Brakes by Napa, anyone try these?
Discussion in '2.5 Gen Tundras (2014-2021)' started by bmw345, Mar 31, 2023.
  1. Mar 31, 2023 at 6:17 AM
    bmw345
    bmw345 [OP] New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    I'm coming up on 48k, so brake replacement is eminent. I snagged these Adaptive one performance rotors at Napa. Always had good luck with OEM but figured i would try these. Couple hundo more than OEM. Anybody have any experience with these.
    kittyhawk and Leo's first like this.
  2. Mar 31, 2023 at 6:34 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I have used the Adaptive One pads on a 1st Gen Tundra, and they worked well.
    No experience with the rotors, but I'm sure they are good quality.
    bmw345[OP] likes this.
  3. Mar 31, 2023 at 6:40 AM
    CTundraForMe
    CTundraForMe New Member
    Last I heard, NAPA is on the higher end. I wouldn't use anything from Autozone (and I mean anything), maybe O'Reily, and more likely NAPA.
    Sierradevil and bmw345[OP] like this.
  4. Mar 31, 2023 at 6:42 AM
    ljburns
    ljburns New Member
    I have both on my truck now, pads and rotors. Both front and back. Work well for me. I also have them on my 2002 Camry. Never a problem.
    Joe333x and bmw345[OP] like this.
  5. Mar 31, 2023 at 10:29 AM
    sleepydog
    sleepydog New Member
    Derrick
    Clarksville, TN
    2019 SR5 TRD Offroad
    Katzkin Leather Interior, Leather Factory Steering Wheel, TRD Front Skid Plate
    I used Napa pads and rotors on my Tacoma - they are solid. Handed it down to my daughter and they are still performing well.
  6. Mar 31, 2023 at 10:45 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Used to work at Napa when going to be community college years ago. Adaptive One brakes were very good quality and held up! I’d recommend them for sure.
  7. Mar 31, 2023 at 11:12 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I have these in mine. They were on the truck when I purchased it at 42k miles and I’m now at 59k with some decent towing and every time I check them at rotations they don’t seem to have worn much. They seem pretty good. Under a lot of sustained heavy braking I notice a slight vibration in the pedal (not like warped rotors though) which goes away once they cool back down. I’m assuming it may be related to the slots.
  8. Mar 31, 2023 at 7:50 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    I installed them on my wife's Kona. They work well.
  9. Apr 2, 2023 at 5:55 PM
    SPOirish28
    SPOirish28 New Member
    Ontario, Canada
    2014 SSM SR5 DC
    Satin black roof, 18” KO2’s, satin black powder coated steel rims, tri fold tonneau cover. Led lights interior, exterior. Trd pro grill. 13” ryonnair antenna. OEM LED headlights.
    I might try some of these, got my truck in Dec/22 and the rotor hubs are very rusty, bit of pulsating. Probably do them when I swap to summer tires in the next month or so
  10. Apr 6, 2023 at 11:57 AM
    kevine0001
    kevine0001 New Member
    Kevin
    Used them on a car that I no longer own, but had them for at least a year. No issues.
  11. Apr 7, 2023 at 8:56 AM
    kittyhawk
    kittyhawk New Member
    Dave
    Houston/Buffalo Texas!!!!
    2015 Tundra Crewmax SR5 4x4
    6112/5160. Ranchhand rear bumper and Valhallas Shields.
    I'm going to have to do brakes in the next 5 -10k and been thinking about trying those. My biggest concern is can the rotors be turned if they warp that and the price is kind of high. But will be on the look out for a good coupon.
  12. Apr 7, 2023 at 4:12 PM
    bmw345
    CT
    they are going on sometime next week. I'll let you know
    thearborbarber likes this.
  13. Apr 8, 2023 at 3:48 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    OEMs are better and worth the cost. IMO.
    Brownsfanhere, Soupbean77 and WILLINH like this.
  14. Apr 8, 2023 at 12:06 PM
    bmw345
    CT
    Always had good luck with OEM, trying something different here! These cost a little more than OEM.
  15. Apr 9, 2023 at 3:45 AM
    Crunch527
    Iowa
    yeah, sharing that I did same…thought the OEMs that I got 70K miles out of weren’t good enough…went with a power stop package…they suck…slotted rotors and all…have to be hot to work and even then they don’t stop as well. Just not worth the coin.
    My best advice is to do something else with that coin.
  16. Feb 24, 2025 at 12:24 PM
    TNVols865
    TNVols865 New Member
    will
    2017 Blue Tundra Double Cab TRD Off Road
    I bought he adaptive one’s for my 17 double cab and they warped within a week. May have had a bad batch but scared me out of buying them again.
    WILLINH likes this.
  17. Feb 24, 2025 at 1:05 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    I like oem because i dont have to mess with any bedding procedure. Slap it on and go.
  18. Feb 24, 2025 at 1:16 PM
    Tundra family
    Tundra family New Member
    Got about 12k miles out of the pads if I remember correctly, never used the slotted rotors. Ymmv, I haul heavy.
  19. Feb 24, 2025 at 3:41 PM
    SPOirish28
    Ontario, Canada
    2014 SSM SR5 DC
    I’ve had Napa rotors on for 20,000km now and going strong. They’re just blanks, not slotted or anything though. My mechanic advised against Napa pads though. Too many people coming back saying they squeak/ squeal. Using Bosch pads on Napa rotors, smooth as silk, and never once made a squeak or anything.
  20. Feb 25, 2025 at 8:23 AM
    bmw345
    CT
    About 14k in now with the Napas. So far so good.
    Tundra family likes this.
  21. Feb 25, 2025 at 7:19 PM
    jmanscotch
    jmanscotch New Member
    Jake
    2020 Tundra TRD OR CM
    I put the NAPA Adaptive One wiggly rotors and matching pads on several months ago and I’ve been happy.
    We have an in house NAPA store at my work and you guys would kill me if you knew what I got these front rotors and pads for on my Tundra. Getting NAPA parts at cost is going to spoil me.
    That said, they seem like a very small, probably just placebo effect, upgrade over OEM but I appreciate that they have a good warranty for any future warping issues. My original rotors and pads made it 50k before warping.
