Bolting a piece of plywood on the floor of the bed w/ longer bed bolts (Bad idea?)
Discussion in '2.5 Gen Tundras (2014-2021)' started by SoCal_Tundra21, Aug 18, 2024.
  1. Aug 18, 2024 at 2:31 PM
    SoCal_Tundra21
    SoCal_Tundra21 [OP] New Member
    Using the OEM bolt locations, I want to bolt a piece of 4x8 1/2 plywood on my Tundra bed. I do a lot of wheelings and I don't want the plywood lifting into the air. I plan to secure my packout plates to the plywood versus drilling holes into the bed. Will it be a bad idea to have the plywood bolted with the bed and frame? Or anyone have a better idea of securing the packout plates to the bed?
    Does anyone know where I can get longer bolts? Probably 3/4 inch longer than OEM.
    Pic for attention
  2. Aug 18, 2024 at 2:47 PM
    I would use pressure treated unless you have a bed cover. For bolts, most likely your local hardware and fastener supplier should have something.
  3. Aug 18, 2024 at 2:50 PM
    Retired...finally
    Here's a few problems I see. There will be a dead space between the bottom of the plywood and the bed surface where the existing bolts are. This will need to filled with fender washers? Also the plywood is soft and getting the bolts tight enough to hold the bed down would likely cause the bolts to be drawn down into the plywood and make the sheet uneven.
    My solution would be to use a ferrule to pass the compression of the bolt head directly to the bed surface to hold the bed to the frame with the designed pressure.
    If this doesn't make sense I'll elaborate. But, yes. Doable. As far as the bolts, they shouldn't be hard to source. McMaster Carr comes to mind.
  4. Aug 18, 2024 at 2:53 PM
    SoCal_Tundra21
    You brought up many good points I never thought of. I'm glad I asked here before just doing it.
  5. Aug 18, 2024 at 3:01 PM
    Retired...finally
    If you are only trying to hold the plywood down to prevent loss or slipping you probably only need to use four of the bed bolts.
  6. Aug 18, 2024 at 3:09 PM
    SoCal_Tundra21
    Copy. I was planning on using the front and middle ones. The bolts by the tail gate have bed stiffeners on them, so I don't plan on using it.
  7. Aug 18, 2024 at 3:17 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
  8. Aug 18, 2024 at 3:19 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
  9. Aug 18, 2024 at 3:49 PM
    SoCal_Tundra21
    I saw this video already. Plan on doing something similar. The problem with his setup is that it is not secure to the truck itself. He uses the weight of the build to hold it down. That will be a problem for me as being airborne with my truck is a real possibility.
  10. Aug 18, 2024 at 3:50 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I did this (with less coverage) and used the OEM bolts.
    5/8” plywood. Only 1/8” difference between this and 3/4”.
    Fridge slide mount without drilling any extra holes in the bed.
    I would not trust this if you’re set up for high speed desert running. But I did do a bunch of western CO wheeling and Imogene Pass with this setup.
    Wallygator and FrenchToasty like this.
  11. Aug 18, 2024 at 5:54 PM
    d33pt
    d33pt New Member
    why not set up something on the sides of the bed instead of the bottom? i'm thinking something like molle panels.
  12. Aug 18, 2024 at 7:08 PM
    SoCal_Tundra21
    I'm going to have a bed cover that is taking the bed rails. Also the molle panels might not be strong enough to handle the vertical weight of all my gears in the packout boxes
  13. Aug 18, 2024 at 7:11 PM
    SoCal_Tundra21
    High-speed desert is exactly what I am building for. I have a Land Cruiser for the slower stuff. I just got done with Black Bear, Imogene, Engineer, and Ophir last week.
    Terndrerrr[QUOTED] likes this.
  14. Aug 18, 2024 at 7:18 PM
    Terndrerrr
    Music City
    6UR-FE
    Gotcha. There are quite a few of us Tundra and LC/LX owners on the forum.
    You must be going LT in the Tundra then?
    I wouldn’t depend on any plywood to hold things down or mount things to in that case. I would be using heavy duty ratchet straps with tie down points and cages bolted to the bed like @reywcms. Search his posts. Lots of bed shots.
  15. Aug 18, 2024 at 7:22 PM
    Terndrerrr
    Music City
    6UR-FE
    See post # 297 here
    reywcms likes this.
  16. Aug 18, 2024 at 8:31 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I dabble in the high speed dirt stuff
    grant.ducckk and Terndrerrr like this.
  17. Aug 18, 2024 at 8:41 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Add to the fact that water will get under there and stay for long periods of time. Might lead wood rotting, and possibly even speeding up the rust process in the bed???
  18. Aug 18, 2024 at 9:20 PM
    d33pt
    d33pt New Member
    You just have to park on a slope for water to drain to either end of the bed. I have a bedrug and water gets under there but it's not a big deal.
  19. Aug 19, 2024 at 6:35 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Yea I wouldn’t go the wood plywood route for many reasons one like mentioned above the tension for the bed bolts etc. I’d use the bed bolts and add tie downs. This has proven to work super well for me and others. For a few other items I’ve added nutserts or bolted through the bed. But not a big deal for me to do that. Especially since my shocks have a hole through that bed etc lol
  20. Aug 19, 2024 at 11:04 AM
    SoCal_Tundra21
    Thanks for the inspiration. Seems like I'll probably have to go your route since it's proven to work.
