Brand new truck squeak and burnt smell
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by kens3313, Feb 11, 2019.
  1. Feb 11, 2019 at 8:38 AM
    kens3313
    kens3313 [OP] New Member
    Ken
    I just bought a new tundra 2019 with 5.7 and after cold start and the first turn of steering wheel I hear a small squeak. Just wondering if anyone else has had this problem. Also after driving for 30 mins or so something has a burnt smell. I only have 1500 miles on it. Not sure if burning smell is just new stuff burning if its normal.
  2. Feb 11, 2019 at 11:31 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Don't mean to bring bad news, but I would look through the wheel wells near the back under the valve cover for a leak..
    Lake.Life24, Prostar 190 and OR18TRD like this.
  3. Feb 11, 2019 at 11:37 AM
    JNeemus
    JNeemus New Member
    Arroyo Grande, CA
    2024 Tundra Limited
    Maybe ignore that first comment. A brand new truck will almost certainly not have a leak causing this.
    Most likely it is the common burning off smell associated with a new vehicle as it warms up.
    I’m not sure about the squeak you’re describing. Any video?
    white_sherpa, TheBeast and Newm like this.
  4. Feb 11, 2019 at 11:40 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    k
  5. Feb 11, 2019 at 11:57 AM
    TheBeast The Beach
    maybe still burning off that new exhaust smell unless it's a new "burning" smell. best is to bring it to the delaership
  6. Feb 11, 2019 at 12:21 PM
    ScarWars
    ScarWars New Member
    2019 Toyota Tundra TRD PRO Super White
    Doesn’t the ABS brake system do a self check after you start and drive off? Maybe that’s what you hear..not sure
  7. Feb 11, 2019 at 12:40 PM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    There are plenty of "brand new" Tundras that have the Cam Tower oil leak. Mine started leaking at 14,000 miles. It was a good suggestion by @jeremyd . Look here: https://www.tundras.com/threads/cam-shaft-tower-seal-leaking-please-read.20102/
    Plenty of very low mileage oil leaks in there.
  8. Feb 11, 2019 at 1:10 PM
    JNeemus
    JNeemus New Member
    Arroyo Grande, CA
    2024 Tundra Limited
    white_sherpa likes this.
  9. Feb 11, 2019 at 1:32 PM
    Padj
    Padj Life is what happens when you're making plans
    Denver, Colorado
    2019 Limited CM TRD MGM
    I have a 2019 same milage still have the smells. I do have a creak when I push it in drive and go. Not related to turning the wheel, though.
  10. Feb 11, 2019 at 2:09 PM
    Atomic City Tundra
    Devin
    New Mexico
    No perspective needed. It is a known issue with the 5.7 engine. Go through the thread. More than one instance of Tundras with discovered leaks at the first vehicle service. While it probably isn't the problem in this case, it is worth checking.
    GNTundra likes this.
  11. Feb 11, 2019 at 2:26 PM
    JNeemus
    JNeemus New Member
    Arroyo Grande, CA
    2024 Tundra Limited
    That’s why I agree. I’m well aware of this known issue.
    This is a 2019 with 1500 miles. It’s probably just burning off like every other new vehicle.
    NewImprovedRon likes this.
  12. Feb 11, 2019 at 5:34 PM
    kens3313
    Ken
    Did some searching on the forum and there are a few others that has the same little squeak after putting it in drive and taking off. Sounds like the problem from what ive read is nothing to worry about.
  13. Feb 13, 2019 at 9:39 AM
    TundraPro2019
    TundraPro2019 New Member
    Barthold
    Western Slope, CO
    2019 Tundra TRD Pro
    I have no burning smell on my also brand new 2019. ~800 miles on the odometer.
  14. Feb 13, 2019 at 11:02 AM
    ScarWars
    ScarWars New Member
    I have 500 mi on the clock of my new 19 Pro and yesterday I could smell a slight burning smell in my garage after I shut the engine off.
    After doing some looking around the forum I guess Its pretty common for Tundras have cam tower leaks. This will leak a little oil and get on the exhaust causing the burnt smell.
    I saw the pics members have taken showing where the leak was coming from.
