Blinkers and reverse lights keep blowing fuses?
Discussion in '1st Gen Tundras (2000-2006)' started by vst, Nov 21, 2023.
  1. Nov 21, 2023 at 6:36 PM
    vst
    vst [OP] New Member
    Scott
    East TN
    2005 DC 4wd
    Anyone have this issue before my blinkers and reverse lights weren't working found the gauge fuse under the dash was blown so I swapped it and when the truck is in park the blinkers will work but as soon as I put it in reverse it blows the fuse. I checked the reverse bulbs one looked maybe blown so I took it out but haven't replaced it yet. I put another fuse in and still popped. Does the bulb have to be in? Anyone have this issue wondering what else I should check and where? Thanks
  2. Nov 21, 2023 at 7:43 PM
    Yep, a few members have had it happen. And in more than one case, it was due to rear tail light housing bulb sockets being effed up.
    I take it you have factory 7-pin trailer receptacle, and havent spliced in any stuff back there?
    Nobody used stupid shit like scotch-locks on your rear wiring or anything?
    Do you happen to have anything tapped into the reverse feed, like a backup camera?
    Sorry for the peppering of questions, just want to cover all the 1st bases that come to mind which may help isolate the issue.
  3. Nov 22, 2023 at 5:15 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I had to replace one of the taillight harnesses in my truck after it developed a short and partially burned.
  4. Nov 22, 2023 at 6:44 AM
    vst
    vst [OP] New Member
    Scott
    East TN
    2005 DC 4wd
    Yes I have a back up camera and it has 2 splices on the drivers side taillight. I cut them last night to see if that’s what was causing it but still was blowing fuses. Nothing spliced in on the 7 pin.
  5. Nov 22, 2023 at 6:45 AM
    vst
    vst [OP] New Member
    Scott
    East TN
    2005 DC 4wd
    Is the harness just a matter of unplugging the old and replacing with a new?
  6. Nov 22, 2023 at 6:48 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I can't find the thread but one guy had a short in the wiring under the bed..
  7. Nov 22, 2023 at 6:50 AM
    Before that ...
    If I were you, just to isolate the issue ... Near the end of the driver's framerail, just to the outside, it's where the main harness run for all assend activities happens. A grey plug, I think 6-8 wires in it. "Combo plug" or whatever.
    Disconnect that. Replace fuse. Try again. If it's still blowing, you'll know it's between the cab and that connector, versus "somewhere on the chain". It should be obvious which wire harness is correct, and if you've never popped it free, be patient, it may take a sec.
    Edit -> What 1LL above is talking about is what I'm trying to help you find. All the wiring runs from cab to rear down the driver's side framerail(ish). If you unplug that main harness before it gets to the lights, and nothing is connected out back but it blows, you may have the same issue as that dude. Great minds think alike...
    vst[QUOTED][OP] likes this.
  8. Nov 22, 2023 at 6:52 AM
    vst
    vst [OP] New Member
    Scott
    East TN
    2005 DC 4wd
    Cool good idea I’ll check that out thanks
  9. Nov 22, 2023 at 7:29 AM
    bfunke
    South Carolina
    Yes
  10. Nov 24, 2023 at 7:15 AM
    vst
    vst [OP] New Member
    Scott
    East TN
    2005 DC 4wd
    Just updating found my issue a wire I’m assuming for the back up camera got wedged some how in the e brake pedal adjustment nut and was shorting out every time the camera would come on being connected to the rear back of lights for power it was blowing the gauge fuse. Happy to have found the issue after checking all connections in the rear around the brake lights
    TX-TRD1stGEN, shifty` and 1lowlife like this.
  11. Nov 24, 2023 at 7:26 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Glad you found it..
    Perhaps others will find this thread and it will help them..:thumbsup:
