Brake pads and rotors
Discussion in '3rd Gen Tundras (2022+)' started by demfer, Nov 26, 2024.
  1. Nov 26, 2024 at 2:53 AM
    demfer
    demfer [OP] New Member
    Having a hell of a time navigating the toyota parts for my 2022 TRD OR Limited doublecab. Looking to take advantage of the current promos to get brakes done. Can someone confirm these are actually correct for the top OEM toyota options?
    42431-0C020 - rear rotor
    43512-0C030 - front rotor
    04465-02580 - front pad kit
    04466-60191 - rear pad kit *what the hell does "without fitted parts" mean?*
  2. Nov 30, 2024 at 6:22 AM
    JDAZ
    JDAZ New Member
    Updated front rotor part number 43512-0C040. Might default to this part # anyway. May or may not need the hardware and shim kit
    Rear parts manual
    https://partsouq.com/en/catalog/gen...fYw9XXnwAAAACZaOOJ$&vid=0&cid=2&uid=432573&q=
    Front parts manual
    https://partsouq.com/en/catalog/gen...ZpcmRmLgAAAADFibrQ$&vid=0&cid=2&uid=432572&q=
    sudobash likes this.
  3. Nov 30, 2024 at 6:08 PM
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    Was looking thru the repair manual today and the fitted parts are the anti-rattle clip, new pins, and the cotter pin thingy that goes thru the pins. Could probably clean up the old hardware if there aren’t any cracks in the anti-rattle clip.
  4. Dec 7, 2024 at 5:13 AM
    Keepontrying
    Keepontrying New Member
    da Burgh
    2022 TRD OR, CM 6.5 ft. bed, Blueprint (aka Black, Blue or Purple)
    Anyone have instructions on how to put brakes in maintenance mode to release the electric parking brake/rear brakes?
    chrisgibbs707 likes this.
  5. Dec 7, 2024 at 6:16 AM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Someone on here used a 9v battery
  6. Dec 7, 2024 at 12:06 PM
    chrisgibbs707
    Socal
    2022 Tundra SR5 4x4
  7. Dec 7, 2024 at 12:26 PM
    Pine_Cone67
    Pine_Cone67 New Member
    2024 Tundra Limited
    Saw your write up (thanks!) but still trying to wrap my head around why you chose 9v battery versus engaging the brake service mode (somehow well documented on the internet for other Toyota models w/ electronic brake).
    chrisgibbs707[QUOTED] likes this.
  8. Dec 7, 2024 at 12:36 PM
    JDAZ
    JDAZ New Member
    It is astonishing to me that there isn't a brake service mode. Shouldn't have to use a 9V battery. Shouldn't have to buy a special tool just to do brakes. My wife's CX-5 has an easy brake service mode. I tried to do it a couple times for shits and grins and gave up yet these "pros" on the interwebs make it look easy. No one on here has done it. I have Techstream. Maybe there's a utility in there but still shouldn't have to use proprietary software for friggin' disc brakes.
  9. Dec 7, 2024 at 1:08 PM
    Pine_Cone67
    2024 Tundra Limited
    Are you saying the method (shown below) to place the brakes in the 'service mode' is NOT applicable to the 3rd gen Tundra? This is what I was asking chrisgibbs707:
  10. Dec 7, 2024 at 2:56 PM
    JDAZ
    JDAZ New Member
    People have tried to get it to work and it doesn't work. TBH, I only tried it a few times and I may have not been doing it right. Oddly, it looks like he's doing it on a 3rd gen Tundra.
  11. Dec 7, 2024 at 3:34 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    That's cause the Tundra does not have a Parking brake service mode. The video shows him working on a Rav4.
    The Toyota procedure to compress the rear brake calipers piston on Tundra is to use to a Brake Caliper Windback tool. It's supposed to be treated like a vehicle with a mechanical integrated parking brake caliper. Like this:
  12. Dec 7, 2024 at 4:15 PM
    Pine_Cone67
    2024 Tundra Limited
    Interesting that you say that (about the Windback tool) and a need to 're-wind/turn' the piston in without addressing the electric motor at all. This is not how chrisgibbs707 has done his. Found another example here (tackling the motor first and then just pressing the piston in straight, without a need to re-wind it')
    If you're saying that re-winding the piston replaces the need to 'hack' the parking brake motor with the 9V battery... I say I am no expert but this could be one way to surely damage something.
    chrisgibbs707 and Tundrastruck91 like this.
  13. Dec 7, 2024 at 5:01 PM
    JDAZ
    JDAZ New Member
    I think both are doing essentially the same thing. 9vdc seems to work. The guy in the video looks to be using a small 12vdc battery like possibly a motorcycle battery. Good find though on that video as it seems to explain how the system works without actually explaining it. The info about keeping that slot even with the protrusion on the brake pad is very important.
  14. Dec 7, 2024 at 5:03 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    Yeah. I've seen people used the hack, for me it's unnecessary. I do work on all the vehicle in the house myself too and had to look up procedure to do brakes on my Tundra so I don't damage anything. I have access to Toyota procedure at the shop I work at and the procedure is to just windback the caliper piston. I mainly work only 2020+ MY vehicle rental fleets.
    I get why everyone is doing the "hack" and trying to find the service mode. The old way to compressing caliper piston for Electronic parking brakes for most vehicle was to put in service mode first. The motor prevents you from turning the caliper. But some of these newer vehicle with electronic parking brakes you can just windback. For example, I've worked on newer BMW's I've just wind them back with my Caliper service tool I got on Amazon for $26. They don't have service mode either.
  15. Dec 7, 2024 at 5:15 PM
    Pine_Cone67
    2024 Tundra Limited
    Well, if the windback method works without touching and damaging the electric motor, it's most certainly simplifies things. Thanks for posting!
  16. Dec 7, 2024 at 6:02 PM
    JDAZ
    JDAZ New Member
    I believe I’ve seen your post(s) on this before. Would you mind posting a link to the SST for posterity of this thread. Thank you so much.