    I went out with a flashlight and mine seems to be dry. No visible leak.
    Hopefully it’s just the new wearing off.
    TheBeast likes this.
  15. Feb 13, 2019 at 12:03 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    I had a cam tower leak. It was a very noticeable burning smell. The oil was dripping onto the heat shield and burning. It does not smell like a new car break-in smell.
  16. Feb 13, 2019 at 12:13 PM
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    related-not-related... just got a new oven, and holy crap did that baby smell (with a visible cloud) during the first fire up. Not something you expect. So I completely understand the worry
  17. Feb 13, 2019 at 2:12 PM
    TundraPro2019
    Barthold
    Western Slope, CO
    2019 Tundra TRD Pro
    You put your truck in the oven?
  18. Feb 13, 2019 at 2:21 PM
  19. Feb 14, 2019 at 3:45 AM
    niscur38
    niscur38 New Member
    2019 with 1500ish miles on it. It does have a little squeak after getting out of reverse and driving off. It did have the new car burnt off smell at first. Especially if I had got on it a little bit right before shutting it off.
  20. Feb 14, 2019 at 4:27 AM
    ScarWars
    ScarWars New Member
    My 19 doesn’t have a squeak. It has a slightly audible thump right when you take off.
    Sounds like someone lightly tapped on your TRD skid plate with a hammer. If you have the radio on you wouldn’t hear it. I believe from what I’ve read it’s the abs self check
  21. Feb 14, 2019 at 4:42 AM
    timsp8
    NY
    Do you live in a cold area? Could the squeak be the belt when the power steering first puts a load on it?
  22. Feb 14, 2019 at 5:00 AM
    Mnorris1206
    08 tundra
    All new things that heat up will have a smell .Furnaces ,water heaters , ovens , cars , I say take a nice long trip in it. In the hot summer time .And I believe it will go away .Everything has a dab of oil coating to keep everything looking nice for the new buyer .
    ScarWars, War Machine and Jengel451 like this.
  23. Feb 14, 2019 at 5:13 AM
    War Machine
    War Machine SSEM # 5 3MW
    Every new vehicle I’ve ever owned had the burning smell for a while. It always worries me at first.
    ScarWars likes this.
  24. Feb 14, 2019 at 8:42 AM
    TundraPro2019
    Barthold
    Western Slope, CO
    2019 Tundra TRD Pro
    Mine does that too.
  25. Apr 3, 2019 at 6:48 AM
    shulsy
    shulsy New Member
    Jamey
    Maryland
    2023 Tundra Platinum Hybrid
    I’ve had my 2019 CM Tundra for almost a month (750 miles) No squeak, but do have the normal ABS thump.. nothing big.
    I do have a burning smell though. Noticed it bad this past weekend and again this morning. The smell was strong enough to come through the vents. For peace of mind, I’ll be taking to the dealership, but I’m hopefully it’s just a new car use thing!
  26. Apr 3, 2019 at 7:47 AM
    ScarWars
    ScarWars New Member
    I have a 19 Trd Pro and I had the burning smell for a little over a thousand miles. I have about 1400 mi now and I don’t notice it anymore.
    shulsy[QUOTED] likes this.
  27. Apr 3, 2019 at 7:54 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I've had eight (8) brand new (from the factory) Toyotas over the years. Every single one has had funky lil' smells when new. My explanation each and every time? "It's a new car." Within 5,000 miles it was neither noticed any longer nor remembered. On all 8.
    shulsy likes this.
  28. Apr 3, 2019 at 9:32 AM
    shulsy
    shulsy New Member
    Jamey
    Maryland
    Yeah, it's probably nothing, but I work in a mx type area and all the mechanics said shouldn't have any burning smells. Just to be safe I have an appointment today to have Toyota check it out. I'll post what the dealer says!
  29. Apr 3, 2019 at 3:16 PM
    shulsy
    shulsy New Member
    Jamey
    Maryland
    Dealership said it’s the rust prevention coating put on the truck for my region (Utah). Said to take to car wash and expect it to dissipate around the 1.5K-2K miles range.
    He gave me the chemical name but it was long and I didn’t write it down lol!
    ConcordCarlos and Mnorris1206 like this.
