Black Door Handles & Badges
Discussion in 'General Tundra Discussion' started by Bistrostyle, Dec 1, 2018.
  1. Dec 1, 2018 at 9:50 AM
    Bistrostyle
    Bistrostyle [OP] New Member
    2018 Toyota Tubdra Crewmax Limited
    Ok, so sometimes I am a little slow, but I am having a hard time understanding my options to change my exterior door handles and badges from Chrome to Black. I don’t want to paint or cover them, is there an OEM option for both of these that are plug and play? Also, how hard is it to do yourself if you are not mr mechanic? :)
    I have a 2018 Tundra Crew Max Limited GMG
  2. Dec 1, 2018 at 10:55 AM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    You have two options for black handles. Either the flat black plastic that comes standard on SR5 models or painted black. Since you have an MGM I’m guessing you’re looking for the flat black plastic. I’d keep an eye out in the BST threads as they are pretty common. A lot of people switch them out for color matched. Or you could just buy them new from @Roman at Toyota Cool Springs or even Sparks Parts. They literally take about 5 min to change out. One of the easiest mods to do.
    Both Toyota Cool Springs and Sparks have the black emblems as well. They are a little more time consuming to install but not difficult. There’s a few threads on here with instructions for removal/ installation.
    Roman likes this.
  3. Dec 1, 2018 at 11:27 AM
    BHarry
    BHarry New Member
    Northern Nevada
    2014 BRM CM TRD
    Yep, super easy. 1 screw per handle. Just keep an eye out, people change to color matched all the time and you can get a deal on the black ones. Badges can be a little tricky, but you can also go for overlays or just remove them all together.
  4. Dec 1, 2018 at 11:34 AM
    mgxsequioa
    mgxsequioa New Member
    I just did mine in about 10 minutes....took longer to find the right bit (torx T25) than replace the handles.
    Not that i'm looking to create competition for myself in the BST forum, but don't forget about your mirror caps.
  5. Dec 1, 2018 at 11:46 AM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    Black badges are very easy. Plasti dip is super easy on them and They seem to have held up for me quite well.
  6. Dec 1, 2018 at 11:58 AM
    mgxsequioa
    Just checked out your build. Looks Great!...What type of plastidip did you use?
    Guhner123[QUOTED] likes this.
  7. Dec 1, 2018 at 12:03 PM
    TheBeast The Beach
    badge-less ;)
    Guhner123 likes this.
  8. Dec 1, 2018 at 12:03 PM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    Thanks! And you should be able to find it at any Walmart and or Lowe’s/Home Depot.
  9. Dec 1, 2018 at 12:22 PM
    mgxsequioa
    thanks for the information!
  10. Dec 1, 2018 at 2:55 PM
    Toyota Man Jeter
    Toyota Man Jeter New Member
    Bill
    Statesville, NC
    18 Crewmax XSP Blacked out badging and chrome trd tip
    None Yet
    I am seeking a place to get the black front and rear bumper covers
  11. Dec 1, 2018 at 3:38 PM
    KnuckleHD
    Same as above. Toyota Cool Springs or Sparks Parts are highly recommended options.
    Roman likes this.
  12. Dec 3, 2018 at 8:13 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
