Blue Sea fuse box questions
Discussion in 'Electrical' started by Tundra234, Jun 18, 2022.
  1. Jun 18, 2022 at 7:11 AM
    Tundra234 [OP] New Member
    Looking to clean up the engine bay and get some of the power leads off of the positive battery terminal. I am looking at the Blue Sea 12 circuit with negative terminals. Here is what I am running currently from the pos terminal.
    4 guage for stereo
    Baja Designs light bar in the hood bulge
    Light bar in the bumper
    Power for the 3W Liners window module
    Power for air compressor for horns
    Power for front camera
    I will have 4 guage from the post to the fuse block, and 4 guage to ground. If I'm thinking correctly, the 4 guage for the stereo will have to remain on the battery. Also, does the negative from the Blue Sea connect to the battery negative post or to a chassis or fender ground? Thanks
    Wallygator likes this.
  2. Jun 18, 2022 at 7:29 AM
    Wallygator
    I have used a Blue Sea 12 under the hood on two vehicles and currently have one in my battery box. I think the chassis is the preferred place. I put it on the chassis ground right next to the battery (on the inner fender) if under the hood and have it ran to the frame from my battery box currently.
    You also need a circuit breaker in between the fuse block and the battery, I use this one (see link) cuz my power needs are/were never above 100 amps. The circuit breaker also makes it easy to add new things to the block, no need to unhook from the battery, just flip the switch on the circuit breaker. Add up all the things you will connect to it to see what your power needs will be.
    Blue Sea also has some good articles on choosing the proper size but I cannot access them here at work. Just google and you should be able to find them. Hope this helps.
    https://www.amazon.com/Blue-Sea-Sys...locphy=9010331&hvtargid=pla-571733390118&th=1
  3. Jun 18, 2022 at 7:42 AM
    Thanks for the reply. After I posted, knew there was something I was forgetting....that circuit breaker lol. I did see links regarding sizes...I'll check it out. Now to figure out where I want to mount it. I don't think there is enough room on the fender well.
    Wallygator[QUOTED] likes this.
  4. Jun 18, 2022 at 7:50 AM
    Wallygator
    Have used the fender well before on a Tacoma and it was awkward getting to the block. Did use velcro and mounted it on the factory fuse block on another vehicle. On my LC I built a mount that was above the battery, worked ok.
    On my 4Runner I bought a mount from a fabricator that bolted to the inner fender well that fit the block and the circuit breaker, it was the cleanest and easiest method I have used so far. Have been contemplating getting a switch pro for the Tundra and would probably again mount it to a fabricator made mount of some sort.
  5. Jun 24, 2022 at 5:05 AM
    One of the guys on the forum sent me a link to a mounting plate. Worked out very well.
  6. Jun 24, 2022 at 5:25 AM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    12” Bulletproof Lift, AFE CAI, AFE Exhaust, rock lights, Fas-Top tonneau and soft topper, Dasaita 10.2” radio, light bar, ditch lights, LED headlights and fog lights, LED interior lights, Amp Research rear bumper step, dashcam, BT ODBII reader and Torque app on radio
    What link is that?
    I used a plexiglass to mount mine, but would like to convert to this.
  7. Jun 24, 2022 at 5:27 AM
  8. Jun 24, 2022 at 8:38 AM
    Wallygator
  9. Jun 24, 2022 at 9:44 AM
    MULLI63
    MULLI63 New Member
    Southern California
    2015 Tundra Platinum, SnugTop Shell, Gray
    Bilstein 5100 all four corners - front at top setting Ready Lift 1” rear block 295/70R18 Falken Wildpeak Method Roost R18 Under Seat Storage Boxes - Rear Seats - see post LED Interior Lights LED Mirror, Back-Up and License Plate Lights Added Auxiliary Fuse Box and Battery Switch Plasti-Dip Chrome Mirror Covers and All Badges to Black WeatherTech Bed/Tailgate Liner Replaced tailgate strut Working On Modifications: Add Oh Sh!t Handle To Driver Side A Pillar LED Head and Fog Lights
    Anyone see a down side of using this switch (see link) instead of the much more expensive circuit breaker? My thought is that each of the circuits already have fuses so no need to have another “fuse” in line. I just want to make it easier to disconnect the battery when installing new circuits.
    CoCsmart Battery Disconnect Switch, 12V-48V Battery Isolator Switch Master Power Cut Off Kill Switch Waterproof Marine Switch for Car RV Boat Truck ATV Vehicles https://a.co/d/c0LgOh0
    Just to clarify my use would be between the battery and the additional fuse box in place of the circuit breaker. Will look into using it to disconnect the battery from all connections but need to investigate that more.
  10. Jun 24, 2022 at 10:01 AM
    Wallygator
    I don't know about that disconnect switch, so that is above my pay grade, but I have always done it this way(see link). It may be redundant in some ways but the circuit breaker will protect in other ways and it also serves as a battery cut off switch.
    This is just a generic video I randomly found and I'm sure there are better.
    https://www.google.com/search?q=12v...nt=gws-wiz#kpvalbx=_fOy1YuS5KJHJkPIP9PeP-A467
    Tundra234[OP] likes this.
  11. Jul 8, 2022 at 8:58 AM
    So looking at the full Blue Sea kits that OE sells, they connect power and ground with 8 gauge cables. I am installing mine with 4 gauge. Is that too big? Another question that I have is regarding the light bar harnesses that are going to be wired to it. The harnesses are really long so there is some extra wire that is bundled up. Since I am trying to clean it up, I am looking at shortening them. I need to mount the relays first. It looks like I might have to shorten them on the firewall side and also extend them between the relays and the connections at the lights.
  12. Jul 8, 2022 at 9:16 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Going heavier gauged wire should be fine. Provides less resistance per foot of wiring.
  13. Jul 8, 2022 at 10:20 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Might as well upgrade the Big 3 while you're at it.
  14. Jul 8, 2022 at 10:30 AM
    Isn't there a kit for that one? How much of a difference is there?
  15. Jul 8, 2022 at 11:01 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
