Brake caliper pistons spreader tool ideas.
Discussion in 'Off-Topic Discussion' started by TundraMcGov., Dec 18, 2024.
  1. Dec 18, 2024 at 4:59 PM
    TundraMcGov.
    TundraMcGov. [OP] Your friend. Your foe. Not yo Ho.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I've never had in my tool box a specific tool designed specially for spreading truck/car brake caliper pistons. The kind used predominately when replacing disc brake pads. They're out there. I've had friends help me over the years and they've had them.
    No more C clamps, etc. Now it's my turn. Who can render a suggestion (make and model)? Real world experience. This includes anything to beware of too.
    TIA.
    AZBoatHauler likes this.
  2. Dec 18, 2024 at 5:20 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
  3. Dec 18, 2024 at 7:36 PM
    Yodagan
    Yodagan New Member
    Peter
    Birmingham, Alabama
    2016 Toyota Tundra SR5
    @TundraMcGov.
    If you need one to borrow. I have one.
    Just let me know.
    I will go out to my garage tomorrow and look for it. I know I have it on a shelf.
    I used it when I replaced rotors and pads.
  4. Dec 18, 2024 at 8:16 PM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
    Well fuck, gotta buy something else I didn’t know I needed.
  5. Dec 19, 2024 at 4:48 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I got one at HF, it has adapters for all makes. I’ve used it a couple times and it works well.
  6. Dec 19, 2024 at 5:26 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    What is Wrong with using the old pad and the clamp - so EZ.
    KNABORES and Bprose like this.
  7. Dec 19, 2024 at 5:41 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
  8. Dec 19, 2024 at 5:54 AM
    If you'll crack the bleeder screw while compressing the brake pistons, you can almost do it by hand, no fancy tools needed. I use a large pair of channel locks and on of the old pads to compress one side, then the other. Opening the bleeder allows the nasty, water contaminated fluid to be removed from the system, instead of pumping it back up into the brake lines.
    WAtundra4x4, snivilous, vtl and 2 others like this.
  9. Dec 19, 2024 at 6:10 AM
    Uhhhh....
    Dave
    7” BDS, 37s
    Smrt
  10. Dec 19, 2024 at 6:15 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    May as well if you’re going to bleed after your pad change!
  11. Dec 19, 2024 at 6:20 AM
    If you're changing pads, it's time to bleed. Brake fluid is not lifetime like people seem to think. I change it every 50-80k miles usually. Minimum of a caliper bleed at any pad change. Brakes tend to last me forever though.
  12. Dec 19, 2024 at 6:20 AM
    AZBoatHauler
    So.Arizona
    This applies even pressure when resetting the piston - whenever I used C clamps they’re always cockeyed because they don’t fit well in the middle of the caliper in my experience.
  13. Dec 19, 2024 at 6:22 AM
    Tundra family
    Tundra family New Member
    X2 for this, only problem I've run into is maxing out the tool before the pistons are all the way in, but I just slap an old pad in there to take up the space.
    And didn't realize I paid $1 more for the red one. What the crap is that? LOL
  14. Dec 19, 2024 at 7:26 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    LOL I saw that too and chose the blue vs the red.
    So those 2 additional longer length pads that come in can actually be sandwiched and used for either side to add additional thickness.
    Had to do that for the fronts.
    Tundra family[QUOTED] likes this.
  15. Dec 19, 2024 at 1:39 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    THANKS Fellers. Appreciate your tips and suggestions. The $20 Amazon one is what my buddy has and we have used on the last couple of pad jobs. Thanks for the link-poo. Ordered.
    @Yodagan thanks for the offer. But I'm a guy: never too many tools. I'm in Hoover near Oak Mountain State Park. DM me and let's schedule a rendezvous.
