Brake Bleed Order
Discussion in '2.5 Gen Tundras (2014-2021)' started by UTTundra, Apr 5, 2018.
  1. Apr 5, 2018 at 8:20 AM
    UTTundra
    UTTundra [OP] New Member
    Lou
    Utah
    What is the correct order for bleeding the brakes? I came across this section of a 2015 Tundra manual that says FR, FL, RR, RL, but every post I've found on the subject says RR, RL, FR, FL.
  2. Apr 5, 2018 at 8:22 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    I always did furthest to closest.
  3. Apr 5, 2018 at 8:25 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Always farther from the master first, progressively closer. Closest last
  4. Apr 5, 2018 at 9:59 AM
    15whtrd
    15whtrd Mr. Blonde
    As the other stated I would think furthest all the way to the closest. But I would also put something under the brake pedal so that you don’t depress it any further than you do under braking. This keeps the master cylinder in it’s typical wear pattern. Damage can possibly occur to the seals in the master cylinder if extended beyond its normal wear pattern
  5. Apr 5, 2018 at 12:00 PM
    UTTundra
    Lou
    Utah
    So what's up with the factory service manuals saying FR, FL, RR, RL? This question came up on a 4runner forum. Someone responded saying that on modern vehicles the front and rear fluid systems are separated, so the passenger side will be the furthest, but it doesn't matter if you do front or rear first.
  6. Apr 5, 2018 at 12:57 PM
    15whtrd
    15whtrd Mr. Blonde
    Well that sounds feasible. In that case you are still doing the furthest from the master first. So to keep it from being complicated, just do it as you would normally. Start at the back and work your way to the front left. You only have two lines from the master cylinder which is just one large reservoir nowadays. Those lead to the ABS block which goes to each wheel individually from there if I’m not mistaken. So if you look at it that way front left is further away from the master cylinder than front right and left rear is further away from the master cylinder then right rear.
    No matter which way you skin it, as long as the to feed lines to the ABS block are bled of bubbles just bleed the brakes normally until you see nice fresh fluid and I don’t think you should have a problem.
    I just did my 03 sequoia in the traditional pattern and it brakes phenomenally. I had just changed the master cylinder as well as the front brake hoses with new brakes all the way around. It stops nice and straight.
    I’m not an expert but I’ve been around the block. Don’t overthink it, there’s been plenty of guys out here doing it the old-school way and I have not heard of one problem yet.
  7. Apr 5, 2018 at 2:24 PM
    http://www.stoptech.com/technical-support/technical-white-papers/bleeding-brakes
    Now there are exceptions. ABS can be a mofo on some systems and a scan tool is needed.
    Sometimes a certain sequence is required per the owners manual.
    If Toyota Service manual says to do it backwards to what we all have been taught, there has to be a reason. Every time I start thinking I’m smarter than Mike Sweers, he proves me wrong.
    jayhawknavy02, JPritch, RickC and 4 others like this.
  8. Apr 5, 2018 at 2:31 PM
    I’m willing to bet doing it the “old” way will work just fine.
    Until about 15 minutes ago, I had no idea the Tundra brake system bleeding sequence. My Tumdra work flawless doing it like you do it as well.
  9. Apr 5, 2018 at 2:33 PM
    15whtrd
    15whtrd Mr. Blonde
    One thing I used to do in the past after replacing a master cylinder or just doing a system flush was actually start at the drivers front wheel. I did this so I was not going to introduce as much air to the rest of the system by pushing it through at the closest corner. Then I would do my typical bleed procedure that we all know. I don’t know if it made much of a difference but my over analyzing self did it this way. But you do have a point if the manual says to do it this way just do it that way. Now that I know the manual says this it’s actually what I will probably do.
  10. Apr 7, 2018 at 8:55 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    I've always done furthest to closest.
    NewImprovedRon and ColoradoTJ like this.
  11. Jul 3, 2022 at 8:15 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Just changed my brake fluid today. I went with the order Toyota suggests, FR, FL, RR, RL. Used my mityvac. Came out pretty good but the pedal didnt feel as good as before, not bad by any means though. I had seen you can bleed the brakes with techstream, so I gave it shot and the order techstream uses is FR,FL,RR,RL as well. Using Techstream got my pedal back to stock feel, would be much easier with two people since it requires keeping the pedal depressed while opening the bleeder but I used some wood a big rock and it got the job done.
    WFD473 likes this.
  12. Jul 3, 2022 at 9:12 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    What do think the Techstream did different than not using it?
  13. Jul 3, 2022 at 9:17 PM
    Joe333x
    Joe333x Member
    Boston
    I dont know exactly what, but it tells you to open the bleeder and hit next, then you hear some noise and end up with fluid coming out the bleeder, tells you to close it. Then it activates the ABS module and has you open the bleeder again. What ever dark magic it does, it definitely makes a difference. I had read some others having issues with because of the ABS so idk if maybe air gets trapped in there some how?
    Karambit and pursuit2550[QUOTED] like this.
  14. Jul 3, 2022 at 9:22 PM
    pursuit2550
    I have heard that some abs systems require a scan tool to activate it so that the old fluid could be flushed out. I don’t know how true this is. I don’t know if the the tundras system is the same way. Either way, if you keep the reservoir full, I don’t see how air can get in. Other than if you open the bleeder at the wrong time.
    Joe333x[QUOTED] likes this.
  15. Jul 3, 2022 at 9:26 PM
    Joe333x
    Joe333x Member
    Boston
    Yeah I mean I totally could have gotten away with not doing the techstream but I had it already so figured what the hell I give it shot. I dont think I got any air trapped from bleeding since I kept vacuum on the line the whole time until closing the bleeder but who knows, I'm not an expert by any means.
