Bilstein 6112’s & 5100’s
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by Tundra694, Mar 29, 2023.
Thread Status:
Not open for further replies.
  1. Mar 29, 2023 at 5:05 AM
    Tundra694
    Tundra694 [OP] New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    ***Pending local sale***
    -2 Bilstein 6112 shock/spring @ 1.9” setting
    -2 5100 rear shocks
    - For 07-21 Tundra
    -Approx. 12,000 miles of use
    -Great condition
    -Pickup or meet up only near Berks County, PA
    -$800
    Occidentalis and PermaFrostTRD like this.
  2. Mar 29, 2023 at 6:54 AM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    Quick question, are the rear shocks for stock ride height? I see they make the 5100's for no lift, 2" lift, and 4" lift. My truck has stock suspension, I would only like to lif the front a little to level. Is your profile photo with these shocks installed? What tire size do you have?
    Thanks!
  3. Mar 29, 2023 at 6:56 AM
    Tundra694
    AJ
    Stock height. The picture is with the same shocks at 2.5” height and 1.75” lift leafs in the back. 285/75r18. The attached picture is with these shocks that are for sale.
  4. Mar 29, 2023 at 7:14 AM
    RickPlatinum2020
    Rick
    Eastern PA
    Ok, so the fronts are set a little lower now (1.9" vs 2.5") so the truck will be more level, looks like a little front high in the photo...
    Thanks!
  5. Mar 29, 2023 at 7:16 AM
    Tundra694
    AJ
    Yea it’s pretty much dead level. That picture it’s parked slightly downhill.
  6. Mar 29, 2023 at 10:48 AM
    RickPlatinum2020
    Rick
    Eastern PA
    Ok, thanks for that. I am pretty local if we do the deal. My truck will be out of warranty in July, want to level it and put slightly larger tires on it after warranty. A little earlier than I was going to pull the trigger, I will get back to you shortly.
  7. Mar 29, 2023 at 11:20 AM
    Tundra694
    AJ
    sounds good. I’d prefer a local sale so I’m all about it. Let me know if you have any other questions. Here’s a better photo as well.
  8. Mar 29, 2023 at 4:59 PM
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    Did you take this off my truck?! Haha also in Berks with same set-up. Highly recommend
    Okimar and Tundra694[OP] like this.
  9. Mar 31, 2023 at 8:58 AM
    Tundra694
    AJ
Thread Status:
