Blind spot help
Discussion in '2.5 Gen Tundras (2014-2021)' started by hocahoon, Dec 6, 2022.
  1. Dec 6, 2022 at 7:11 PM
    hocahoon
    hocahoon [OP] New Member
    Hey guys, I’m brand new and not sure where else to turn.
    i have a 2018 tundra and for the last few days the check engine light has come on and the following systems don’t function.
    Blind spot monitors
    Cruise control
    Rear cross traffic detection
    Parking sensors
    Lane detection and collision detection appear to work.
    Sounds like a fuse or wiring harness issue to me. Has anyone had anything similar?
    I’ve googled and youtubed with no luck. Any advice or wisdom would be most welcome!
  2. Dec 6, 2022 at 8:43 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Welcome to the forum! There’s a ton information on here so stick around!
    Have you had the truck since new? I ask because being an 18, if it’s the original battery, that could be the culprit as a dying battery can cause odd electrical issues.
    Also, we love pictures. Let’s see the truck!
  3. Dec 7, 2022 at 6:40 AM
    hocahoon
    See I wouldn't have even thought battery since everything else seemed fine, great idea, thank you!
    I'm not the original owner, I got it with 75k miles on it. Not a great pic, but that was on a jobsite :)
    toWaLaBv0REUlv-seHMF1wmmu9wXQwCXwN2kP_6v_515243c6265cbc94c8dc09867d332633c6dbe070.jpg
  4. Dec 7, 2022 at 6:47 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    What code?
  5. Dec 7, 2022 at 6:47 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Nice! Yeah have the battery tested just to rule it out. I got a lot of weird gremlins when my battery was dying. It was covered by warranty too.
  6. Dec 7, 2022 at 6:52 AM
    hocahoon
    Actually have a code reader arriving today so I can pull the code. I'll post it back as soon as I can, thanks for the help guys!
    Jaypown likes this.
  7. Dec 7, 2022 at 1:25 PM
    hocahoon
    So an update
    I did indeed need a new battery, good call! Replacing the battery made the cruise and parking sensors work again, but still no blind spot monitors or rear traffic alert.
    The error codes were related to the gas cap not being completely closed, so I cleared them.
    Anybody got any ideas lol?
    Saltyhero13 likes this.
  8. Dec 7, 2022 at 1:28 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Yep, low or bad battery does all sorts of odd things with Tundras. Now that the battery is sorted, make sure those functions are turned on, buttons for each. And I would check the fuses for both systems, check both under dash and under hood.
    Jaypown and 1lowlife like this.
  9. Dec 7, 2022 at 1:57 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    BSM fuse is ECU-IGI NO 4
    Oddly enough your cross-traffic alert is on the same circuit.:D
    Checking that would be a start.
    As @frichco228 stated make sure they are turned on too..
  10. Dec 7, 2022 at 2:04 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Dumb question:
    Did you go into the vehicle settings in the instrument cluster and make sure BSM and RCTA are turned on? They don't have a physical button on the 18+ trucks.
    Edit - just saw others suggested the same.
  11. Dec 7, 2022 at 2:08 PM
    hocahoon
    Yeah mine turn on via the cluster in the center, they're both off and I can't toggle them back on.
    @1lowlife Where did you find that schematic sir!? I've been googling poorly apparently, thank you so much man.
    RainMan_PNW likes this.
  12. Dec 7, 2022 at 2:11 PM
    1lowlife
    DADA
    2014 MGM DC SR5
  13. Dec 7, 2022 at 2:38 PM
    hocahoon
    Just pulled that fuse, it’s not blown
