Blackstone Lab Oil Report Results :)
Discussion in '2nd Gen Tundras (2007-2013)' started by superman86, Jan 27, 2025.
  1. Jan 27, 2025 at 12:57 PM
    superman86
    superman86 [OP] New Member
    Jonathan
    2008 Slate Metallic SR5 4x4
    So I got my results back
    I purchased my truck Oct '23 with 153,000 miles took it to Toyota right after to have it checked and had them change the spark plugs, fluids, brakes and hoses replaced.
    Heard about this on YouTube of some customers sending oil to get information about the engine.
    I drive about 5,000 a month and recently changed oil to Mobile 1 0W20 Extended Performance so i'll be sending it again sometime mid next month to see how the report will come out.
    This Report is based off Regular Mobile 1 0W20 Full Synthetic @ 190,000 miles
    Ive come from '02 Tacoma Reg, '07 XRunner, 04 Tacoma PreRunner and now this Beast!!!! I do like the New Gen Style but having this V8 everytime i drive brings a smile :) and with this report makes me want to keep it till it cant go no more.
    I enjoy the customer service writing in the comments of the report making it simple to understand how the engine is doing.
    1lowlife likes this.
  2. Jan 27, 2025 at 1:02 PM
    AZBoatHauler
    So.Arizona
    5W-30 would get your flashpoint way up. Great report.
  3. Jan 30, 2025 at 1:06 PM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Can you explain "flashpoint" and how a higher weight would help?
  4. Jan 30, 2025 at 1:06 PM
    AZBoatHauler
    So.Arizona
    Flashpoint is the temperature at which oil ignites and burns.
    Thicker oil has a higher flashpoint making it more resistant to ignition and burning. I hope that helps.
    WILLINH and 300BLK[QUOTED] like this.
  5. Jan 31, 2025 at 7:08 AM
    ryanallaire
    ryanallaire New Member
    Ryan
    2010 CM 5.7
    3" RC leveling kit, S&B intake, custom DIY exhaust, tuned for 91 octane, morimoto headlights, all LED interior lighting.
    How long have you been running 5W30? No odd engine noises?
  6. Jan 31, 2025 at 7:13 AM
    AZBoatHauler
    So.Arizona
    70k miles. Just the noise of a happier engine.
    OHwendTrd, vtl and FrenchToasty like this.
  7. Jan 31, 2025 at 7:16 AM
    ryanallaire
    Ryan
    2010 CM 5.7
    What oil do you use?
  8. Jan 31, 2025 at 7:20 AM
    2000 Limited TRD AC 4X4 Thunder Grey 277k miles. *SOLD* 2019 Limited TRD CM 4x4
    Flashpoint also increases with fuel contamination of the oil. Sometimes a sign of worn rings in the combustion chamber, or leaky injectors.
  9. Jan 31, 2025 at 7:39 AM
    AZBoatHauler
    So.Arizona
    I use Mobil1 but I don’t think brand makes a huge difference as long as you’re changing at 5k miles.
    grave likes this.
  10. Jan 31, 2025 at 9:20 AM
    ryanallaire
    Ryan
    2010 CM 5.7
    I've seen what engines look like using conventional oil versus synthetic, there's a difference..
  11. Jan 31, 2025 at 9:33 AM
    AZBoatHauler
    So.Arizona
    Who makes conventional oil still?
  12. Jan 31, 2025 at 9:34 AM
    Mother earth
  13. Jan 31, 2025 at 10:56 AM
    ryanallaire
    Ryan
    2010 CM 5.7
    Just doing a quick search, they still sell it..
    k0diak8o8 and AZBoatHauler like this.
  14. Jan 31, 2025 at 11:04 AM
    AZBoatHauler
    So.Arizona
    Sure - I guess my point was if you go to Walmart or the auto parts store 99% of the offerings will be synthetic in oils that are lighter than 10w-30.
    You can find some conventional but seems you have to seek it out. I don’t think anyone has ever made a conventional 0w-20.
  15. Jan 31, 2025 at 12:20 PM
    ryanallaire
    Ryan
    2010 CM 5.7
    My initial point was referring to comparing brands, you can't compare walmart brand oil to mobil1..
  16. Jan 31, 2025 at 12:43 PM
    Youd be surprised
    AZBoatHauler likes this.
  17. Jan 31, 2025 at 1:01 PM
    ryanallaire
    Ryan
    2010 CM 5.7
  18. Jan 31, 2025 at 1:02 PM
    AZBoatHauler
    So.Arizona
    I use Kirkland 15-40 in my wake boat. It’s $10 for a 5 quart jug.
    It gets changed out every 40 hours of run time.
    Desron23 likes this.
  19. Jan 31, 2025 at 1:35 PM
    Pennzoil Platinum high mileage 5w-30
  20. Jan 31, 2025 at 1:45 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I’ve got a couple jugs of Kirkland 5w-30 en route for an oil change on the S.S. TRDFerguson. Excited to see if it lives up to the hype.
    AZBoatHauler[QUOTED] likes this.
  21. Feb 24, 2025 at 3:50 PM
    Nemesis
    Nemesis New Member
    This had me ROTFLMAO. Damn comedians. LOL
    KNABORES[QUOTED] likes this.
