Body mount chop
Discussion in 'Wheels & Tires' started by Davknz, May 3, 2020.
  1. May 3, 2020 at 10:12 AM
    Davknz
    Davknz [OP] New Member
    David
    Orange County ca
    2018 sr5 Trd 4x4 crewmax tundra
    Level kit
    Is bmc really required for 35’s or 285/75r18 ? I thought I saw a thread someone running 285 with 5100s on middle setting and that’s it no other mods. I’m in the market for some new tires and have 5100s middle setting and def wanna run 285/75r18 (34.8”x11.2”) I saw other thread on max tires per lift but thought I’d ask anyway . Thanks
  2. May 3, 2020 at 10:13 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I ran 35s and was fine. Just moved into 37s and got a BMC!
    BlackSheep likes this.
  3. May 3, 2020 at 10:15 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    My 35s was on 20” wheels and my current 37s are on 17” wheels.
  4. May 3, 2020 at 10:16 AM
    Davknz
    David
    Orange County ca
    Level kit
    I was hoping so thanks
  5. May 3, 2020 at 4:49 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    It really depends on the setup including lift, offset, rim/tire size etc.
  6. May 3, 2020 at 5:23 PM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    Yes, offset is key, as well as your caster, and how much you plan to flex out the suspension. Also important is the specific measurements of the tire you want, as not all 35s are created equal. I went with 35x12.5x17 BFG KO2s on a completely stock Tundra with Rock Warrior wheels (+50 offset) and was totally fine. Others have had to do BMC with 295/70/18, which are like 34.25"x11.5". So, it just depends on your specific truck.
    equin, Davknz[OP] and Pinay like this.
  7. May 3, 2020 at 6:15 PM
    msikk
    msikk New Member
    I need a BMC w/295/70/18's on Black Rhino Arsenals. I used to run 315/75/17 on Rock Warrior Rims and didn't need a BMC. The increased offset on the Black Rhinos causes a slight bit of rubbing on the passenger side when I'm backing up, hence the BMC.
    equin, Davknz[OP] and BlackSheep like this.
  8. May 3, 2020 at 7:01 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    285 65 20 w/ BFG 2KO
    0 offset 9 “ wheel mine scraped as alignment was binging tested.
    BMC was easy if you have some tools & skills. Had to settle for less camber in alignment by a little.
    Had 3/1 Toytec lift. Used a heat gun to reshape plastic inner fender well. Another easy thing to do, agree with post # 6 on body to suspension flex. I’ve sense sold that truck.
    You can do it !!
    Davknz[OP] likes this.
  9. May 4, 2020 at 8:34 AM
    Davknz
    David
    Orange County ca
    Level kit
    I got 5100s on middle setting so just under level and want to run stock rims 18” looks like bumper probably only thing gonna have to trim I dunno (btw wanna run toyo open country m/t 285/75r18
