Bluetooth issues since iOS 13 upgrade
Discussion in 'Audio & Video' started by mike90, Oct 24, 2019.
  1. Oct 24, 2019 at 10:25 AM
    mike90
    mike90 [OP] New Member
    Has anyone else had issues with their truck dropping the phone from bluetooth? I have a 2019 Tundra with the Entune system. I use an iPhone with 13.1.3 software on it. Every since the iOS 13 upgrade I'll be on my phone via bluetooth in the truck and then the truck just disconnects the phone. Lately it's been hanging up the call completely. Getting very frustrating. I feel like it's something with the truck since all my other bluetooth devices like headsets stay connected to my phone. It's only the truck that disconnects.
  2. Oct 24, 2019 at 11:35 AM
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    I have a 2018 and mine dropped from Bluetooth last weekend since the update. I just turned the radio off and it reset and picked the phone back up. Haven't had any other problems.
  3. Oct 24, 2019 at 11:44 AM
    superslif
    superslif New Member
    NE. Ohio
    2014 Tundra Double Cab 5.7 Limited
    Firestone bags, Toyota tow mirrors, TRD sway bar
    My 2014 seems to do that once a year. Now I did have a issue the first 5 years where the whole radio / nav unit would cutting out / and have to re-boot. Sometimes it wouldn't do it for 3-4 months, other times it would do it 3-4 times a day. The Toyota service department just says for $250 you could get a Nav update. But either on this website or Tundra.net there was a SB (service bulletin) post for this issue. Not until I told them (Toyota Service writer) about the SB number, did they go ahead and get it fixed. For free...go figure...
  4. Oct 24, 2019 at 11:57 AM
    19TRDPRO_FL
    19TRDPRO_FL New Member
    Paul
    Parkland, FL
    2019 Tundra TRD Pro
    Audio: Pioneer 8200NEX Infinity Kappa complete speaker package 4 Channel Kenwood amp 5 Channel Kenwood amp 10 inch JL Audio W1 shallow mount sub X 2 Readylift Pro Plus 4in lift (6 total) 22x12 Fuel Sledge wheels 35x12.5R22 Nitto Ridge Grapplers LED bar in hood scoop LineX step rails
    Does this have an effect on the hot spot as well?
  5. Oct 24, 2019 at 12:00 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  6. Oct 24, 2019 at 1:36 PM
    timsp8
    NY
    Try to completely remove the link from your phone and the radio. Then redo the pairing. That fixed my issue after iOS 13.
  7. Oct 24, 2019 at 1:42 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
  8. Oct 24, 2019 at 1:46 PM
    hogpiolet
    hogpiolet New Member
    Jimmie
    2018 tundra Platnium
    none
    No problems here
  9. Dec 1, 2019 at 8:25 AM
    jrmymllr66
    jrmymllr66 New Member
    2016 Crewmax TRD Pro
    I just deleted the Scout GPS app from my phone and have had no problems since.
  10. Jan 14, 2020 at 6:18 PM
    Rkj1432
    Rkj1432 New Member
    ‘19 TRDPRO
    Having the same issues everyone else is but deleting the entune app didn’t work for me. If I turn off Bluetooth on my phone the radio works fine. But as soon as I turn it on again it is in a death cycle of rebooting nonstop. Have had the phone and the truck since July and never a problem. Just started last week. iPhone X and ‘19 TRD pro. The toyota downloads show no updates for my truck.
  11. Jan 14, 2020 at 6:51 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Have you tried nuking Apple Music like in the linked thread? Any apps get installed on your phone recently, or even updated?
  12. Jan 15, 2020 at 3:54 AM
    timsp8
    NY
    Did you also try to completely remove the pairing and re-pair it?
  13. Jan 19, 2020 at 12:34 PM
    johnchabin
    johnchabin New Member
    2014 TRD Tundra
    Bilstein 6112 Series Suspension Kit set @ 2" lift CB 0.25" Strut Shims Bilstein 5160 rears CB +2 Shackles Total Chaos UCA Diff Drop Method Grid w/ 295-70R18 Magnum front & rear bumpers
    I have the same problem. The software update starts, then fails with the message, "There is no new software or the media is not inserted."
    Entune sucks.
  14. Mar 5, 2020 at 6:27 AM
    beaverfood
    beaverfood New Member
    I have a 2019 Tundra 1794, and on a recent 2 hour trip, (while listening to a police scanner on my iPhone via bluetooth) my infotainment system rebooted 2-3 dozen times. I took it in to have the dealer look at it. They installed a software update. A few hours after I picked it up, it failed again. I can make it fail by changing the source from Bluetooth to FM radio. Anyway, today, they told me it may be my iPhone and that I need to make sure my iPhone software is up to date. It is, at 13.3.1. Then they told me to delete the iPhone from the Tundra, along with any personal radio settings, which I did. I rebooted my iPhone and the Tundra. This did NOT fix the problem.
    Things seem to work normally, when connected via USB cable.
  15. Mar 5, 2020 at 2:56 PM
    johnchabin
    2014 TRD Tundra
    I can only use the USB cable with my iPhone. Bluetooth crashes the radio over and over. The radio firmware update via USB fails.
    Entune sucks.
  16. Mar 6, 2020 at 6:09 AM
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    Can you pst that? does it pertain to my 2014 with JBL (Junk Broken LowQual)
  17. Mar 6, 2020 at 8:18 AM
    johnchabin
    2014 TRD Tundra
    The USB update starts out and the progress bar gets stuck:
    After some time, I get the message, "There is no new software of the media is not inserted."
    The update doesn't work and I can't use bluetooth anymore. I will not pay the dealership to update my stereo a second time.
  18. Apr 21, 2020 at 7:20 AM
    markman03
    markman03 New Member
    Mark
    2019 Tundra Limited
    I removed itunes and the apple music store. Reset the network setting and repaired. So far so good.
  19. Apr 21, 2020 at 7:42 AM
    Kung
    KG, VA
    New truck, and I've had no issues.
  20. Apr 21, 2020 at 9:01 AM
    markman03
    Mark
    2019 Tundra Limited
    Do you have apple car play?
  21. Apr 21, 2020 at 11:56 AM
    Kung
    KG, VA
    I do, but I've also used the regular old Entune BT connectivity; I've had the occasional crackle, but aside from that, no issues.
