Both low beam headlights not working
Discussion in 'Lighting' started by dozer1, Feb 3, 2019.
  1. Feb 3, 2019 at 7:13 AM
    dozer1
    dozer1 [OP] New Member
    Both my low beam headlights are suddenly not working, its a 2008 tundra all other lighting high beam, fog lights etc are working fine. Why are my low beams suddenly not coming on ?
  2. Feb 3, 2019 at 7:19 AM
    15whtrd
    15whtrd Mr. Blonde
    Check the fuses?
    Pitbull410, GODZILLA and nk1794 like this.
  3. Feb 3, 2019 at 7:22 AM
    dozer1
    I did already they appear fine, and whats the odds of both fuses going out at the same time ?
  4. Feb 3, 2019 at 7:26 AM
    15whtrd
    15whtrd Mr. Blonde
    The odds of both bulbs going out at the same time are pretty low. But you should only have one fuse for your low beam headlights. In the past on a (Chevy) I had a relay go out. The highbeams and fog lights would work but not the low beams. The way I checked it was by finding the relay and swapping it with my fan relay to confirm. They were the same.
    Northcoast101 and GODZILLA like this.
  5. Feb 3, 2019 at 7:36 AM
    dozer1
    there are two fuses in engine compartment one for low beam right side and one for low beam left side, both appear fine, I also tried swapping out relays to see if that would work and nothing. I guess I could try the rodent chewing the wire idea, but again what are the odds of both sides going out at the same time. Maybe I should replace the lighting stem at steering wheel ?
    nk1794 likes this.
  6. Feb 3, 2019 at 7:45 AM
    15whtrd
    15whtrd Mr. Blonde
    Sorry I was wrong about 2 fuses. I haven’t had to work on my lights yet. Have you pulled the bulbs to confirm if they look blown? I’m sure it’s possible the stem went bad. I have a fuse tester that came with a box of fuses. To test the fuses it just probes the two little contact points without even removing the fuse to check for continuity. A little light lights up if they’re good. Sometimes a fuse can be blown and look OK. Before you spend all that money check anything that is relating to headlights or running lights etc. Also check the ones inside the cabin, driver side left knee.
    BC2010Tundra and GODZILLA like this.
  7. Feb 3, 2019 at 7:49 AM
    dozer1
    ok thanks, ill give that a shot
    15whtrd likes this.
  8. May 10, 2019 at 11:42 AM
    Happycamper12000
    Happycamper12000 New Member
    2009 Toyota Tundra
    I have a 2009 tundra with the same problem. I have checked fuses, relays, bulbs, wiring haha everything but the switch on the steering column.
    Did you ever find out why your headlights stopped working?? Please let me know if you did. Thanks so much
  9. Jun 27, 2019 at 5:03 PM
    nxpnw
    nxpnw New Member
    2002 Tundra SR5 4.7L V8 4WD Access Cab
    2002 Tundra with the same problem. I have tried switching out the relays and fuses but didn't fix it. I will try new headlamps tomorrow. Please let me know if anyone found a solution.
    Northcoast101 likes this.
  10. Aug 6, 2019 at 3:49 PM
    ckmonzingo
    ckmonzingo New Member
    Did anyone ever figure this out? I am having same issue.
  11. Aug 6, 2019 at 3:57 PM
    nxpnw
    nxpnw New Member
    Yes. Incredibly, it turned out that both lights had just gone bad at the same time. I replaced the bulbs and the problem was solved. I even had a shop check the electrical for other issues. Nothing was found. Weird but happy it wasn't something worse. I hope you have a simple solutions too.
  12. Aug 6, 2019 at 4:45 PM
    15whtrd
    15whtrd Mr. Blonde
    Strange they both went at the same time. I wonder if it got a little electrical surge that caused it? I guess don’t sweat it unless it happens again identically.
    GODZILLA and NewImprovedRon like this.
