Brake Override Malfunction
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra 2019 tss, Dec 12, 2020.
  1. Dec 12, 2020 at 2:42 PM
    Tundra 2019 tss
    Tundra 2019 tss [OP] New Member
    Jerry
    2019 tundra TSS
    Hey guys this happened to me today does anyone know how to fix or do I just have to wait until Monday to take it to the Dealer?
  2. Dec 12, 2020 at 2:46 PM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    More information needed?? LED bulbs? Aftermarket taillights? Check the fuses? Looks like it’s should still be under warranty...
  3. Dec 12, 2020 at 2:51 PM
    Tundra 2019 tss
    Jerry
    2019 tundra TSS
    I does have aftermarket head and tail lights that are LED but I have been running them since I got the truck over a year now. everything else is stock.
  4. Dec 12, 2020 at 3:14 PM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    Check fuses...
  5. Dec 12, 2020 at 3:16 PM
    Tundra 2019 tss
    Jerry
    2019 tundra TSS
    done that they are all good unless there are some I dont know about beside what is in the engine compartment
  6. Dec 12, 2020 at 3:18 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Looks like you may need a reflash on the ECU or PCM.... That was part of the recall for the 2nd gen from 07-13 the brake override came from the ECU reflash as to neuter your truck's power once you press the brake pedal to prevent any unintended acceleration... May be a stealership thing...
  7. Dec 12, 2020 at 3:18 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Pull the negative terminal off your battery and let it sit for a while and then reconnect and see what happens.
    Saltyhero13 likes this.
  8. Dec 12, 2020 at 3:18 PM
    blackdemon_tt
    I'd try to pull codes first... local autoparts store
  9. Dec 12, 2020 at 3:20 PM
    Tundra 2019 tss
    Jerry
    2019 tundra TSS
    okay will try both and see what happens thanks
  10. Dec 31, 2020 at 7:39 AM
    Tundra 2019 tss
    Jerry
    2019 tundra TSS
    okay guys sorry about not getting back on right away. I had a friend of mine hook to the truck with his scan tool and it showed the brake switch to be bad. Took truck to dealer and they said that it was a fuse that blown I checked all fuses under the hood before I took it to the dealer. Is there a fuse box or something under the dash that I can not see lol. I have the truck back I just want to know what they could of done to fix it and not tell me the whole story
  11. Dec 31, 2020 at 7:40 AM
    Squatting Pigeon
    Holden
    North Texas
    Yes it’s by your left foot when sitting in the drivers seat. You’ll have to stick your head up under the dash to see it
  12. Dec 31, 2020 at 7:41 AM
    Tundra 2019 tss
    Jerry
    2019 tundra TSS
    okay sweet thanks for the info
  13. Mar 27, 2021 at 12:19 AM
    Viliamu808
    Viliamu808 New Member
    @Tundra 2019 tss problem never came back after switching the fuse? Just happened to my 2019 yesterday. 20,000 miles exact of today..I see yours was almost at 17,000 miles.
  14. May 30, 2021 at 5:01 AM
    Mikemalandrucolo
    Mikemalandrucolo New Member
    2020 tundra tss
    Okay I hope this can help somebody out. I had the same issue, after replacing my factory tail light with another oem tail light.
    After installation I started the truck and it wouldn’t let me shift out of park. I got the brake override malfunction fault. Turns out the fuse marked STOP in the cab cluster(not under the hood 10amp was popped. This happened because I didn’t put the bulbs in the new tail light assembly before installing it causing an open circuit and popping the fuse. Hope this helps somebody out.
  15. Jun 23, 2021 at 7:58 PM
    asmall23
    asmall23 New Member
    Art
    2020 Gray Platinum Tundra
    Linex bed liner, Upgraded stereo system, 40 inch Led light bar, and waiting for my Stage 1 Tav Spec upgrade.
    Hi I am having the same problem. I have aftermarket tail lights for over a year and no problem and now I can barely go over 20 miles and that same fuse blows. I even put a 15amp fuse it lasted longer but still the same issue. What tail lights are you using? Also we have to put the same bulbs from the original in there or use something else? Thanks in advance for your help!
  16. Dec 15, 2021 at 8:58 AM
    BenSan
    BenSan New Member
    Ben
    2020 TRD PRO
    Hi, can you take a photo of which fuse ? It just happened to mine truck.
