Brake Backing Plate
Discussion in 'General Tundra Discussion' started by shep1950, Oct 11, 2019.
  1. Oct 11, 2019 at 11:36 AM
    shep1950
    shep1950 [OP] New Member
    Hello.. I have a 2012 Toyota Tundra Crew Max. I was told I need a brake backing plate and said I would have to do both sides left and right rear. Is this normal for a a 7 year old truck? the cost would be $2,700 dollars. Just making a rubbing noise when turning left.
    Any help would be appreciated.
  2. Oct 11, 2019 at 6:25 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Welcome from TX!
    Like any high $$ quote, get a few quotes.
    I could be wrong but a brake backing plate are for drum brakes. Thinking you have disc brakes which does not apply.
  3. Oct 12, 2019 at 6:46 PM
    Since you live on the east coast, yeah, pretty normal for rust to overcome the backing plates.
    Are you handy with hand tools? These dust shields are 92.00 each. My ass would be doing this myself.
    Ely010606 likes this.
  4. Oct 14, 2019 at 2:22 PM
    JackWagon
    JackWagon Dr. Wookiee
    16 Tundra DC TRD Pro MGM
    I wonder if this is what I am running into now. I have a metal on metal grinding/scraping sound (sorta like the rotor rubbing the heat shield). When I brake it goes away. I pulled the rear brakes down and checked everything I could think of. All parts look in good shape and no replacements are needed. I've even checked the front for good measure. I'm completely stumped and started perusing the forum for advice..
    OP, how did they check the "backing plate" or "head shield"? You can't just look in the whole way around.
    Edit.... 2016 Tundra TRD Pro w/ 78k miles. (Brakes were replaced less than a year ago. Yea, I think its been less than a year with PowerStop E36 Truck and Tow.)
  5. Oct 27, 2019 at 2:43 PM
    Mooseknuckles
    Mooseknuckles New Member
    Randy
    I'm doing mine now along with the wheel bearings. Where in the world did you find the plates for $92 each? All i can find is $200-$380 each.
  6. Oct 27, 2019 at 2:52 PM
    timsp8
    NY
  7. Oct 27, 2019 at 3:05 PM
  8. Oct 27, 2019 at 3:27 PM
    Mooseknuckles
    Randy
    1. Thnx guys. 2008 Tundra with 230K miles. I don't think that tsb would cover it. but at least i got 230K miles out of the old ones. :)
  9. Oct 27, 2019 at 3:35 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Stay away from that shop. Huge ripoff. As others have stated, that backing plate (ie. dust shield) is only $100-200. It's easy to do the swap if you have the right tools but even then a shop shouldn't charge you that much. If you were in San Diego, I'd help you do it myself.
  10. Oct 27, 2019 at 4:15 PM
    Mooseknuckles
    Randy
    thnx for the offer. Ill save a bigger job for when back in CA :)
  11. Oct 27, 2019 at 5:26 PM
    timsp8
    NY
    A TSB just explains an issue and how Toyota recommends to fix it. It’s not a recall. TSBs still cover the vehicle they are issued for, they are not saying Toyota will pay to fix it.
  12. Nov 5, 2019 at 11:17 PM
    Mooseknuckles
    Randy
    morning guys. Update on wheel bearings. easy as pie to pull everything off. 30-40 mins each. new bearings, new break backing plate, seals o-rings etc. got the bearings off/on easily enough. But it looks like the spacer went a little past where the C-clip sits making the bearings a tad bit tight. I'm guessing this isn't good.
    Any advice?
