Bilstein TRD Sport suspension vs. Stock
Discussion in 'Suspension' started by Rustyscrew, Jul 5, 2019.
  1. Jul 5, 2019 at 5:57 AM
    Rustyscrew
    Rustyscrew [OP] New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    I was curious on peoples opinion on how the ride, and feel is between the Bilstein TRD Sport performance shocks are versus the stock ones? I'm thinking of switching to them on my 15 Platinum. Just wanted some feed back. I already have TRD front and rear sways. Now looking to maybe upgrade to those.
  2. Jul 5, 2019 at 6:04 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I test drove both ( all three actually; Standard, TRD Sport and TRD Off Road) and did not feel any significant difference. The different size tires probably made a bigger difference in ride than the shocks. I would not spend the money, unless you can get them for a bargain, for instance someone who takes theirs off to upgrade to aftermarket suspension. If you do want to upgrade, aftermarket shocks might be a little more expensive, but will give you a significant different ride.
  3. Jul 5, 2019 at 7:20 AM
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    The black stock ones are soft.. red off road were stiffer and more rigid on road. Work well off road though
  4. Jul 5, 2019 at 7:31 AM
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    I thought the red and blue TRD's are a "race inspired on road" shock. Is this not true?
    AxelsHumanDad likes this.
  5. Jul 5, 2019 at 8:35 AM
    Boerseun
    Ferdie
    Sarasota Florida
    There are supposed to be a difference between the TRD Sport and TRD OffRoad shocks, and they are "race inspired". Sport is tuned more for road use and OffRoad obviously for off road use, but I have heard conflicting stories about the difference. Most opinions is that the road shocks are stiffer (like a race car's suspension) for cornering etc. and Off Road is softer to absorb all the uneven terrain. From my test drive experience I could not tell much difference. I don't think I would spend much money to get one over the other.
    Black Wolf likes this.
  6. Jul 5, 2019 at 8:41 AM
    Boerseun
    Ferdie
    Sarasota Florida
    I would suggest go test drive a Sport and see if you notice a difference. Keep in mind tire pressure when you do so. When I bought my truck the tires were at 28psi. Nice soft ride, but they wore on the outsides. I upped it to 36 psi - noticable difference, but of course it had nothing to do with the shocks, so make sure if you test drive and compare to your Platinum, that you keep tire pressure and even tire make and model in mind. Sport and Platinum should at least be the same size tire if you are still stock.
  7. Jul 5, 2019 at 8:43 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Only worth it if you’re getting everything from the Sport for 250 or less. Otherwise go with a better upgrade, like a Bilstein 5100
  8. Jul 5, 2019 at 8:43 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    I swapped my OEM black Gabriels to a set of TRD Sports about 6 months ago. They’re awesome. Tad bit stiffer than the soft, black ones (what new shocks aren’t) but in a good way. Got used take offs with less than 100 miles for $200. Raised truck 1/4” from sagging OEM shocks with 75k.
    Boerseun likes this.
  9. Jul 6, 2019 at 12:48 AM
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    Thanks, that is what I was hoping for. I never offroad more than driving in a front yard. I'm wanting to get better handling, because I like to drive like its a race car since I don't have one... right now
  10. Jul 6, 2019 at 12:48 AM
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    That's a really good idea. I just might go and do that.
    Boerseun[QUOTED] likes this.
  11. Jul 6, 2019 at 1:28 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    I think the ride in the Sport is because of the shocks and weight?? Shocks diffidently make a difference in the ride. My daughters TSS rides like a tank and I attribute that to the shock difference and less weight than my Sport. My Bilstien shocks along with the weight of the four wheel drive make the ride in my Sport very comfortable. The Billstiens front and back come with the truck. The TSS is a rough rider, you hit every bump very hard compared to the sport.
  12. Jul 6, 2019 at 1:35 AM
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    Buy the most expensive shock you can realistically afford.
    The expensive ones, last a long time. And you literally feel the payoff, nearly every second you’re in your truck.
    It only took me 19 years to figure that out, after 12 different off-road shock setups.
    15whtrd likes this.
