Brake service mode
Discussion in '3rd Gen Tundras (2022+)' started by markshoffit, Sep 7, 2023.
  1. Sep 7, 2023 at 10:06 PM
    markshoffit
    markshoffit [OP] New Member
    MARK
    2022 SR5 Tundra
    Can someone please explain how to put a 2022 Tundra into brake service mode.
  2. Sep 7, 2023 at 10:49 PM
    Aerindel
    Aerindel New Member
    Montana
    I don't want to live in this world anymore....
    Sorry.....I know its not helpful....but GD....I can't believe the stuff new cars get up to.
    Skorch, Mr Badwrench and ArticTundra like this.
  3. Sep 7, 2023 at 11:59 PM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    Welcome to the forum. Are you asking how to engage the emergency brake?
  4. Sep 8, 2023 at 6:11 PM
    markshoffit
    MARK
    2022 SR5 Tundra
    No. How to put into brake service mode so I can replace brake pads.
  5. Sep 8, 2023 at 6:17 PM
    EmergencyMaximum
    EmergencyMaximum New Member
    What is this? Subscribed.
    Check the service manual book maybe?
  6. Sep 8, 2023 at 6:27 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    There is no brake service mode for the 3rd gen tundra.
  7. Sep 9, 2023 at 12:00 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Someone on here mentioned a tool to fully retract the parking brake servos. I haven’t searched for it yet since I’m a long ways from doing rear brakes. (I hope)
  8. Sep 9, 2023 at 12:06 PM
    This is nothing new. Anything with an electronic parking brake has to be put in service mode. This goes back to 2001.
  9. Sep 9, 2023 at 12:46 PM
    EmergencyMaximum
    We had 2000 suzuki xl7 and it was electronic...sorta, but with regular e-handle. You could feel how incrementally it would grab.
    Sorry, I guess irrelevant to this thread.
  10. Sep 9, 2023 at 2:17 PM
    PNW Tundra Mike
    Southern Cal
    We need a Toyota truck Mech in this Forum!!
  11. Sep 10, 2023 at 7:04 PM
    Aerindel
    Aerindel New Member
    Montana
    Guess I've been lucky in my vehicle selection then. I've never encountered this before.
  12. Sep 10, 2023 at 7:47 PM
    I have avoided this very thing as well. I have a bad feeling I won't be able to on my next truck purchase though. :(
  13. Sep 10, 2023 at 8:18 PM
    Aerindel
    Aerindel New Member
    Montana
    I'm pretty sure I will just have to make my current vehicles last forever. I don't think I could live with anything newer than about 2005.
  14. Sep 10, 2023 at 8:21 PM
    You sound like my brother up in Montana. His newest vehicle is probably a LL Bean Subaru...around 2004. His Chevy 3/4 ton 8.1L is a 2001 and still hasn't broken 100k miles.
  15. Mar 21, 2024 at 9:07 AM
    maytyler18
    maytyler18 New Member
    raylo likes this.
  16. Apr 30, 2024 at 6:12 AM
    Fedtime
    Fedtime New Member
    I've tried the above procedure and it does not seem to work on the 2022 Tundra. I get to the point where I'm holding down the brake button and the "P" is flashing rapidly, but then the servos do not release. Does anyone know how to engage brake service mode on the 2022?
  17. Apr 30, 2024 at 9:18 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    There’s no need for brake service mode on 3rd gen.
    https://www.tundras.com/threads/power-stop-brake-pads.140866/#post-3565288
  18. Apr 30, 2024 at 10:01 AM
    Fedtime
    Fedtime New Member
  19. Apr 30, 2024 at 2:34 PM
    Fedtime
    Fedtime New Member
    Here is my modest contribution to the discussion. The brake tool is $80 here in Canada (Princess Auto), and I'm in the middle of nowhere and need the new pads installed, so Redneck SST it is.
    I made mine from a 9v battery, taped some wires onto the contacts and then used some leads from a multimeter.
