Boat on the ramp
Discussion in '3rd Gen Tundras (2022+)' started by fastarget, Mar 27, 2024.
  1. Mar 27, 2024 at 7:54 AM
    fastarget
    fastarget [OP] New Member
    Had our fishing boat on a steep ramp at lake Powell. Wife pulled us out slightly and put the transmission into Park. So, on a steep slope I know it was loading the truck in reverse. When I got in the vehicle to pull out the rest of the way, went into Drive but the truck would not move, actually it felt like it wanted to go in reverse. Went back to Park, waited for the brake to engage then back to Drive, same thing. Felt like it wanted to move backward. Did the routine 2 more times, then I thought of shifting it into 4H. On the 5th attempt, we moved forward and all was well.
    So, what is the best way to avoid this and even better, what is the best way to resolve it if it was to happen again. Would hate to experience that every time we go fishing.
  2. Mar 27, 2024 at 7:58 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Sounds like the rear tires were slipping if going into high range fixed it.
    I always put the truck into 4wd when going down the boat ramp. Once the rear tires hit water and slim they're essentially useless and you're just relying on the fronts.
    Mater likes this.
  3. Mar 27, 2024 at 7:59 AM
    I would engage the parking brake first, then shift to park. I do this with all my automatics on any incline or when loaded(or both).
    I messed up once with my Allison transmission and did something similar. I couldn't get the truck out of park. Ended up uncoupling the gooseneck and was able to shift, then couple the trailer back up.
    Can't imagine that would be an option on the boat ramp. :eek::D
  4. Mar 27, 2024 at 8:00 AM
    Breathing Borla
    Northern Illinois
    I would start with the recent trans recall, and go from there
    Bannerman and BlueCrushSC16 like this.
  5. Mar 27, 2024 at 8:00 AM
    fastarget
    Rears were not slipping, looked at them and the kids were watching, it actually wanted to torque backwards. It never engaged 4H even though I tried.
  6. Mar 27, 2024 at 8:01 AM
    Breathing Borla
    Northern Illinois
    once you have a huge load on the drivetrain, its not really going to want to go into 4 hi.
    I would go 4 hi before you even start any of this
    Chugbug, Gene_in_FL, aj350925 and 2 others like this.
  7. Mar 27, 2024 at 8:01 AM
    fastarget
    I thought it engaged the parking brake automatically when you put it into Park?
  8. Mar 27, 2024 at 8:02 AM
    fastarget
    Good advice, I shall do that regardless of conditions, it has never done that before.
  9. Mar 27, 2024 at 8:03 AM
    Breathing Borla
    Northern Illinois
    it does or should. I just wonder if you had a huge load on the truck and it put on the parking brake in this situation and then had difficulty releasing under that load.
    hard to tell without seeing what happened.
    fastarget[QUOTED][OP] likes this.
  10. Mar 27, 2024 at 8:04 AM
    I'm not sure in that one, but can you but the parking brake on in neutral first, then shift to park?
    GODZILLA likes this.
  11. Mar 27, 2024 at 8:10 AM
    Breathing Borla
    Northern Illinois
    you can also read the manual about the hill hold assist button, I havent messed with it that much and see if that can apply
  12. Mar 27, 2024 at 8:21 AM
    sandiegosteve
    sandiegosteve New Member
    San Diego
    24 Limited TDR Lunar Rock
    That is the default setting, but I think I read in the horribly written manual that when on an incline, you should press the parking break button before shifting. That might be something to try. There are enough videos of boat ramp issues where the parking paul broke because the brake wasn't set on all kinds of vehicles. So I make it a habit of setting the parking break first. That was easier on my prior vehicle since you set it with your left foot...
  13. Mar 27, 2024 at 8:27 AM
    BriannaSTILLEN
    BriannaSTILLEN New Member
    Brianna
    Definitely use 4 hi. I used to back the boat down @ Pleasant and other AZ lakes using a Ram 3500 dually and never needed it (that thing was a beast) but as soon as I used a Ram 2500, the wheels would slip and going up was a bit of a chore. Can't imagine using a Tundra in 2wd. But also depends on the size of your boat.
  14. Mar 27, 2024 at 8:42 AM
    DRP
    DRP Old Member
    Dave
    I don't think this feature is set by default. With your foot on the brake, pull the parking brake switch and hold for 3 seconds. This will activate that feature. If it is on, make sure you keep your foot on the brake for a few seconds after you put it in park. This gives the parking brake time to fully engage. And lastly, when you are ready to put it in drive to go back up a steep ramp, keep your left foot on the brake when putting the truck in drive. That way your right foot can be on the gas immediately in case it's needed. I also agree that putting it in 4 wheel drive before backing down is a fine idea.
  15. Mar 27, 2024 at 10:09 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
  16. Mar 27, 2024 at 10:27 AM
    I hear that the truck likes to start in 3rd gear for efficiency's sake. Maybe selecting 1st gear manually would help with your ramp woes. I've never needed 4wd on our boat ramps with my older 2.5 gen, but there's a decent amount of weight over my back axle being a CM with a campershell.
  17. Mar 27, 2024 at 10:31 AM
    fastarget
    Excellent, yes, told my wife that is what to do from now on , and not even shift into P the next day and we did not have the same issue...........I wondered if that handbrake would not disengage. In the Platinum model like ours , when you go to Park, the Brake light comes on on the dash after a few seconds, but it does have the manual option button on the dash as well.
  18. Mar 27, 2024 at 10:32 AM
    fastarget
  19. Mar 27, 2024 at 10:56 AM
    sandiegosteve
    San Diego
    The good news is that the break will disengage automatically. In my old vehicle, I used to see the gas door pop open and I knew they were looking to get the parking break off.
    I also read "neutral" and got worried. I often launch my boat alone and was thinking unattended in N at the ramp. Don't do that unless you are recoding...
  20. Mar 27, 2024 at 12:18 PM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    Never had issues on the boat ramp with a 2wd pickup..
    ghunter321 likes this.
  21. Mar 27, 2024 at 12:33 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    Oh, it would but we would need a video and some popcorn and beer to watch from our armchairs...
  22. Mar 27, 2024 at 1:24 PM
    CMikeB
    CMikeB New Member
    Park brakes are a lot like Owner's Manuals; there but seldom used.:D
  23. Mar 27, 2024 at 2:52 PM
    Breathing Borla
    Northern Illinois
    some of the less used ones around here are slick as snot, 4wd is a must.
    especially depending on the size and set-up of the boat which is the amount of suction while you try and pull it out
    AZBoatHauler likes this.
  24. Mar 28, 2024 at 4:57 AM
    CMikeB
    CMikeB New Member
    Nothing but common sense.
