Bilstein struts and shocks rusted?
Discussion in 'Suspension' started by atrinh15, Mar 21, 2021.
  1. Mar 21, 2021 at 5:58 PM
    atrinh15
    atrinh15 [OP] New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    Has anyone else had rust issues with there Bilstein shocks and struts? I’ve had them for less than a year and this was the first winter. I wash my truck regularly with under carriage wash. Kinda upset. Seeing if anyone else is having the same problem.
  2. Mar 21, 2021 at 6:04 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Doesn't seem like your undercarriage wash is doing anything for the undercarriage either...
  3. Mar 21, 2021 at 6:20 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I agree with 14burrito. What are you using for an undercarriage wash?, maybe its ingredients are harsh on paint.
  4. Mar 21, 2021 at 6:21 PM
    atrinh15
    495-93 area
    It looks worse than it is in that picture. I would think the coating would be better on these.
    just going thru a automatic car wash
  5. Mar 21, 2021 at 7:31 PM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    Auto wash isn’t going to get in there. When I got my truck last spring, I took a wire brush and wire wheel on a drill to all the rust underneath. Then I picked a nice warm day and got under there with a pressure washer. I made sure to let it dry for at least a day. Then I treated all the spots with a spray on rust treatment. I then painted what I could with Por15. When winter started approaching I washed underneath again, let it dry and sprayed the crap out of it with CRC marine corrosion inhibitor. I also sprayed some Fluid Film in the hard to get to spots. Oh, and filled the rocker panels with 3m cavity wax.
    The CRC stuff leaves a yellow sticky waxy film, but it’s better than rust. Just washed under there this weekend now that it’s warmed up and the water was still beading off. A lot of work, but I plan on keeping my truck a long time.
  6. Mar 21, 2021 at 7:36 PM
    TheBeast The Beach
    automatic car wash wont do anything, you need to crawl underneath and hit it good with water/soap /baking soda/brush
    get all that grime /road salt out. let it dry then some type of undercarriage protectant.
    14burrito likes this.
  7. Mar 21, 2021 at 8:25 PM
    Teegee
    Teegee Around
    Grouch
    21 MAX
    If the powder coat on the sway bar is rusted then for sure the Bilsteins will rust.
    Aluminum polish and some elbow grease and they should clean up
  8. Mar 21, 2021 at 10:03 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    That doesn't look like a Bilstein problem, there's a lot of rust back there... leaf springs, axle, RSB.
    I'd address that ASAP before it get's too far out of hand, especially the springs and axle.
    The shocks and RSB are relatively cheap parts to replace, the rest of that stuff is not so inexpensive.
  9. Mar 22, 2021 at 3:30 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    That is what Bilsteins do especially since you did not buy the upgraded resi clamps.
    Aluminum mated to steel makes things worse.
    A good coat of Eezox on the suspension every month or so will help.
    You also need to really hose it down after the salt.
  10. Mar 22, 2021 at 3:57 AM
    timsp8
    NY
    My 6112/5160 were covered in rust after 1 winter. I’d wash all the road salt and dirt off once a week too, but it didn’t matter.
    atrinh15[OP] and 14burrito like this.
  11. Mar 22, 2021 at 4:30 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Everything is rusty from what I see. There is not a single shock or coilover in the world that won’t look like this without proper maintenance. Mine have zero rust in over 2 years of having them on. Proper cleaning and protection go a long way.
    ShinyConcretE and 14burrito like this.
  12. Mar 22, 2021 at 4:35 AM
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    Has anyone painted or clear coated them before install? Thinking about doing mine with something. Just not sure what yet.
  13. Nov 30, 2021 at 3:42 PM
    EZDoes It
    EZDoes It New Member
    Ed
    LSD (Lower Slower Delaware)
    2020 MGM CM SR5 TRD exhaust, TRD wheels
    Tint, tow mirrors, remote start, Razormotor taillights, Genuine trans cooler, tailgate light strip, Extang tonneau, TRD rear sway bar, trans cooler…(thanks TRD)
    With the looks of that under carriage, you can’t blame Bilstein…IMO.
  14. Dec 1, 2021 at 6:26 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    If you live in an area that gets a lot of snow and has salted roads then you should look into applying fluid film to the undercarriage/suspension.
