Brake bedding.....what's the best way?
Discussion in '2nd Gen Tundras (2007-2013)' started by Tundra234, Jan 25, 2020.
  1. Jan 25, 2020 at 8:57 PM
    Tundra234 [OP] New Member
    Just installed all new Stoptech slotted rotors and PosiQuiet ceramic pads. What do you guys recommend for bedding procedures? The front is cryo treated and the rear are standard.
    TheBeast likes this.
  2. Jan 25, 2020 at 9:08 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    0-60 in beast mode then lock ‘em up
    14burrito, Luckydog and Hbjeff like this.
  3. Jan 25, 2020 at 9:10 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    No instructions about break in from Stoptech?
  4. Jan 25, 2020 at 9:14 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    Find a nice open road at night to accelerate to about 60 MPH, brake hard to about 10 MPH, and repeat a dozen or so times without coming to a complete stop. Drive around for a while to let the rotors cool off and do this a second time if you can. Don't come to a complete stop if the rotors are hot.
    Tundra234[OP] and Hbjeff like this.
  5. Jan 25, 2020 at 9:14 PM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
  6. Jan 26, 2020 at 10:49 AM
    Did the best break in that I could based on traffic etc. Does the rubbing/scraping noise go away with this setup after driving a few miles while the pads continue to settle in? I didnt make any adjustments to the rear e-brake shoes.
    So after it sitting for about 45 minutes while I was at the store, I drove to pick my son up down the street. It was still making a rubbing noise in the right rear.....sounded almost like a wear sensor. After picking him up, we hit about 60 mph on the way home and it stopped.....no idea what it was.
  7. Jan 26, 2020 at 11:21 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Good info here:thumbsup: I have a ways to go yet before needing brakes. I'm at 83,000 miles on factory rotors/pads. My Mechanic says I should go 100,000 before replacing:spending:.
  8. Jan 26, 2020 at 2:18 PM
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    Tundra234[OP] likes this.
  9. Jan 26, 2020 at 5:39 PM
    Now that I'm thinking about it, it could have been rubbing the backplate. Anyone had that issue with the StopTechs on the rear?
  10. Jan 26, 2020 at 6:05 PM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    Likely the E-Brake. I wouldn't worry if it doesn't get worse
  11. Jan 26, 2020 at 7:19 PM
    computeruser6
    Dirk
    Escondido
    I had to remove the powdercoat from part of the inside of the rear rotor hat. Try that and adjusting your e-brake.