  17. Dec 15, 2021 at 10:04 AM
    Wheresmytranscooler
    Wheresmytranscooler New Member
    Brad
    2019 Tundra SR5 TRD
    An open circuit would result in zero current flow, not a blown fuse. Possibly, the bulb prevents the tabs inside the bulb socket from touching causing a short circuit with no bulb present???
  18. Dec 16, 2021 at 4:43 AM
    2mchfun
    This condition can also be a faulty brake switch.
  19. Dec 18, 2021 at 5:51 PM
    BenSan
    BenSan New Member
    Ben
    2020 TRD PRO
    Hi, can you take a photo of which fuse ? Thanks
  20. Apr 14, 2022 at 10:33 AM
    Mickydounuts
    Mickydounuts New Member
    Mick
    I had the same problem 2019 Tundra. Pre-collision system malfunction, break over-ride malfunction, trailer break error, visit your dealership error codes. My shifter also locked up. I was able to drive home by pushing the shifter over-ride button on top of the steering column. The break lights wouldn’t work but they work with the hazards on. My fix was a 10 amp fuse in the panel under the steering wheel. I found it by doing a continuity test with my meter. The reason the fuse blew is still a mystery. I do have aftermarket tail lights but they are at least 3 years old with never any issues. I’m starting to look into my viper alarm system that is hooked into the break pedal switch to kill the engine during an alarm occurrence. Hope this helps.
  21. Jul 2, 2022 at 1:04 PM
    Kichinko
    Kichinko New Member
    TRE 5ON
    VA
    SUPER WHITE 2016 Plat 4x4
    TBD
  22. Jul 3, 2022 at 7:06 AM
    Mickydounuts
    Mick
    Figured out my blown fuse problem. Aftermarket tail light LED resistor fell out of its mount and the unprotected soldered connection would ground out on the truck body. I installed heat shrink to the connectors and secured the resistors with high grade 3M double sided tape.
  23. Sep 18, 2022 at 3:05 PM
    MarkTRDPRO
    MarkTRDPRO New Member
    Mark
    2020 gray Tundra TRD Pro
    I had the same thing happen after I changed out tail lights for aftermarket from 1A Auto. It was a popped 10A fuse. I put in a 15A fuse and put back the stock lights and have had no problem.
    Can I use my aftermarket’s with a stronger fuse or is this just going to cause more electrical problems with the wrong fuse?
    Is there any other fix to this so I can use the new lights?
    Bear in mind I’m not a mechanic and have little to no mech skills.
  24. Nov 11, 2022 at 11:53 AM
    OSB
    OSB New Member
    K
    2010 Tundra Crewmax 4X4 TRD
    SB M1 Bumpers SB 15K winch Toytec lift Fuel rims OS tires
    MarkTRDPRO,
    I wouldn't risk a higher amp fuse. If you have high current draw it could melt the wiring or socket assembly. IMO you need to find out what is wrong with that taillight assembly or replace it/them. Could be just a poor connection or bad wire.
  25. Jan 14, 2023 at 8:17 PM
    CMac0400
    CMac0400 New Member
    Long story short, I tried changing out my broken tail lights with new LED tail lights. I figured out most of the issues and solved them by putting my old tail lights back in. I’m still having an issue with my key fobs not working anymore. I’ve put in new batteries in both keys and they still don’t work. Additional info: when I get into my truck and put the key in the ignition before turning it to start, the dome light fades in and out and the dashboard flickers on and off. Anybody know the solution?
  26. Jan 14, 2023 at 8:23 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Do you have LED cargo lamp bulbs? I think those interfere with the key fobs for some reason if I remember correctly.
  27. Jan 14, 2023 at 8:25 PM
    CMac0400
    CMac0400 New Member
    No, everything else is factory installed lights.
  28. Jan 14, 2023 at 8:45 PM
    TILLY
    Massachusetts
    Very strange, any other non-factory add on's like alarm or remote start?
    RocknRoll likes this.
  29. Jan 14, 2023 at 8:59 PM
    CMac0400
    CMac0400 New Member
    Nothing. It only started happening a day after I changed out the tail lights.
  30. Aug 31, 2023 at 12:34 PM
    moisegram
    moisegram New Member
    Moisés
    It just happened to me, I replaced a tail light and this happened to me, I checked the fuses everywhere and there is nothing wrong there, can someone help me?
