Brake Booster/Master Cylinder Upgrade/Fix
Discussion in '1st Gen Tundras (2000-2006)' started by mevaleverga, Oct 19, 2023.
  1. Oct 19, 2023 at 10:28 AM
    mevaleverga
    mevaleverga [OP] New Member
    '06 Tundra DC SR5
    Hi all,
    I've got the infamous "unicorn" master cylinder on my first-gen Tundra. I took the unicorn, secondary MC piece apart and found what I believe to be the source of the issue--a warped seal.
    I've been going back and forth debating on how I want to fix the thing--since I can't locate a rebuild kit and Toyota wants half my soul for the entire assembly--and I've been considering the T100 upgrade detailed here.
    I was wondering if anyone has tried this upgrade with a DC pickup, as OP's truck has the access cab.
    Or, if anyone has figured out another way to fix the issue without dishing out the $1,200+ that Toyota wants for the booster/MC assembly, I'd love to hear what you did.
    Thanks in advance for any advice!
  2. Oct 19, 2023 at 11:24 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    If this is the “unicorn” booster/MC you speak of, you’re going to have significant hurdles attempting the T100 upgrade. There’s a dedicated brake line to each wheel and they play into the “auto-LSD” dif we have. All that would have to go away and you’d have to learn to live with all the codes and lights on your dash when you get rid of it.
  3. Oct 19, 2023 at 11:29 AM
    That's the VSC booster/MC and whatnot.
    I think he's talking about the MC that's technically 2 pieces MC, with a standard booster. VSC have the little keg-can booster (or whatever function it serves)
  4. Oct 19, 2023 at 11:32 AM
    mevaleverga
    '06 Tundra DC SR5
    I think that's the model with VSC. I should have mentioned that my truck does not have VSC. My issue is the same as the one discussed in this thread.
  5. Oct 19, 2023 at 12:57 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    :thumbsup:
  6. Oct 19, 2023 at 5:43 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
  7. Oct 19, 2023 at 6:10 PM
    mevaleverga
    '06 Tundra DC SR5
  8. Oct 19, 2023 at 6:12 PM
    bfunke
    South Carolina
    Several lengthy threads about this past couple yrs. I don’t recall anyone posting a follow-up with a satisfactory solution other than BOHICA at parts dept