  13. Aug 6, 2019 at 4:49 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I had it happen. I lost one and not long after lost the other. I read up and it is actually pretty common.
  14. Nov 25, 2019 at 9:28 PM
    Northcoast101
    Northcoast101 New Member
    02 Tundra
    Both of my low beam headlights just went out.... 02 tundra.... hoping what I just read here will work for me also.... fingers crossed..
    GODZILLA likes this.
  15. Jun 2, 2020 at 9:07 PM
    Sugarbearhtx
    Sugarbearhtx New Member
    2002 Gray Tundra
    I am having the same issue in my 2002 Tundra. Fog lights work, high beams work, low beams dead. I will check the fuses again but I will try some new bulbs.
  16. Jun 25, 2020 at 8:57 AM
    Ren
    Ren New Member
    2004 Tundra
    I ran into the same problem this week on my '04 Tundra. Replacing the bulbs was the fix.
    BTW, the reliability models associated with bulb filament wearout supports both bulbs burning out very close in time together given that they have an almost identical environmental and temperature exposure in the headlight housing. (assuming the two bulbs were replaced at the same time)
  17. Jul 29, 2020 at 9:14 AM
    O*2001
    O*2001 New Member
    I have a 2010 Toyota tundra that both the low beam and high beam stopped working. When I get a power probe and put power to the fuses The lights come on. Fuses are good. Not sure about relays. Does the fuses come before or after the relays? Could it possibly be the light switch in the steering column?
  18. Nov 16, 2020 at 6:34 AM
    sween819
    sween819 New Member
    Dennis
    2016 Tundra
    Stock
    Same problem. 2016 Tundra and I already replaced each headlight at least once with hi intensity bulbs that turned out to be just slightly brighter than the factory bulbs. With only 54k miles on, I'm taking it to the dealer and pushing warranty issue. I'll post back when they hook me up with the details
  19. Feb 7, 2021 at 3:25 PM
    Dfw El Jeffe
    Dfw El Jeffe New Member
    Try this for a fix. The turn signal (yellow bulb) socket plugs have a tendency to melt causing bulb to lose contact which can disrupt the circuit. The turn signal lights won't turn on with headlights but interestingly can sometimes turn on with blinker but with quick flash. Anyway, replace the turn signal socket, they are cheap, before trying anything more expensive. Replace both at the same time, will take you two minutes. Here is link to part:
    https://www.amazon.com/gp/product/B00FZP7K7G/ref=ox_sc_act_title_1?smid=A1N5C1IZJU9LZZ&psc=1
  20. Jan 25, 2022 at 9:33 AM
    Tundraalltheway8887
    Tundraalltheway8887 New Member
    Matthew
    2007 crew cab 4x4
    I have a 2007 had both mine go out fuses were good took the bulbs out still good put them back in and they came on, weird, i’ll probably get need new ones shortly
  21. Mar 9, 2022 at 7:14 AM
    BC2010Tundra
    BC2010Tundra New Member
    Bernadine
    2010 Toyota Tundra
    2" lift
    Thank you for this forum. I have a 2010 Tundra and noticed my radio light on dash was out, could still operate volume on steering ..then noticed my.low beams were not working. All other lights working. I am checking fuses today and will go through the process of elimination until the culprit is found. I did replace both low beams and battery about a year ago to some apparent fancier ones...here goes nothing. I need lights ..thank you all
  22. May 14, 2022 at 1:42 PM
    Ttown biker
    Ttown biker New Member
    Lee
    2011 Crewmax Limited
    Lifted
    I had an issue with 2011 Limited where headlights won't display with full power. If I take relay 90080-87024 out and put it back in they work. I replaced it this week and everything seems to be back to normal. Is the relay for dimmer supposed to be same part number? I got truck used and not sure if someone put wrong one in. I'd like to get relay for dimmer so there is nothing old to worry about. I have 205,000 miles showing and it is still running good.
