Bilstein 4600 rubber grommets too big for original shock hat?
Discussion in '1st Gen Tundras (2000-2006)' started by Jack McCarthy, Oct 9, 2021.
  1. Oct 9, 2021 at 10:47 AM
    Jack McCarthy
    Jack McCarthy [OP] Working remotely from the local pub
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Looks like the shock hat wants its original grommets which are smaller in size to fit. Bilstein ones don't allow enough thread to start shock nut.
    Is there another way to make it fit or should I reuse the knarly original ones? I'm not sure if my dealer would even have them in stock.
    To top it off I sat on my prescription reading glasses and popped out the lenses. My day is going great, how about you?
  2. Oct 9, 2021 at 10:51 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    How close is it? Close and the shock stud should reveal more as you compress, lift at the LCA? I would be hard pressed to reuse those top hats.
    NewImprovedRon likes this.
  3. Oct 9, 2021 at 10:54 AM
    SouthWestGA
    SouthWestGA New Member
    Welcome to the forum!
    Here’s my view
    You see how you have a wobbled out slotted metal top mount? It’s not supposed to be that way.
    It’s supposed to be a proper centered hole.
    Even IF you put a new rubber bushing in there,it won’t be right.
    Get a new top piece,then install everything correctly with the proper bushing and call it good
    Do it right,do it once!
    Oey12 likes this.
  4. Oct 9, 2021 at 11:00 AM
    Jack McCarthy
    Bill
    North of Boston
    Well the dealer certainly didn't install it correctly. They were the ones who last installed replacement shocks back in 2010 and drilled that carnage of a hole.
  5. Oct 9, 2021 at 11:04 AM
    Jack McCarthy
    Bill
    North of Boston
    I can't even see the first thread when I put everything together unless I take out the dust boot which provides an extra 1/4 inch. I've also tried reversing the Bilstein grommet but that doesn't help either.
    It looks like the lip on the underside of the top hat is getting in the way of the larger Bilstein grommet.
  6. Oct 9, 2021 at 11:11 AM
    Jack McCarthy
    Bill
    North of Boston
    Yikes! I took a look online and the rubber grommets are part of the Toyota standard shock and not ordered separately. That's not good.
    How is everyone else getting this to work? I'm missing something here obviously.
  7. Oct 9, 2021 at 12:15 PM
    Jack McCarthy
    Bill
    North of Boston
    Here it is stacked...
    I'm seriously thinking of assembling it without the dust boot. There's no easy solution here.
  8. Oct 9, 2021 at 12:20 PM
    SouthWestGA
    You’ll probably wear out the bushings prematurely with the way those top hats look and have to RE do everything all over again
    It shouldn’t have the sideways slots in it
    No dust boot? Why? If you’re having issues,taking stuff off that’s supposed to be intact isn’t really making things work properly
    Have you checked the local parts store for new top hats? KYB makes excellent top hats
  9. Oct 9, 2021 at 12:28 PM
    Jack McCarthy
    Bill
    North of Boston
    Even without the botched top hat hole i shouldn't have an issue using the Bilstein grommets but I do unfortunately as no thread is visible to catch with the top shock nut to tighten down the whole assembly.
  10. Oct 9, 2021 at 12:53 PM
    Jack McCarthy
    Bill
    North of Boston
    Anyone else have luck with aftermarket hats (strut mounts)? I see KYB SM5442s being compatible but so far they need to be ordered and are not in stock anywhere at a local chain auto parts store.
  11. Oct 9, 2021 at 12:58 PM
    alb1k
    Left Coast
    It's good
    That's not a drilled hole, thats wear from excessive movement.
    FrenchToasty likes this.
  12. Oct 9, 2021 at 1:03 PM
    alb1k
    Left Coast
    It's good
    said someone yesterday....@Tundra2
    Jack McCarthy[OP] likes this.
  13. Oct 9, 2021 at 1:10 PM
    Jack McCarthy
    Bill
    North of Boston
    Really? That blows my mind that can happen.
    Too late for that unfortunately.
    Currently looking for Moog K90726 replacement hats... not in stock anywhere.
    How did I know my weekend would suck so much? lol
  14. Oct 9, 2021 at 1:14 PM
    alb1k
    Left Coast
    It's good
    I hear you, been there. I'm fairly certain that when I installed similar, I had to do a loose assembly, bolt the bottom of the shock to the LCA, and jack the LCA up to compress the spring and that bushing to show threads.
  15. Oct 9, 2021 at 1:44 PM
    Jack McCarthy
    Bill
    North of Boston
    I hate to go that route, so I'm going to do a search and see if I can find ANY strut mount locally to replace the F'd one I have first.
    Hopefully leaving the spring compressed overnight won't be an issue.
  16. Oct 9, 2021 at 1:46 PM
    alb1k
    Left Coast
    It's good
    The spring is compressed all day long when installed and the truck on the ground. No issue.
  17. Oct 9, 2021 at 1:50 PM
    Jack McCarthy
    Bill
    North of Boston
    No its the cheap Chinese spring compressor I'm worried about. I don't want to grenade tomorrow when I work on it again.
  18. Oct 9, 2021 at 1:54 PM
    alb1k
    Left Coast
    It's good
    those are scary. there is a video on how to compress spring safely on the truck I recall. Top hat gets bolted in, loose assembly below that, frame up and then jack LCA up to put the stem through the hole. But you need top hats.
  19. Oct 9, 2021 at 4:54 PM
    Jack McCarthy
    Bill
    North of Boston
    Well, the decision has come down from above....
    I'm to move my sh!tbox out of the driveway by the end of tomorrow so my father can finish his timing belt (he's parked behind me, BTW) and get his vehicle back on the road. :smack:
    Guess I'll be driving without dust boots with that hole in the strut mount.
    des2mtn likes this.
  20. Oct 9, 2021 at 7:06 PM
    SouthWestGA
    Well you can always fix it properly next weekend right? New top hats,keep the boots and all!
  21. Oct 9, 2021 at 10:45 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Wheelers carries the top hats Jack.
    Jack McCarthy[OP] and Tundra2 like this.
  22. Oct 10, 2021 at 12:45 AM
    Jack McCarthy
    Bill
    North of Boston
    Unlikely, but if i run into wear issues, I may have no choice.
  23. Oct 10, 2021 at 9:30 AM
    Jack McCarthy
    Bill
    North of Boston
    20211010_122613.jpg Well, 90% there on the 1st shock. Need my father to work the crowbar while I push the bolt through. I tried it myself but smacked myself in the face with the pry bar. :rofl:
    des2mtn likes this.
  24. Oct 12, 2021 at 8:03 AM
    Jack McCarthy
    Bill
    North of Boston
    Shock 2# apart. Damn, coil was rusted to the shock seat. :rofl:
    des2mtn likes this.
  25. Oct 12, 2021 at 9:14 AM
    Jack McCarthy
    Bill
    North of Boston
    Complete! Now only the rear shocks remain...
    The $50 spring compressor held up thankfully. The trick is to only use 1/2 2200 lb rating, so I estimated 600 lbs force/inch of the springs x 1.5 inch compression = 900 lbs of force.
    des2mtn and 1lowlife like this.
