Blinker acting like the bulb is out
Discussion in '2.5 Gen Tundras (2014-2021)' started by RW-3, Feb 27, 2018.
  1. Feb 27, 2018 at 1:42 PM
    RW-3
    RW-3 [OP] May the Mods be with you
    Rob
    16 Black TRD CM 4x4
    Lights: 2018 OEM Black Chrome LED’s Morimoto XB Fogs Interior LED upgrade - VLED’s LED reverse / cargo - VLED’s Footwell lights, vanity lights, break lights, rear turn signals, 3rd break light - All VLED’s 30” Rough Country light bar hidden in bumper w/ Rago Fab Brackets Matt Gecko LED bed lights (red & white) and hood lights Exterior: Truxedo Lo Pro QT WeatherTech in-channel window deflectors Interior: Husky X-Act Contour front & rear Front, back and rear windows all tinted 10% Ceramic Heat Film on Windshield 70% OCD console organizer OCD console tray TRD 4x4 inserts on Husky mats by Achuop Tacoma TRD Pro shift knob with TRD leather boot AJT Design vent ring trim - chrome delete Center console wireless charger Drivers side grab handle Performance: Dirty Deeds BA Muffler 12” Budget Standard System TRD Rear Sway Bar AFE Pro Dry S Air Filter Bilstein 6112 1.9” clip Bilstein 5100 - rear Coachbuilder +1’s Nitto Ridge Grapplers 285/70/18 Audio: Infinity dash speakers Tech12Volts custom center dash speaker Hertz Uno door speakers JL Audio RD 900/5 amp 2 JL Audio 10w-0 v3 10” subs in custom Tech12Volts box Protection: McGuard Tailgate Anti theft lock OEM tailgate lock w/ Dynamat TRD Pro skid plate SNS ARB sensor guards Misc: TRD key fob case AJT Designs Rear diff breather mod Fortin remote start with Car Link CL6 TRD battery bracket by Coupe TRD valve stem caps TRD interior handle inserts by abomb60 (Adam)
    My retros are in the shop so I had to put the original headlights back on. I left all the wiring for the retros I just pulled the fuse. When I put my right turn signal on, both the front and back light up and blink normal for a bit, then all of a sudden it starts blinking really fast as if the bulb is burned out, yet both front and back are blinking really fast. This only happens on the right side. I did do the DRL delete mod for the retros and didn’t plug that back in before I put the originals back on. Has anyone else experienced this?
  2. Feb 27, 2018 at 1:58 PM
    RW-3
    Rob
    16 Black TRD CM 4x4
    I was kinda thinking the same thing but inaske the retro guru if that DRL delete would cause this and he said no.
    SouthBoundSteve likes this.
  3. Feb 27, 2018 at 2:01 PM
    RW-3
    Rob
    16 Black TRD CM 4x4
    I put vleds in the rear but that was about a month ago. This just started when I put the orig headlights back on. The blinker, side marker and headlight on the front is all halogen.
  4. Feb 27, 2018 at 2:14 PM
    RW-3
    Rob
    16 Black TRD CM 4x4
    Haha! Are you saying since I have led’s on the rear turn signals I need resistors on them? I was not aware of that. Thought led’s were plug and play (except headlights) that draw less power
  5. Feb 27, 2018 at 2:16 PM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    Yep you need resistors thats probably ur issue. Also make sure the bulbs are seated properly in the stock housing.
    Les7311, SouthBoundSteve and RW-3[OP] like this.
  6. Feb 27, 2018 at 2:17 PM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Leds and halogen draw differently so the truck thinks the bulb is out because the led doesnt use much power.
  7. Feb 27, 2018 at 2:19 PM
    RW-3
    Rob
    16 Black TRD CM 4x4
    Well damnit! I feel like a moron!! But, you learn something new every day right? At least that’s what I’ll keep telling myself! As always, thanks for the input gentlemen. :anonymous::bowdown:
  8. Feb 27, 2018 at 2:21 PM
    RW-3
    Rob
    16 Black TRD CM 4x4
    Since we are on the topic, have y’all put led’s in for the front turn signals? I was looking at VLEDs turn signal bulb and it said not to use them if you had DRLs. Should I be looking at DRL bulbs or turn signal bulbs?
  9. Feb 27, 2018 at 2:24 PM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    I had the vleds def pricey but worth it. Make sure u get their resistors with it.
  10. Feb 27, 2018 at 2:25 PM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    I learned the same way with the leds, on my camaro.
