Brake controller fuse
Discussion in '2.5 Gen Tundras (2014-2021)' started by Walleyeguy, Oct 31, 2017.
  1. Oct 31, 2017 at 2:55 PM
    Walleyeguy
    Walleyeguy [OP] New Member
    where is the electric brake controller fuse
  2. Oct 31, 2017 at 4:33 PM
    Abrams65
    Abrams65 New Member
    Cliff
    WV
    16 Tundra MGM SR5 CM OR/15 Corolla S
    ICI Magnum RT Steps, 18' LED Foglights
    Let me know what year and I’ll look in the wiring diagram.
    Vehicle before aug 2017 there are actually two fuses. There is a 40A fuse in the engine compartment marked TOW BRK and a 7.5A fuse #1 in the interior fuse box marked ECU-IG
    After aug 2017. 30A fuse same place and a 5A #2 in the interior fuse box marked ECU-IG1
    NewImprovedRon likes this.
  3. Oct 31, 2017 at 5:27 PM
    Walleyeguy
    It is a 2016 - I checked both slot 1 and 2 (both 7.5 amp) and both were good. Also found the 40 amp - also good.
    I get no response from the controller (does not show up in sequence of screens when hit Disp)
  4. Oct 31, 2017 at 6:18 PM
    Abrams65
    Abrams65 New Member
    Cliff
    WV
    Is the trailer connection solid
  5. Nov 1, 2017 at 7:32 AM
    Walleyeguy
    Connection seems good - I cleaned the contacts.
    If you slide the Manual electric brake lever - should there be 12v to the truck 7 pin plug connector for electric brakes?
    Could my controller be bad?
  6. Nov 1, 2017 at 5:21 PM
    Abrams65
    Abrams65 New Member
    Cliff
    WV
    Not too versed on the controller I’ll ask one of the other guys in the shop tomorrow. It should be the truck isn’t that old. Did it work before or is this the first time you’ve tried it?
  7. Nov 1, 2017 at 7:30 PM
    Walleyeguy
    No worked before, but haven’t used it for 6 months
