Blower motor fan speeds
Discussion in '1st Gen Tundras (2000-2006)' started by AV8R4AA, Aug 18, 2019.
  1. Aug 18, 2019 at 9:37 AM
    AV8R4AA
    AV8R4AA [OP] New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    I’m writing this because I want to change my blower fan speeds.
    I know that position 4 is straight battery voltage (WFO)
    Any detent less is run through a resistor. The slower the fan speed, the more
    Resistance. (More heat also)
    I’m not happy with the first 2 settings. They are not enough flow.
    Position 3 is good but noisy. Position 4 is very noisy, but effective.
    I tried a exact same size blower motor resistor unit that is for a MercedesBenz of 5he same
    Year. It physically fits, but does not wrk the same. Position 1 and 2 are better flow, but there is no change between 1 and 2.
    I have cleaned the evaporators box to shiny clean. There is no blockage.
    Just wanting better flow down low.
    Anyone else try this?
  2. Aug 18, 2019 at 1:34 PM
    bajaphile
    bajaphile New Member
    Solana Beach, Ca
    2001 4x4 Limited
    Icon Coilovers, Icon AALs, JBA headers, 285/75r16 BFG KO2s
    Sorry, I don't know the answer to your question, but how difficult was it to clean the evaporator? I think mine is clogged, or something... seems like a cup of water drains out of there every minute.
  3. Aug 18, 2019 at 2:24 PM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    If you take out the blower resistor, you can look right in there.
    I used Home Depot quality of home Air Conditioner “coil clean”
    It foam up inside box like shaving cream. Then I used a garden hose to flush out.
    Let it sit and loosen dirt for 5 minutes.
    Should drain out the evaporators box drain.
    MAKE SURE IT DRAINS!!!!
    roll the hose between your fingers to loosen up the crustys and goo.
    Should pour water out when it’s clean.
    Gets rid of AC skank smell also.
  4. Oct 6, 2019 at 9:50 AM
    Professional Hand Model
    Hand Protectors
  5. Oct 2, 2021 at 12:05 PM
    Em1
    Em1 New Member
    2020 Toyota Tundra 1794 Edition with TRD Off Road Package
    Motors & resistors are usually designed in conjunction, if it's a multi speed motors as it is in cars than the board os programmed to that specific resistor, it will not work if it doesn't see one of the progranmed resistance values, so changing out complwte motor with variable resistor that works with variable speed motors, although ot3possible but not fwasable to do on cara do to cost, design etc.. Since you would need a control module on thos case on cars it's ac control module that would talk with variable motors board or another name ecm, but since you're saying it's noisy & you don't get enough air flow I would roll all the way back & start with eisiest, hvac air handling filtet or cabin filter on cars if car is aged & you live on leafy dirty environments than almost guaranteed yoir evap coil is pretty dirty plugged inside hvac air handling box especially if changib cabin filters at least twice a year was neglected than there goes your answer. I've been master mb tech for over 15 years, now I'm a Union HVAC tech, o and anyone that own early years 2015 Ford Transits kerp in mind tgat Ford forgot to install Cabin filters in the factory so a load of tranaits have lots of failing evap coils due to oxidation & eventually rotting & leaking r134a into the cabin I'm syill surprised there was no class action law suit in that one the FU*****G OLD ROTTEN DEVIL as I would call it. Cheers.
  6. Oct 2, 2021 at 12:35 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Holy thread revival! That prior post is over a couple years old.
    I don't think the early tundras are quite that complex requiring the ECU to see the correct current through the blower resistor to operate correctly as you're suggesting. I believe its just a simple multi-tapped resistor that limits the current through the winding of the coil of the blower motor.
    BubbaW likes this.
  7. Oct 2, 2021 at 2:08 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I could see a bank of computer fan motors making a difference at 12v. Hardwired off the battery to a ?rheastat? Knob.
    Especially if circ is on.
  8. Oct 2, 2021 at 2:26 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Yep, as simple as ohm's law !
  9. Oct 2, 2021 at 3:44 PM
    Jack McCarthy
    Bill
    North of Boston
    But they have to be the expensive military grade ones that spin at 20,000 rpms so you feel like your sticking your head out the window at 75 mph. :D
  10. Oct 2, 2021 at 3:50 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    A ducted fan from a hair dryer is pretty impressive.
