Brake pad/rotor suggestions
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rockanock, Jan 19, 2024.
  1. Jan 19, 2024 at 8:56 PM
    Rockanock
    Rockanock [OP] 21 Chevy 2500
    Time for brake pads on the front. I’m gonna go ahead and do rotors as well. Do y’all have any suggestions? I’m not looking for formula one stuff. I’ve been looking at the normal flavors from o’reillys and autozone but if there’s a better affordable option I’m all ears. 2020 SR tundra 2wd. Thank you.
    biebs96 likes this.
  2. Jan 19, 2024 at 9:11 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I went with OEM, it works and lasts a long time.
    biebs96, AggieSigGuy and equin like this.
  3. Jan 19, 2024 at 9:15 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Yup, if you’re wanting to keep it similar to stock, go OEM.
    AggieSigGuy likes this.
  4. Jan 19, 2024 at 9:44 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    I haven't needed to change my brakes yet but I keep seeing Power Stop mentioned as well as EBC. Rock Auto sells the Power Stop front and rear entire pad n rotor kit at different prices based on what level you want from about $300 to $500.
    bulldog93 and Leo's first like this.
  5. Jan 20, 2024 at 3:07 AM
    SPOirish28
    SPOirish28 New Member
    Ontario, Canada
    2014 SSM SR5 DC
    Satin black roof, 18” KO2’s, satin black powder coated steel rims, tri fold tonneau cover. Led lights interior, exterior. Trd pro grill. 13” ryonnair antenna. OEM LED headlights.
    I went with NAPA premium rotors, and Bosch pads. Been on about a year and they feel great still. Couple of my mechanic buddies have had bad luck with Napa pads squeaking on trucks.. hence the Bosch pads.
    bulldog93 likes this.
  6. Jan 20, 2024 at 4:33 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I like my cryo treated centric/stop tech rotors, and while the Hawk pads bite well, they are a bit noisy, so I may switch to centric pads, too. They are impressive on the wife's vehicle.
    The rotors were a nearly 6 month wait during the pandemic. Not sure where they are at now.
    Lots of threads on this topic, so easy research.
  7. Jan 20, 2024 at 1:12 PM
    JohnWhicker
    JohnWhicker New Member
    Same here, I went with OEM, it works and lasts a long time like other said....
    equin likes this.
  8. Jan 20, 2024 at 8:05 PM
    Rockanock
    Thank yall for the replies. Where is the best place to buy the oem parts? I don’t have a Toyota dealer close to me
  9. Jan 20, 2024 at 8:08 PM
    biebs96
    PA
    Just picked up all four rotors and pads.
    OEM is the way to go when it comes to Toyota vehicles.
    GlocKoMA, bulldog93 and WILLINH like this.
  10. Jan 20, 2024 at 9:21 PM
    Rockanock
    Did You pick all that up at a dealership?
    biebs96[QUOTED] likes this.
  11. Jan 21, 2024 at 5:04 AM
    biebs96
    PA
    yes. Called them early in the week and they had it all in stock.
  12. Jan 21, 2024 at 5:15 AM
    Yugo
    Yugo New Member
    Aleks
    North Carolina
    2018 Silver Sky CM 1794
    Going with OEM replacement myself. My local dealer always has promos on parts and I can get front rotors and pads under $200.
  13. Jan 21, 2024 at 5:19 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I just did OEM pads on the front. 98,000 miles on the stockers. But they were shot.
    I've had 7 new-from-the-dealer Toyotas since 1985 and have never had to replace a rotor.
    bulldog93 and STR1 like this.
  14. Apr 20, 2024 at 4:37 PM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Doing pads and rotors for the first time on my 19’. Going OEM. Any other parts I need besides the rotors and pads? Thanks! Any need to get additional hardware. Newbie with DIY brake job.
  15. Apr 20, 2024 at 4:40 PM
    biebs96
    PA
    I purchased shim kits for mine as well.
    My mechanic said he could reuse the old ones, but if you’re going to spend hundreds on new rotors and pads, don’t be cheap and save $40 on the shim kits.
  16. Apr 23, 2024 at 7:06 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Maybe pin kit for front calipers with high temp antiseize or equal.. Rear caliper slider pins, clean and lube, with non petroleum base caliper lube..
  17. Apr 24, 2024 at 4:50 AM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    I'm running Stoptech slotted rotors and Hawk LTS pads. Excellent quality stuff, but in the future I will use some other combo that makes less dust. I'm sick to DEATH of how often I have to wash my rims.
    bflooks likes this.
  18. Apr 24, 2024 at 5:41 AM
    KTM4LIFE
    KTM4LIFE New Member
    2015 Crewmax SR5
    Can't go wrong with Akebono premium ceramic pads. They last a long time.
  19. Apr 24, 2024 at 5:56 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Worse than EBC yellow?
  20. Apr 24, 2024 at 2:43 PM
    Gene_in_FL
    FLORIDA
    I've never tried those.
  21. Apr 24, 2024 at 3:30 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I want you to imagine you moved into a house 20 years ago, and forgot to dust on top of something until just yesterday.
    They're DUSTY. Also noisy, freight trains flinch at my truck when I first get rolling in the morning.
    I'll be doing different pads this summer probably. My EBC yellowstuff pads have been on the truck for like 15k so I don't feel like it's a complete waste, but still. Looking forward to quiet brakes again.
  22. Apr 24, 2024 at 3:33 PM
    bflooks
    bflooks New Member
    Metrowest MA
    But they do bite well when needed. I'll give the LTS that.
    Gene_in_FL and MedCityMoto like this.
  23. Apr 24, 2024 at 3:35 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
  24. Apr 24, 2024 at 7:41 PM
    Gene_in_FL
    FLORIDA
    Definitely. They are excellent pads. More power than I need.
  25. Apr 25, 2024 at 7:46 AM
    tysonjunior
    tysonjunior New Member
    2020 Cement CM
    Yeah great pad but too dusty for a street truck.
    Gene_in_FL[QUOTED] likes this.
  26. Apr 25, 2024 at 7:47 AM
    tysonjunior
    2020 Cement CM
    I use these and they are the way to go. Otherwise, use the OEM ones. Quiet and clean.
