Brake override malfunction
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2020TundraRango, Mar 13, 2024.
  1. Mar 13, 2024 at 8:31 PM
    2020TundraRango
    2020TundraRango [OP] New Member
    Rango
    Cement grey 2020
    Recently was driving my truck got out turned the engine off got back it and the truck wouldn’t start and wouldn’t shift out of park, the brake override malfunction had turned on.Had use the emergency override to put the truck in neutral and push it back into my driveway. After a lot of struggling I finally came down to the problem (The STOP fuse had blown) inside the cab, Replaced that and finally got the brake override malfunction light to go away but now have a new problem. My brake lever is locked out and I can’t figure out to bring it back to turn the truck on, Wondering if and one has and ideas or have had the same experience
  2. Mar 14, 2024 at 4:36 PM
    SportDek
    SportDek Boat hauler, Bus Driver
    Dale
    TEXAS from MN
    2021 1794 Tundra Crewmax Windchill Pearl
    TRD Swaybar, RCI Skid plates, DiamondBack HD cover, bed rug, Cooper AT3 4S
    Put your parking brake on. With the iginition switch on, hold your key fob up against the switch for 30 seconds, it will now start.
