bike rack hell...
Discussion in '3rd Gen Tundras (2022+)' started by raylo, Jul 4, 2023.
  1. Jul 4, 2023 at 4:21 AM
    raylo
    raylo [OP] not so new member
    Frederick, MD
    I have had my Kuat bike rack on the hitch for a week or so and the safety systems are a PITA. I turn off the back up alert in the first place or that will slam on the brakes. That was easy enough. But then when I do go into reverse I get a loud steady beep... which can be silenced easily enough by pressing the OK button so that is alright, I guess. But then it throws a dirty backup sensor warning and shows the left rear sensor in orange. I can clear that by hitting the back button... but the message just keeps coming back as I drive... I can hit the back button but about 5 seconds later the error message is back... and this behavior persists until I turn the engine off and back on and drive without backing up.... which makes the center of the display useless. Apparently Toyota didn't test this mess with a bike rack.
    Mr Badwrench likes this.
  2. Jul 4, 2023 at 5:24 AM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    Can you not simply turn off all rear driving aides? Don't own a Gen3 so Im genuinely curious, not being a smastass
  3. Jul 4, 2023 at 5:26 AM
    raylo
    Frederick, MD
    I have it turned off with the dash button. That was in the second sentence above. I need to get the manual out and see if there is yet another level of "off".
    Edit: apparently the dash button only turns off the Parking Brake Assist, not the Intuitive Parking Assist.
  4. Jul 4, 2023 at 5:53 AM
    raylo
    Frederick, MD
    From the manual... can turn off the intuitive Park Assist from the display meter and that setting will persist with engine off/on cycles. I'll try that next time I drive. That should stop the beeping but it remains to be seen if it clears the "dirty sensor" issue, which is the main problem.
    Also from the manual: The intuitive parking assist may not work properly:
    When equipment that may obstruct a sensor is installed, such as a towing eyelet, bumper protector (an additional trim strip, etc.), bicycle carrier, or snow plow
    So, hopefully turning it off from the meter will do the trick.
  5. Jul 4, 2023 at 6:10 AM
    Porkchop253
    Porkchop253 New Member
    2023 Platinum Hybrid
    Trd lift. Heritage grill. Painted grill surround. Ceramic tint. Bfg ko2. Leer canopy.
    I have a Kuat rack also. I have the same warnings as you but I do not have the orange light warning that keeps coming up as you drive. Once I hit the ok to silence the warning as I back up then it won’t go off again until I back up somewhere else
  6. Jul 4, 2023 at 6:12 AM
    raylo
    Frederick, MD
    Which Kuat do you have? Mine is a Sherpa II.
  7. Jul 4, 2023 at 6:13 AM
    Porkchop253
    NV
    raylo[OP] likes this.
  8. Jul 4, 2023 at 6:16 AM
    raylo
    Frederick, MD
    In my case the audio warning does nor recur unless I back up again, it just the stupid "dirty sensor" message. That is just visual and fills the center display... and can only be cleared temporarily.
  9. Jul 4, 2023 at 6:17 AM
    Porkchop253
    I have not had that warning but maybe it’s the difference in the model of the bike rack. Just a guess
  10. Jul 4, 2023 at 6:18 AM
    Porkchop253
    I might cover a sensor more than mine
  11. Jul 4, 2023 at 6:22 AM
    raylo
    Frederick, MD
    Looks like this, except in my case only the left rear sensor is in error state. For some reason the right side does not also fault.
  12. Jul 4, 2023 at 6:26 AM
    Porkchop253
    Unfortunately might have make a trip to the dealership. I would leave the bike rack on.
  13. Jul 4, 2023 at 6:27 AM
    raylo
    Frederick, MD
    I hope and believe that turning it off from the meter will work.
    Carolina Peej likes this.
  14. Jul 4, 2023 at 7:48 AM
    Bogus6
    Bogus6 New Member
    2022 Tundra TRD Pro, Solar Octane
    Yokohama Geolander MT 35x12.5x18
    I use a Fox tailgate pad and get the same warnings and errors when a bike is loaded.
