Brake light out on one side, but the running light works
Discussion in 'Lighting' started by midnightyota12, Mar 15, 2023.
  1. Mar 15, 2023 at 9:52 PM
    midnightyota12
    midnightyota12 [OP] New Member
    Wyatt
    2012 SR5 double cab
    3” lift 35s Icon wheels Black widow exhaust
    Hello, my 2012 tundra has a brake light out on one side, but the running light works. The other side works running and brake. Is there a fuse somewhere or do I have a bad bulb? Also my driver side fog light has a brand new led bulb and quit working after 4 days. Any ideas or thoughts? Thank you
  2. Mar 15, 2023 at 10:30 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Brake light is probably a bulb and is super easy to check, think it's 2 screws. Fog light... check your connections, might be loose. Even chinesium leds tend to last longer than that.
    Taco-Spike likes this.
  3. Mar 16, 2023 at 6:25 AM
    Taco-Spike
    Two Trucks
    The brake light bulb is a dual filament. Used with 2 functions, parking and brake. Brake filament probably went bad, parking will still work.
    NewImprovedRon likes this.
  4. Mar 16, 2023 at 6:16 PM
    midnightyota12
    Wyatt
    2012 SR5 double cab
    So update. Brake light is fixed. Now with my driver side fog light, where is the connection from the harness coming off the light up near the battery?
  5. Aug 7, 2023 at 9:58 AM
    Prestoman13
    Prestoman13 New Member
    Preston
    2008 crewmax SR5
    So what fixed it? I have the exact same issue on my driver side. My brake light doesn’t work, but running light does.
  6. Aug 7, 2023 at 10:30 AM
    Replace the bulb. It's a dual filament.