    Contacts: looking at the connection with everything still attached to the vehicle, positive on the right, negative on the left will spool out the piston. It is the same on both sides.
    My suggestion - go slow and don't spool the piston too far too fast. You only need to spool it far enough to go over the new pads. Also, watch that the piston boot retracts properly. It has folds in it, so it should settle into the creases, but mine didn't and if I had just slapped it back together the boot would have been between the piston face and the brake pad. Once spooled out, you will still need to press in the piston. I used a c-clap style set of vice grips.
  20. Apr 30, 2024 at 6:40 PM
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    2024 SR5 TRD Offroad Lunar Rock
    What is “spooling” the piston? I’ve always just used a c clamp and old pads to compress the piston. Does the tundra require turning and compression?
    as for the parking brake you can set it up so the parking brake stays off. Would this not be good enough? Do you need to retract parking brake for pad swap? Or rotor swap?
  21. Apr 30, 2024 at 6:43 PM
    Oldandfat
    Cannuckastan
    9 volts worked just fine? (Others used 12v)How do you get the parking brake to “set”after the brake job?
    I couldn’t find the brake tool at Princess auto. Is it,called something else?
  22. Apr 30, 2024 at 6:54 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    The 3rd gen Tundra has an Electronic Integrated parking brake. Instead of a cable like on a mechanical integrated parking brake, it uses an electric motor to turn the piston in and out. So you have to turn the piston in first before you can compress it.
    Also not sure if it’s doable, but on Honda’s I’ve taken the actuator off, 2 bolts. And turn the piston in from back side of caliper. Believe a torx bit fit in there. I would think the Tundra be the same.
  23. Apr 30, 2024 at 7:05 PM
    Oldandfat
    Cannuckastan
    I,kinda understand. I,just thought the electronic version was like the cable, and activated the parking brake inside the rotor. I,didn’t realize,the electronic parking brake activated the actual piston.
    what I,don’t understand is you can deactivate the parking brake so can’t you just do that, and swap pads out?
  24. May 1, 2024 at 1:33 AM
    Fedtime
    Fedtime New Member
    Some use 12v, I used 9 and it worked fine, just slower. The Princess tool is called a “wind back brake caliper” tool. It is $79.
    Once the work is done, just activate the parking brake using the switch in the cab. This will seat the piston to the correct position. You may have to cycle it more than once, but it is self adjusting and will “set” itself.
  25. May 1, 2024 at 1:38 AM
    Fedtime
    Fedtime New Member
    No. The parking brake only retracts the piston far enough to release the pads and allow the rotor to spin. To get new pads in place, which are thicker than what you are replacing, you have to back off the piston to make the needed space. From what I have seen, it can be done in three ways: 1 apply voltage to the electric motor as I did; 2 buy the wind back tool and manually wind back the piston; 3. Remove the electric motor from the back of the caliper as suggested above and manually wind back the piston (not 100% sure on this one since I’ve not done it).
    TakiEvo likes this.
  26. May 1, 2024 at 2:00 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    If you do decide to wind the piston back in...make sure the seal doesn't spin on you. I tried that and it started dragging the seal and twisting it. Applying 12v to the pins was easier
  27. May 2, 2024 at 6:19 PM
    umrex
    umrex New Member
    Damn I attempted upgrading the rear pads and could not get the caliper off. Sigh……I am very mechanically inclined but need a visual tutorial. There is nothing on YouTube. I just decided put all the bolts back on as I didn’t want to mess it up.
  28. May 2, 2024 at 6:41 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    I’m not really understanding why you guys don’t just disable the electronic parking brake then do the pad change? I keep mine disabled, don’t like to hear the noise coming from it.
  29. May 2, 2024 at 7:09 PM
    umrex
    umrex New Member
    Honestly I don’t know how to do this. How?
  30. May 2, 2024 at 7:12 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Tundrastruck91 likes this.
