Bilstein 5100 Front Shocks on 22 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by hansenr3, Aug 3, 2022.
  1. Aug 3, 2022 at 6:25 AM
    hansenr3
    hansenr3 [OP] New Member
    Hey guys,
    Anyone try installing Bilstein 5100's on their 2022 yet? Part# 24232173 fits the 07-21 but was wondering if anyone tried fitment, I want to level the truck but not a fan of the spacer kits out there. Thanks!
  2. Aug 3, 2022 at 8:03 AM
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    I emailed bilstein a couple months ago and was told these wouldn't be available until some time next year, not sure these will fit our 2022 trucks?
  3. Dec 17, 2022 at 3:52 PM
    socaldad
    socaldad New Member
    23 SR5 crewmax TRD-sport
    Any update on when bilstein 5100 come out?
  4. Dec 17, 2022 at 5:13 PM
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    I emailed them last summer. They said mid to late 2023. Rough Country has a couple options in the same price range. I ended up doing their 2” front struts on my truck.
    socaldad likes this.
  5. Dec 17, 2022 at 9:19 PM
    mass-hole
    mass-hole New Member
    Bilstein is having trouble shipping existing shocks, I dont think they are necessarily worrying too much about trying to bring out new ones quite yet.
  6. Dec 18, 2022 at 1:46 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    How about buying the Trd shocks front and rear? Are there any new ones available?
    Or what would be part numbers for used ones in case someone is selling lightly used from their Trd Tundra?
  7. Dec 18, 2022 at 6:26 PM
    22Tundraplat253
    22Tundraplat253 New Member
    Chanh
    2022 Tundra Platinum
    Wheels,lift,air level std stuff
    Will not work..I have the same strut kit and spend 4hrs on installing removing adjusting the finding out the circlip fails with oe spring perch as the providing bilsteing perch won't fit outer large spring o.d...so I spend another hr reinstalling oe strut with level spacer..
    batman900 likes this.
  8. Dec 18, 2022 at 8:33 PM
    socaldad
    socaldad New Member
    How’s the ride on the RC
    Which rc did you get? The M1 adjustable or 2” leveling kit?
    iiawah808 likes this.
  9. Dec 20, 2022 at 7:21 AM
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    I did the static 2" leveling struts. I'm quite impressed with them, especially for the price. WAY BETTER than a spacer lift. I had bilstein 5100's on a 2019 Ram and these feel just as good. I have a 1” space in the back because I tow.
    socaldad[QUOTED] and iiawah808 like this.
  10. Dec 20, 2022 at 9:11 AM
    Ullose272
    Ullose272 New Member
    Boise, Id
    22 Tundra SR5 TRD OR
    i have the rear shocks from the TRD lift kit installed on my truck, they are about 2" longer. i have the struts sitting here by my tool box, but quick measuring tells me they wont work with the factory spring, the red TRD spring will be required which doesnt seem to be available yet.
    iiawah808 and Cdunner like this.
  11. Dec 20, 2022 at 4:35 PM
    wildmank99
    wildmank99 New Member
    Arizona
    22 Tundra Limited
    talking about these red coils
    https://theyotagarage.com/collectio...suspension-kit-3-lift-pair-2022-toyota-tundra
  12. Dec 20, 2022 at 6:58 PM
    socaldad
    socaldad New Member
  13. Dec 21, 2022 at 3:37 AM
    wildmank99
    Arizona
    22 Tundra Limited
    that I don’t know.
    socaldad[QUOTED] likes this.
  14. Dec 21, 2022 at 4:37 AM
    Skidmarcx
    Skidmarcx New Member
    Glendale, AZ
    ‘22 SR5 CM
    You will need the UCAs if you want to achieve desired caster, I don’t believe there is enough adjustability with the stock cam bolts
    wildmank99 and socaldad[QUOTED] like this.
  15. Dec 21, 2022 at 9:08 AM
    Ullose272
    Boise, Id
    wildmank99[QUOTED] likes this.
  16. Dec 21, 2022 at 10:34 AM
    wildmank99
    Arizona
    22 Tundra Limited
    thanks for the info
  17. Dec 21, 2022 at 11:01 AM
    Ullose272
    Boise, Id
    I RETRACT THIS they are now available just ordered a set.
    wildmank99 likes this.
  18. Apr 18, 2023 at 8:13 PM
    Cdunner
    Cdunner New Member
    2023 White Sequoia SR5 TRD Off-road
    So you’re saying the trd lift kit front shock will not work with oem springs? Thanks
  19. Jan 14, 2024 at 9:32 AM
    2021 work truck
    2021 work truck New Member
    22 Tundra Crewmax 6.5
    33" Tires, Black Toyota Rims, TRD shocks
    Anybody know if the TRD shocks from lift kit will work with the stock springs and uca's?
  20. Jan 15, 2024 at 4:10 PM
    LB-1889
    LB-1889 New Member
    Bilstein just put a post out on instagram looking for MY22+ vehicles for product development. I’m guessing it may be awhile.
    ScootARoot and Dfrink like this.
  21. Dec 14, 2024 at 9:36 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