  15. Jul 4, 2023 at 7:56 AM
    Carolina Peej
    Carolina Peej Hey can you hold the light for me real quick?
    North and South Carolina
    2022 Midnight Black Metallic 4x4 Tundra Platinum 5.5 w/ load leveling + AVS, HUD, and Power Running Boards
    There are two dash buttons in my Platinum. One near the shifter that controls the automatic parking brake. Another one to the left of the steering wheel that turns off the Intuitive Park assist, or whatever feature that is that slams on the brakes when backing up a trailer. As others have mentioned, depending on your trim, you may need to find this setting in the display menu on the instrument cluster, if you don’t have a hard button to the left of the wheel.
  16. Jul 4, 2023 at 8:02 AM
    raylo
    Frederick, MD
    If I read the manual correctly that hard button turns off the emergency automatic braking. There is a dash light that illuminates for that. But that does not turn off intuitive parking assist which is just the beeps when you get near stuff. That needs to be done on the display as far as I can tell. When I get my error message the dash gains another light which shows intuitive park assist is in fault. I'll get some pics next time.
  17. Jul 4, 2023 at 8:16 AM
    Carolina Peej
    Yeah, the beeps are annoying. I forgot about that. Gotta hit that ‘ok’ button on the steering wheel to silence. But at least it doesn’t slam on the brakes when I’m backing the trailer into the parking spot. That scared the absolute crap out of me first time it happened.
    raylo[QUOTED][OP] likes this.
  18. Aug 16, 2023 at 6:52 AM
    Ericsopa
    Ericsopa Old man and the sea
    SO happy to have a '13 without all that crap to deal with. Not necessarily Toyota's fault, I guess, but technology seems to be getting less and less user-friendly as time goes by. Pretty soon, there won't be a way for the user to interfere in the least. You won't be able to turn ANYthing OFF!!
    Rigger likes this.
  19. Aug 16, 2023 at 7:09 AM
    mass-hole
    mass-hole New Member
    Mike Sweers thinks you should buy a Subaru if you wanna tote around mountain bikes.
    This is a truck and should be used for manly truck things. They left the beeps and warnings there just to persuade you to buy that subaru
  20. Mar 17, 2024 at 6:40 PM
    Nio9
    Nio9 New Member
    Drop the M & -, that's what you are!
  21. Mar 17, 2024 at 6:43 PM
    Nio9
    Nio9 New Member
    I found in the vehicle settings to turn off the parking sensors, the first time I was backing up with a bike rack my '24 limited JAMMED the brakes on!
  22. Mar 17, 2024 at 7:20 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I put my bike above the sensors so no beeping or random brake slamming!
    mayan likes this.
  23. Apr 9, 2024 at 9:20 AM
    ghunter321
    ghunter321 Trail Hunter
    NC
    2022 Blueprint Limited Tundra
    Retrax Pro XR bed cover, UpTop Overland mid truss system with Baja Designs rock lighting X6, GGOffroad rearview camera relocation kit, Pelican cargo BX90 case, Maxtrax recovery traction boards, OEM bed step, OEM dash and door trim/cubby/footwell lighting, Slee Offroad dual wireless Qi phone charger upgrade, CBI covert front bumper with air dam delete module, TRD Pro heritage grille replace with amber OEM marker lights, Diode Dynamics 18" white lightbar kit and OEM marker lighting, Diode Dynamics covert 18" amber lightbar, Rough Country bed mat, Rough Country defender series fender flares, TRD camo tailgate spoiler and OEM marker lights, TRD camo rear bumper arms, Screen Protech for interior surfaces, OEM badge blackout
    Which upright bike mount do you have? I tried swagman from Amazon but it’s a little wobbly for my tastes. Gets the job done but always on the lookout for improvements
  24. Apr 9, 2024 at 9:38 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    My racks are Yakimas!
