the oil becomes more acidic and would attack the fipg.
  12. Feb 16, 2025 at 8:06 AM
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
    How would explain the guys who got their cam tower leaks at only 2k miles, I read about brand new trucks sitting at the dealer that just got offloaded from the delivery truck with the leaks
    250000yota likes this.
  13. Feb 16, 2025 at 3:00 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You might have read about it but it’s would be extremely rare for cam tower leaks at that low of a mileage. The very few that might have a leak would be from a poor application of sealant when the engine was assembled. We had a few timing cover leaks on low mileage 3UR-FE motors but it was from an insufficient amount of fipg.
  14. Feb 17, 2025 at 9:27 AM
    250000yota
    Russ
    Berthoud, CO
    I personally saw 4-5 cam tower leaks before their first oil change. In fact, the first one I saw had just shy of 2k miles and came in specifically because he was dripping oil on the driveway.
    I don't believe self-maintenance had anything to do with it, more likely the grey factory FIPG or an application error when these engines were assembled. According to our FTS, the manufacturers have a limited amount of silicone they are allowed to use per engine, so the application is done by a robotic arm with a calibrated tip to apply a precise amount. I don't know how true that is, but that's the story our rep gave us. A lot of the trucks I did and saw done were under warranty, recommended by us at the dealer. I think I've only done 2-3 customer pay trucks to be honest.
  15. Feb 17, 2025 at 9:45 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    - 5w30 @ 5k
    - don't shut engine off immediately at the pee stop after cruising at highway speeds, or piston rings will cook
    - if towing, let engine cool on the side of the road a bit after the climb and before descending: engine braking cools it very quickly, you may stress the heads / block thermally, they can warp
  16. Feb 17, 2025 at 9:53 AM
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    Getting ready to do the Coolant change this year. Any specific TTPs? Does this need to be purged, bled, etc? I plan to drain radiator with petcock (assuming it is there) then pull lower and upper Radiator hoses to allow to drain completely, and refill with Toyota Coolant (pre-mixed preferred) or Coolant and Distilled Water.
    I've been neglecting this, am at 100K & 7 years, and need to do it. Have kept up on all other fluids including brake flushes, trans, transfer case, read diff, but have neglected the coolant.
    Been running 5W30 since day 1, with a bottle of Ceratec every other change. Intervals have been 5-7K, with a couple going to 10K when I was taking lots of 1300 mile round trips (monthly).
  17. Feb 17, 2025 at 10:00 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    4. Wet panties constantly being thrown at the Voodoo Blue TRD PROs.
  18. Feb 17, 2025 at 10:04 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
  19. Feb 17, 2025 at 10:12 AM
    Moisture on said undergarments can damage the finish. And cause poor decision making.
    vtl, hagrid[QUOTED] and FrenchToasty like this.
  20. Feb 17, 2025 at 2:00 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You would think that if the leaks were from the lack of fipg you would think that you would see most of the oil leaks early on. They seem to be right away or on older and/or high mileage engines.
