Break away cable placement
Discussion in 'Towing & Hauling' started by Northwoods22, Mar 7, 2024.
  1. Mar 7, 2024 at 8:47 AM
    Northwoods22
    Northwoods22 [OP] New Member
    MN
    2013 tundra grade
    Hey guys, where is everyone attaching there break away cable on their trucks? Drove big boy trucks at work they had a separate eye bolt I believe. Where do you put it on your tundra?
  2. Mar 7, 2024 at 9:19 AM
    I just attach mine to one of the chain hooks.
    Mattedfred likes this.
  3. Mar 7, 2024 at 9:21 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I attach mine to a little carabiner that I put in the chain hook.
  4. Mar 7, 2024 at 9:24 AM
    I attach it directly to the truck receiver hitch safety hooks with a carabiner. If the hitch and or safety chains fail, the trailer breakaway needs to work. If it’s attached to any part of the trailer hitch components, it may not get activated.
    shawn474, Mattedfred and Lifer like this.
  5. Mar 7, 2024 at 9:30 AM
    SD Surfer
    Bruce
    So Cal
    On my '00 I drilled and attached a seperate eye bolt. (I've yet to do that on the '19)
    Technically it's supposed to be attached somewhere other than your hitch, since if your whole hitch w/safety chains gets ripped off and your breakaway is attached to that it won't be activated.
    bflooks, 2mchfun, PBNB and 1 other person like this.
  6. Mar 7, 2024 at 9:46 AM
    Northwoods22
    MN
    2013 tundra grade
    That’s what I thought. I’ve been attaching it to just the chain hooks but I don’t think it’s fully correct
    2mchfun likes this.
  7. Mar 9, 2024 at 8:36 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I connect mine to one of my hooks. I do see the logic in a completely separate connection! Then it is good to check the connections of the hitch to the truck and make sure that the bolts are there and still tight.
    There was a thread in the Airstream forum where the trailer rolled away when the hitch rusted out and basically fell off the tow vehicle. That is just someone not taking a moment to have a look at the hitch condition!
    For our newer trucks we will probably need a few years before the rust eats the hitch and surrounding materials :)
    If you are using a weight distribution hitch, that should help to keep the ball and coupler together..
    Cpl_Punishment likes this.
  8. Mar 9, 2024 at 9:09 AM
    2mchfun
    Looks like the payload and safety police are slacking!
  9. Mar 9, 2024 at 9:10 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I was talking to one guy with a lot of towing miles about it and he figures if you're going to have a problem with the way things are hitched up, it's going to happen early in the trip. So he recommends stopping after about 20 minutes and checking everything over.
  10. Mar 9, 2024 at 9:19 AM
    if the hook comes off, no emergency braking will activate.
    PBNB[QUOTED] likes this.
  11. Mar 9, 2024 at 10:07 AM
    Retired...finally
    That's my MO. 10 miles to the interstate and 9.something to the BP station on the right. Tire and bearing heat, any tiedowns and hitch integrity.
    A far as the emergency brake cable goes, a clip a bit more secure than the faux carabiners is snapped on the cable loop then pushed through the safety chain elongated hole on the Tundra hitch. Then snap it on the cable itself. If the hitch falls off the truck I have real problems and my annual inspection isn't working.
    PBNB and Cpl_Punishment[QUOTED] like this.
  12. Mar 9, 2024 at 12:39 PM
    bflooks
    bflooks New Member
    Metrowest MA
  13. Mar 9, 2024 at 2:00 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Terrifying, probably extremely uncommon, but it makes sense and takes not much effort to mitigate
    Mattedfred, NewImprovedRon and PBNB like this.
  14. Mar 9, 2024 at 2:23 PM
    Rerun
    Rerun New Member
    Rick
    Tucson AZ
    2019 Crewmax Limited TRD 4x4 white
    Thanks for posting this. I am hooked up and ready to go camping in a few days. Of course, my breakaway cable is hooked up like most people do. On my way out to the shop now to find an alternate location.
  15. Mar 9, 2024 at 4:03 PM
    Retired...finally
    Yeah but that was a Chevy.:anonymous:. I'll look for a different attachment point but I don't think my license plate mount is up to the job.
    Northwoods22[OP] and Mattedfred like this.
  16. Mar 9, 2024 at 6:54 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Without a washer/nut on the backside, no. Otherwise, yes. Give it a test and see what works for you. Always a big believer in "prove it" adoption.