  13. Jul 6, 2019 at 2:04 AM
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    I'm not looking for an off-road shock, I'm looking for a better on-road setup without really lowering. Do you know of a better on-road setup?
  14. Jul 6, 2019 at 2:08 AM
    Bingeaux
    Bingeaux New Member
    2018 MGM Tundra TRD Sport CM
    Took off my sport shocks for 6112 highest setting. Didn’t regret one bit. More softer but still firm and hit bumps like a champ.;)
  15. Jul 6, 2019 at 2:20 AM
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    I’m 99% street and switched from stock to the 6112s set to the second lowest spot and comparing the two is night and day when it comes to handling. I agree with @Boosted4runner, get the best shocks you can afford.
    Mr Swervlin likes this.
  16. Jul 6, 2019 at 2:28 AM
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    Does the 6112s lift the truck?
  17. Jul 6, 2019 at 2:49 AM
    justfortun
    James
    Boston
    2016 SR5
    Four heights, and you need to pick one because changing means taking the shock apart a bit. It raises .9”, 1.3”, 1.9” and 2.5”
  18. Jul 6, 2019 at 3:53 AM
    Toyota's plain jane OEM shocks on the 2nd/3rd gen tunny are KYB.Taco's got Tokico's
    Jrharvey02[QUOTED] likes this.
  19. Jul 6, 2019 at 3:57 AM
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    I'm really not looking to do a lift at all. Even if it's 0.9 inches. I really think I'm going to go with the red and blue TRD
  20. Jul 6, 2019 at 6:52 AM
    Jrharvey02
    I take on/off ramps at no less than 70 in my race truck...
  21. Jul 6, 2019 at 7:02 AM
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    Thats what I'm talkin' bout
  22. Jul 6, 2019 at 8:19 AM
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    I can't wait to get rid if my TRD Yellow and blues. Upgrading to 6112 soon
    PermaFrostTRD likes this.
  23. Jul 6, 2019 at 8:24 AM
    Danman34
    Danman34 New Member
    Danny
    You should do it. It’s not safe driving on inadequate shocks.
  24. Jul 6, 2019 at 8:40 AM
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    Totally unsafe
    worktruckwhite likes this.
  25. Jul 6, 2019 at 9:24 AM
    TundraDan15
    TundraDan15 New Member
    2015 White Tundra Limited CrewMax
    Looking to purchase a set of Bilstein 5100’s to level out the front. What setting should I use #3 or #4 without the truck going nose high?
    NativeHoustonian58 and Rica25 like this.
  26. Jul 6, 2019 at 11:56 AM
    Rica25
    Ricardo
    Tulare
    I've had 5100s for about 3 yrs now and if I was to buy shocks again they will be the Billstein 6112 and 5160
  27. Jul 6, 2019 at 11:27 PM
    Boosted4runner
    WA
    Well, the expensive off-road shocks, handle amazing better on-road as well.
    My old TRD set-up I could never do 110mph without white knuckles on road (floater-boat style). Kings (while in Mexico) can easily tap out the limiter and feel planted as F.
    There are areas/bends on the freeway that a stock car wouldn’t do 90 around, and the Tundra on Kings does with zero issue. Not saying anyone has to do 100mph to enjoy them, just trying to give an idea of how correct dampening should work in a truck. It’s hard to explain. Test drive a TRD Pro and you’re almost there.
    I’ve turned a few friends onto Kings that are pavement pounders, and they will admit it turns a stock vehicle into a drive they didn’t know existed.
    Edited to add - I’m not running a front sway bar either LOL.
    SprinterAE86 and Rica25 like this.
  28. Jul 7, 2019 at 3:27 AM
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    Very interesting. Good to know. I assumed since lifting give you a higher center of gravity it would hinder handling capabilities.
    Rica25 likes this.
  29. Jul 7, 2019 at 8:21 AM
    Boosted4runner
    WA
    Generally speaking, yes. But the better shock makes up for it.
    Ever watched the stadium trucks on the road courses? They are pretty badass! :D
    SprinterAE86 likes this.
  30. Nov 23, 2019 at 3:21 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    I need to stop going in this forum. It's getting more expensive than my racecar build. But I will look into King next time. I need to convince my self and justify the cost and effect.