  11. Feb 27, 2018 at 2:26 PM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Did you do the drl delete?? Id call the company and ask to make sure.
  12. Feb 27, 2018 at 2:27 PM
    itsdchz
    itsdchz 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
    Wanted to chime in. I had the same issue on left turn signal this weekend. Worked fine, then after shopping at Costco, came out started car and for that 15 min trip the left blinker hyper blinked. Only during that one keystart did it happen, and havent been able to get it to replicate.. Again, all my lighting is stock for turns and headlights/taillights.
  13. Feb 27, 2018 at 2:36 PM
    RW-3
    Rob
    16 Black TRD CM 4x4
    Thanks. I did do the DRL delete so I’ll give them a shout after my wallet recovers. The vleds are expensive as shit but top of the line. Hate that I just had to fork out another $30 for the resistors. Some of the interior lights and footwell lights aren’t so bad on the price though. Love my footwell lights!
  14. Feb 27, 2018 at 2:39 PM
    RW-3
    Rob
    16 Black TRD CM 4x4
    that’s odd if all the lights are factory. May want to double check that nothing is blown and like @darkknight2014 said above, make sure it’s all seated correctly.
  15. Feb 27, 2018 at 2:44 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    @RW-3 I have vled V6 up front and I love em. Super bright. Also have leds up front and I’m running a 3ohm resistor per side.
    RW-3[OP] and SouthBoundSteve like this.
  16. Feb 27, 2018 at 2:45 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Haha they are Serius lights from Amazon. I didn’t need resistors with stock front but once I put leds up front a 6ohm resistor wasn’t enough per side so I had to up it to 3ohm per side.
  17. Feb 27, 2018 at 3:14 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Not anymore! Now you don’t have a reason! Unless you want to wait for a sale. They always have 20% off sale.
  18. Feb 27, 2018 at 3:15 PM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    ok I have Vled brake and reverse rears, no issues and just did a bulb swap....am I going to have an issue? or is it just turn signals
    Kwikfish likes this.
  19. Feb 27, 2018 at 3:36 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    That ones in stock too. Buy now :rofl:
  20. Feb 27, 2018 at 3:57 PM
    RW-3
    Rob
    16 Black TRD CM 4x4
    Based on what I’ve learn by asking this question, you should be fine. I’ve had led’s in my reverse lights since I bought it 2 years ago. This is only an issue on blinkers because they draw such little power, the truck thinks there’s not even a bulb there. I’ve had led break lights the same amount of time as the blinkers with no issues.
  21. Feb 27, 2018 at 6:47 PM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Will that work in the 2018 head lights?
  22. Feb 27, 2018 at 6:49 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Yes I’m running them on 18 headlamps. But you need to repin the signal back to stock and use your old bulb socket.
  23. Feb 27, 2018 at 7:08 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
  24. Feb 27, 2018 at 10:10 PM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
  25. Mar 3, 2018 at 8:27 PM
    RW-3
    Rob
    16 Black TRD CM 4x4
    Installed the resistors today and Found something interesting. Disclaimer - I know next to nothing about electricity hence the reason for this thread. My passenger blinker was hyper flashing so naturally I installed the first resistor on that side. Checked the blinker after install and it still hyper flashed. After I installed the resistor on the driver side the hyper flash issue was resolved. Just thought it was weird that adding a resistor to the driver side fixed the hyperflash on the passenger side.
    On a side note, tapping the wires with the resistor from vled was a pain in the ass!!! The tap wouldn’t properly close and I ended up having to use electrical tape to keep it securely connected. Expected better from vled. They are usually top notch but this kinda fell short imo.
  26. Mar 3, 2018 at 8:30 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
  27. Mar 3, 2018 at 8:33 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Order yet?
    You might have a bad connection.
    Right!?
    RW-3[QUOTED][OP] likes this.
  28. Mar 3, 2018 at 8:41 PM
    RW-3
    Rob
    16 Black TRD CM 4x4
    Bad connection where?? As soon as I tapped the drivers side with the resistor, the passenger side stopped hyperflashing. I never touched the passenger side after installing the driver side except to put the screws back in the taillight.
  29. Mar 3, 2018 at 8:42 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I didn’t read it properly. Thought you still have hyperflash. I’m saying it probably wasn’t making good contact which is why it was still hyperflashjng.
  30. Mar 3, 2018 at 11:08 PM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Not yet brotha lol, i just recently purchased a ss trd dirtydeeds exhaust. Gotta rebuild the mods funds lol. Its def next on my todo list love how bright they are.
    BlueBottle[QUOTED] likes this.
